[Επίσημο] iPad Pro @2020
Όσο διαβάζω για το νέο Smart Keyboard τόσο περισσότερο ψήνομαι:
MAGIC KEYBOARD FOR IPAD PRO
This thing looks amazing. Real keys (with backlighting). It floats the iPad above the keyboard surface. You can apparently tear off the iPad from the keyboard with a single hand. And there’s no kickstand. It’s strong enough to hold the iPad Pro in place, adjustable to any angle from 90° to 130° — a significant range of motion.
Basically, this makes a “docked” iPad Pro a true clamshell laptop. It’s still going to be very top-heavy compared to a pure laptop, but that’s inherently true for any dockable tablet. On a pure laptop, the top part is only a display, and the display surface is lightweight plastic, not glass. On a tablet, the whole “computer” is in the top part, and the display is (relatively) heavy glass.
Apple’s Smart Keyboard covers have been… fine. But they’ve clearly been — if not afterthoughts, per se — at least sorta kinda on the afterthought spectrum. They seemed designed only for typing, and yet for typing alone, weren’t that great because they use those fabric-covered squishy keys. One of Apple’s decade-old arguments against touchscreen Macs is about the ergonomics of reaching up and out to touch a vertical or near-vertical display. And they’re right — it is uncomfortable to poke at a vertical display for more than a few seconds. But without a trackpad (and, of course, without trackpad support in the OS) that is the only way to do many things on an iPad in a Smart Keyboard. Clamoring for touchscreen support on Macs is unlikely ever to stop, but I feel strongly that iPads needed trackpad support — both for ergonomic comfort and for precision. Touchscreen support for Macs is, at best, a nice-to-have idea. (And if you ask me, it’s a feature that only sounds good.)
Apple’s Smart Keyboard covers have always been very limited in terms of viewing angles. The current ones have two slots; the older ones had just one angle. A proper laptop, of course, uses a hinge, with a range of motion that lets you adjust the display angle until it’s just right for you.
Put another way, with its Smart Keyboard covers, it has never seemed like Apple was even trying to be in the game for the best way to turn a tablet into a laptop form factor. With this new Magic Keyboard, if it works as well as it looks like it does, Apple quite possibly has jumped to the head of the pack. This is a setup that someone might consider even if they are primarily looking for a laptop, not a tablet. It turns it into a matter of OS preference, not form factor.
Magic is better than smart, at least when it comes to iPad keyboard covers.
There is no aspect of today’s product announcements that more makes me wish it had been feasible for in-person briefings and hands-on time than the hinge on the Magic Keyboard.1 It simply looks too good to be true that it’s strong enough to suspend the iPad Pro above the keyboard without flopping. Real keys, a real trackpad, no kickstand. It even has its own USB-C port to charge your connected iPad Pro via the Smart Connector, freeing the iPad’s own USB-C port for peripherals. It’s the first attempt from Apple at a way to use an iOS device primarily as a laptop. Talking to Apple about it, they claim the hinge and magnetic connection are more than sturdy enough to actually use it on your lap.
There’s no special name for the one and only color option, but judging from photos (and AR) it’s a very cool near-black. It makes me wish they’d switch the dark option for MacBooks from “space gray” to this near-black color — if you’re going to offer a darker option, go a lot darker. They’ve even added an Apple logo to the back — oriented for landscape. Put an iPad Pro in this case and it’s a laptop.
The only downsides: the Magic Keyboards are not available until “May”, and they cost $300/350 respectively for the 11/12.9-inch iPad Pros. That’s not cheap, but these don’t look cheap. And a bonus: they’re fully compatible with the previous generation 11- and 12.9-inch iPads Pros, including the camera cutouts on the back.
https://daringfireball.net/2020/03/super_wednesday
Απάντηση: Re: [Επίσημο] New iPad Pro @ 2020
Οι αναλογίες οθόνης πάλι δεν είναι για ταινίες δυστιχως. Γιατί δεν το κάνουν 16:9
Μακαρι ΝΑ ΜΗΝ τοκανουν!!!!
Πολύ καλα τα σποτάκια και φυσικά το πληκτρολόγιο, $350 όμως;
Aνυπομονώ να δω τι βιντεο εφαρμογές θα βγούν με το Lidar.
Σιγουρα καποιο είδος keying πέρα απο defocus.
«Έλιωσε» το AnTuTu – ξεπέρασε τις 700,000 μονάδες!
