Ενα...νεοκλασσικό ζευγάρι.Luxman SQ 38u/D 38u
DIPIE
13 July 2007
17,263
Δεν ξέρω τι λέει στους νεώτερους,η νέα αυτή σειρά της θρυλικής Luxman,αλλά προσωπικά όταν τα κοιτάζω,κάτι φωνάζει μέσα μου...Τα θέλωωωωωωωω.....
phpThumb.php
SQ-38u
Luxman SQ-38u Integrated Amplifier - Tube
Luxman first introduced the SQ-38 in 1963 and it was a terrific success.
Second Generation of the famous "SQ-38D" is that from 1964, roughly 44 years ago!
(Output tubes: 6RA8, power transformers: OY-14, 10W +10 W) at 50,000 units was also a big hit.
Third Generation "SQ-38F" in 1968, F at the time was meant as an abbreviation for Final as Luxman thought that they would soon have to cease vacuum tube production due to the increased prevalence of the transistor in audio component design.
For 2009 the eleventh generation SQ-38 is a wonderful blend of old & new; the Luxman SQ-38u incorporates many modern features in a classic design that exudes luxury & class.
Another remarkable design from Kazuyuki Doi - who brought us the MQ-88 / CL-88 as well more recently the NeoClassico. Conservatively rated @ 30 watts per channel, the Luxman SQ-38u gives an ultra-linear output as well as offering the trademark Luxman reliability and quality build.
Here is an amplifier that can be inherited by the next generation.
Luxman SQ-38u New Product Information here
Manufacturers Website here
6 Moons review here
SPECIFICATIONS
Output: 30W +30 W (6Ω), 25W +25 W (8Ω, 4Ω)
Inputs: 1 phono (MM / MC high / MC low), 4 line inputs
Recording input and output: REC output, monitor
Speaker Outputs: A, B (independent switching, with simultaneous output)
Remote Control Functions: Volume up / down, mute
Tube Compilment EL34 x 4, ECC85 (6AQ8) x 5, ECC82 (12AU7) x 2
Dimensions: 15.7" (400mm) W x 7.7" (196) H x 12.2" (310) D
Weight: 44 lbs. (20 KG)
Supplied Accesories: Remote Control, JPA-10000 Power Cord
Luxman announce the D-38u CD player.
The styling is clearly designed to be the perfect partner with the recently launched SQ38u integrated. Price is anticipated to be around £2500 and UK availability in Nοvember.
D-38u Features:
• 16mm thick MDF case with a natural wood veneer enhances the overall rigidity of the D-38u
• More than just a pretty face, the 8mm thick front panel, is a hairline-finished aluminum board which adds chassis rigidity
• D-38u circuitry is designed specifically for playing CDs, with a left-hand mechanism adopted for an ideal flow of power supply and audio signals
• Drive mechanism is supported on a thick 15mm base plate of pure aluminum for added stability and reduced jitter
• D-38u D/A converter features a 24Bit, 192KHz PCM1754 Burr-Brown DAC chipset
• Switch on the fly between Tube Output and Solid State Output, 12AU7 is only lit when vacuum tube section is in use
• Headphone output is driven by analog output, can be switched between Tube and Solid State on the fly
• Large, Easy to read display offers a 3-stage dimmer function (brightness adjustment)
• Externally cosmetics mirror other Luxman 38 series components, including power ring indicator and up/down lever switch
• Supplied full function aluminum remote control with wooden border even allows adjustment of the SQ-38u volume
• Vacuum tube components are designed for a life-time of service and are stress tested for 24 Hrs before installation into D-38u
Specifcations
Applicable disc: Compact disc
Analog output: 1 x unbalanced line, the 18-mm pitch gold-plated output terminal
Digital output (44.1kHz): 1 x coaxial line, 1 x optical line (TOS-LINK)
Output voltage/frequency response: 2.0V/4Hz-20kHz
Total harmonic distortion/signal-noise ratio: 0.004%/95 dB
Front panel: Power operation switch, headphone jack, headphone volume, output changeover switch, FL display, disc tray, play key, pause key, stop key, next/previous track keys, disc eject key
Rear panel: Input/output terminals, AC inlet
Remote control function: (other than all the switch functions on the main unit) numeric keypad, time display selection, display dimmer Special playback keys (track order program/random/repeat/A-B repeat/introduction/recall play)
Dimensions and weight: 400 x 168 x 280 mm (WxHxD) (excluding terminals and knobs), 9.0 kg
Accessories: Remote control (RA-N3)
Νομίζεις ότι μόνο εσύ τα θέλεις? χεχε
Πάντως φαίνεται να έχει πιάσει τους Ιάπωνες μια 70's retromania. Πρώτα η Yamaha με τη σειρά ΑS και τώρα η Luxman.
Όπως έχω ξαναπεί το κλασσικό είναι πάντα in, η σειρά αυτή της Luxman είναι μακράν ότι ωραιότερο και πληρέστερο έχω δει σε στυλ vintage
Καλή αντιγραφή πάντως είναι και η τελευταία σειρά της Cayin
DF
