DJI Osmo 360
Kosh
7 September 2006
106,156
Εκεί ψηλά.....
Meet DJI Osmo 360 - 8K Revolutionary 360° Camera​
DJI
DJI Osmo 360 First Look – The Best-Looking 360 Camera Yet?​
Bobby Tonelli
Video up to 8K 50fps panoramic or 4K 120fps single-lens​
For the panoramic video (with both sensors and lenses recording the full 360° video), the Osmo 360 offers the following resolutions and framerates:
  • 8K: 7680 × 3840 @ 24/25/30/48/50fps
  • 6K: 6000 × 3000 @ 24/25/30/48/50/60fps
  • 4K: 3840 ×1920 @ 100fps
On top of 360° mode, when both lenses are capturing images, the camera also offers a single-lens mode. The benefit of this one is that the image processing is faster, and therefore the Osmo 360 can shoot up to 5K 60fps or 4K 120fps video with a 155° (or 170° in ultra wide-angle video mode) field-of-view. Users can also switch between the front and rear lenses during a take without stopping recording. This can be useful for vlogging. In the single-lens video mode, the camera is capable of:
  • 5K (4:3): 5120 × 3840 @ 25/30fps
  • 5K (16:9): 5120 × 2880 @ 25/30/50/60fps
  • 4K (4:3): 3840 × 2880 @ 25/30/50/60fps
  • 4K (16:9): 3840 × 2160 @ 25/30/50/60fps
  • 2.7K (4:3): 2688 × 2016 @ 25/30/50/60fps
  • 2.7K (16:9): 2688 × 1512 @ 25/30/50/60fps
  • 4K (4:3): 3840 × 2880 @ 25/30/50/60/100/120fps (ultra wide-angle video)
  • 4K (16:9): 3840 × 2160 @ 25/30/50/60/100/120fps (ultra wide-angle video)
  • 2.7K (4:3): 2688 × 2016 @ 25/30/50/60/100/120fps (ultra wide-angle video)
  • 2.7K (16:9): 2688 × 1512 @ 25/30/50/60/100/120fps (ultra wide-angle video)
Best 360° Cam 2025? DJI OSMO 360 vs Insta360 X5 32-Min Unsponsored Review​
Hugh Hou
DJI OSMO 360 vs Insta360 X5 - Which 360 Camera is Right For You?​
The Drone Creative
Osmo 360|First Use​
DJI Tutorials
Καλά η DJI ξέρει να κάνει μάλλον τα καλύτερα demo από κάθε άλλη εταιρία (ακόμα και από την Apple). Δεν υπάρχουν τα πλάνα που βάζει, τόσο σ'αυτό το μαραφέτι όσο και στα drones.
Κατά τα άλλα, φανταστικό παιχνίδι, πολύ θα ήθελα να το ψαχουλέψω, αλλά δε μπορώ να φανταστώ ούτε μισό use case scenario για μένα, οπότε δεν.
Reactions: papg and tiniakos
Key features​
  • 8K30 360° Action Camera with 1″ Sensor
  • Capture up to 4K120 and 170° Boost
  • Capture up to 120MP 360° Stills
  • Osmo Magnetic Quick Release Ecosystem
  • Capture up to 100 Minutes of 8K Video
  • 10-Bit and D-Log M Color Profile
  • OsmoAudio Direct Microphone Input
The new 1″ CMOS sensor paired with dual wide-angle lenses delivers 360° imaging with minimal power consumption. Featuring an f/1.9 aperture, its image quality is stated to remain crisp and bright, even in low-light conditions. A new pixel-allocation scheme allows you to capture 8K30 360° video, and the camera features an ultra-high dynamic range that is claimed to rival cinema cameras, offering a 77% image quality improvement over 5.7K sensors.
The sensor also offers high frame-rate 360° Video that captures ultra-smooth 6K60 or cinematic scenes using 4x slow motion with 4K100 360° video.
  • 5K (4:3): 5120 × 3840@25/30/50/60fps
  • 5K (16:9): 5120 × 2880@25/30/50/60fps
  • 4K (4:3): 3840 × 2880@25/30/50/60fps
  • 4K (16:9): 3840 × 2160@25/30/50/60fps
  • 2.7K (4:3): 2688 × 2016@25/30/50/60fps
  • 2.7K (16:9): 2688 × 1512@25/30/50/60fps
In single-lens mode, the Osmo 360 captures of 4K120 video with a 170° ultra-wide field of view.
  • 4K (4:3): 3840 × 2880@25/30/50/60/100/120fps
  • 4K (16:9): 3840 × 2160@25/30/50/60/100/120fps
  • 2.7K (4:3): 2688 × 2016@25/30/50/60/100/120fps
  • 2.7K (16:9): 2688 × 1512@25/30/50/60/100/120fps
You can also switch to 5K60 with a 155° super-wide field of view for a different perspective.
The maximum recording bitrate is 170 Mbps.
The Osmo 360 features prerecording, selectable from 5 to 30 seconds up to 1 to 5 minutes.
Χμμμμμμμμμ μαλλον παει για χρηση με υποβρυχια θηκη (που δεν υπαρχει ακομα ....) η συγκεκριμενη αν δεν φτιαξουν το προβλημα.
  • Sad
Reactions: Φρα.Πε.
Καποιος youtuber έκανε ένα tear down και αν καταλαβα καλα απο τον τίτλο (δεν το παρακολούθησα) έλεγε πως δεν είναι φτιαγμένη για να επισκευάζεται!
Γενικά πάντως η πρώτη 360 υλοποίηση της dji είναι πολύ δυνατή και θεωρώ πως το επόμενο μοντέλο θα είναι πολύ καλύτερη πρόταση χωρίς παιδικές ασθένειες. για την ώρα play safe Χ4/Χ5.
Συμφωνώ...η Insta X5 με χειρότερα specs την κατάπιε την dji με την πρώτη της αυτή προσπάθεια στα 360 , ειδικά σε εικόνα / χρώματα , edit video software and interface στο κινητό αλλά και άλλες ευκολίες , plus service φακών ..εν αναμονή της δεύτερης προσπάθειας!!
Reactions: Φρα.Πε.
New Canon 360 Camera vs Insta360 X5 | Why This 8K Video Looks Better​
Hugh Hou
Bαλτε στα 8k την αναλυση για να δειτε την διαφορα.
Reactions: Φρα.Πε.
Η διαφορά είναι μεγάλη όπως και η πρακτικότητα και το κόστος. Εξυπηρετούν διαφορετικές ανάγκες πάντως τα setup. Επίσης παραπλανητικος και ο τιτλος καθότι μιλάμε για φακό 190 μοίρες οχι κάμερα 360.
Νομιζω οτι το λεει γιατι συνηθως για ληψη 360 μοιρων χρησιμοποιουν παντα ενα rig 2 τετοιων καμερων (με φακο 180 μοιρων) οταν προκειται για τετοιες καμερες
Reactions: Φρα.Πε.