Η έκδοση των 11-ιντσών πέρασε από το AnTuTu και αποκάλυψε μερικές ενδιαφέρουσες λεπτομέρειες σχετικά με τις
προδιαγραφές του. Καταρχήν να πούμε ότι η Apple επέλεξε να ονομάσει τον επεξεργαστή του tablet της A12Z ενώ
τα νέα iPhone 11 έχουν τον επεξεργαστή A13. Μπορεί να νομίζετε ότι ο πρώτος είναι ασθενέστερος από τον τελευ-
-ταίο λόγω της ονομασίας τους, ωστόσο αυτό δεν συμβαίνει. Το iPhone 11 A13 έχει επεξεργαστή έξι πυρήνων και
μια τετραπύρηνη GPU. Το A12X SoC, που είχαν τα iPad Pro του περασμένου έτους, διαθέτει επεξεργαστή οκτώ
πυρήνων και επταπύρηνη GPU. Το φετινό iPad Pro, έχει τον A12Z ο οποίος διαθέτει επεξεργαστή οκτώ πυρήνων
και οκταπύρηνη GPU!​
Η μονάδα που πέρασε από το AnTuTu έχει 6GB μνήμης RAM, 2GB περισσότερα από το μοντέλο του περασμένου έτους.
Καθώς η Apple κάνει διαφορετική χρήση της μνήμης στο λογισμικό της -«παίζει» με τα μισά GB που θέλει το Android
συνήθως – μιλάμε για μια μεγάλη αναβάθμιση. Το νέο iPad τρέχει το iOS 13.4 το οποίο δεν έχει ακόμα ανακοινωθεί
και έχει 128GB εσωτερικής αποθήκευσης.
Το σκορ της CPU είναι λίγο πολύ ίσο με το περσινό iPad Pro, αλλά ο πρόσθετος πυρήνας της GPU δίνει μια αύξηση της
βαθμολογίας στα γραφικά κατά 9%. Το iPad Pro του 2019 είχε καταπληκτική απόδοση στο gaming και πιστεύουμε ότι
το φετινό θα είναι ακόμα καλύτερο.
Το συνολικό σκορ είναι ένα από τα καλύτερα που έχουμε δει στο AnTuTu, καθώς πέρασε το όριο των 700.000
με 712,218 μονάδες! Όλοι γνωρίζουμε ότι η σύγκριση των αριθμών στα benchmarks δεν είναι ιδανική καθώς
υπάρχουν πολλές μεταβλητές στη διαδικασία. Ωστόσο το σκορ έχει κοντά 100.000 περισσότερες μονάδες από
τα αποτελέσματα του επεξεργαστή Snapdragon 865 που έχουν οι ισχυρότερες ταμπλέτες με Android.
[via] . [via]
Αυτό που δεν καταλαβαίνω είναι γιατί να πάρεις iPad Pro το οποίο μαζί με το keyboard είναι πανάκριβο και όχι ένα MacBook Air.
Έχω το iPad Air 2 από το 2013 και ένα MacBook Air από την ίδια χρονιά.
Ειλικρινά το air 2 μετά από τόσα χρόνια πετάει :) (γι αυτά που το θέλω )
Και το MacBook Air είναι , όπως λένε πολλοί , ο καλύτερος φορητός που μπορείς να πάρεις .
Εστιάζω στη λέξη φορητός.
Άριστη μπαταρία . Άριστο πληκτρολόγιο . Άριστο βάρος . Θεϊκό trackpad . Ταχύτατο για εφαρμογές γραφείου .
Το νέο air έχει και άψογη οθόνη .
Το δικό μου δεν έχει τόση ευκρίνεια . ( να πούμε και μια αλήθεια οι 13 ίντσες για εμάς τους , λίγο :) , μεγαλύτερους είναι λίγες αν δουλεύεις excel )
Όποτε γιατί iPad Pro και όχι MacBook Air ;;
Δίνει τη δυνατότητα να ξεκουμπώσεις πληκτρολόγιο και να χρησιμοποιήσεις τη γραφίδα, και το χρησιμοποιείς ως ταμπλέτα που το air δεν μπορεί...
Εξαρτάται τι χρήση που κανείς. Το iPad είναι πρωτίστως tablet το οποίο υπό συνθήκες μεταμορφώνεται σε laptop.
Το MacBook είναι αποκλειστικά laptop με προφανώς περισσότερες δυνατότητες multitasking και καλύτερη υποστήριξη σε προγράμματα.
Βέβαια, αν έχεις και τα δυο, υπάρχει συνέργια μέσω του Handoff, χρησιμοποιώντας το iPad ως δεύτερη οθόνη στην οποία μπορείς να χρησιμοποιείς το Apple Pencil πχ για να ζωγραφίσεις, κανείς edit photos, υπογράψεις pdf κλπ
Σε επίπεδο hardware, το iPad Pro είναι πιο ισχυρό από το Air. Φανταστείτε πως σε ένα test για εξαγωγή 4K 60fps αρχείου, το iPad Pro 11 μου (προηγούμενη γενιά) ήταν ελαφρώς ταχύτερο από το top of the line MacBook Pro μου του ίδιου έτους.
Πάντως, εάν δεν είχα τίποτα από τα δυο, πρώτα θα αγόραζα Mac και μετά iPad, βάσει των τρεχουσών αναγκών μου.
Αν θέλεις περισσότερο χρήση ως multimedia consumption καλύτερα ένα Android tablet πχ tab s6 με 16:10 είναι μανουλα.
Και η αλήθεια είναι ότι το γλυκοκοιταζω αλλά με φρενάρει η Sammy με το λογισμικό της,αν έβγαζε πχ η oneplus με OOS αντίστοιχο θα πήγαινα καρφί
Αυτό είναι το θέμα το λειτουργικό μην κολλάει μετά από ένα χρόνο
Εγώ είχα όλα τα samsung me oled, ωραία οθόνη ....αλλά μέχρι εκεί.
Οι εφαρμογές είναι άθλιες και το android για tablet, απλά ανύπαρκτο.
Για τάμπλετ δυστυχώς μόνο iPad.
Εκτός αν θες μόνο να βλέπεις βίντεο ....
Sent from my Nokia 9 using Tapatalk
Έχω Tablet σε ios και πολλά χρόνια ipad 3 δεν έχω παράπονο εκτός ότι δεν μπορώ να περάσω xiaomi mi app γιατί έχει το ios 9 και δεν το υποστηρίζει
δε χρειάζεται να δώσεις τόσα - s5e και είσαι μια χαρά
και εγώ το φοβόμουν λόγω Samsung αλλά το ρίσκαρα και το έχω ευχαριστηθεί πάρα πολύ
16:10, μικρά bezels, πολύ ελαφρύ, εξαιρετική οθόνη, πολύ καλός ήχος, επεκτάσιμη μνήμη - βάζεις μια microsd φορτωμένη με ο,τι θες
για μένα προσωπικά δεν υπάρχει λόγος να πας σε ακριβό android tablet όπου εκεί έχεις άλλες απαιτήσεις και εκεί οπωσδήποτε ένα ipad pro κάνει σκόνη το s6
για οικονομική συσκευή media consumption όμως είναι η καλύτερη πρόταση και το λέω έχοντας κάνει τη σύγκριση με ipad 2018
το συγκεκριμένο ipad pro πάντως με το νέο πληκτρολόγιο είναι ο,τι πιο κοντά σε laptop replacement έχουμε δει μέχρι τώρα...
Εντυπώσεις από s5e στο κομμάτι ταχύτητας και απόκρισης?
Έχει πολλά lags?
Καλά ναι απλά θα ήθελα τη σβελταδα του 855 που είναι πιο future proof να αντέξει μια 3ετια άνετα, είχα δει το s5e από φίλο και μου άρεσε πάντως το form factor του.
Αλλά έχει κάνει κοτσάνα η Samsung δεν έβαλε theme engine στα tablet πραγματικά ακατανόητη απόφαση της πχ εμένα που μου αρέσει customization /personalization δεν γουστάρω Android OS με πινελιές ios και περιορισμους, άσε που ούτε καν Android 10 έχει πάρει, θα το πάρει καλοκαίρι όταν η Google θα έχει βγάλει την 11.
Τραγική η Samsung σε πολλά στα του λογισμικού
Sent from my MI MIX 3 using Tapatalk
Έχει πολλά lags?
Μια χαρά είναι και σε ταχύτητα και σε απόκριση, για lags δεν είναι Snapdragon 855 αλλά και πάλι είναι οκ. Σε αυτό το θέμα το mediapad m5 που είχα πριν ήταν καλύτερο. Αν χρησιμοποιείς fingerprint scanner όμως κάποιες στιγμές (τις περισσότερες) θα θέλεις να το πετάξεις από το παράθυρο, ναι, είναι τόσο άθλιος.
Καλά εδώ τους έχει αφήσει με security patch Δεκεμβρίου, το Android 10 περιμένει πολύ ακόμη
