[Επίσημο] MacBook Pro 14″ | 16″ with PROLED XDR @2026
airb
25 May 2008
16,636
Λιβαδειά
Nέο MacBook Pro με οθόνη PROLED XDR και λειτουργία αφής για πρώτη φορά σε Mac, ισχυρούς επεξεργαστές
M5 Pro/M5 Max, έως 128GB ενοποιημένης μνήμης, προηγμένες δυνατότητες AI και αυτονομία έως 24 ώρες.
  • 14.2-inch (3024 x 1986 pixels) / 16.2 (3472 x 2266 pixels) tandem OLED display at 254 pixels per inch, ProMotion technology for adaptive refresh rates from 10Hz to 120Hz, Up to 1,000 nits sustained (full-screen) brightness, 2000 nits peak brightness, 10,000,000:1 contrast ratio
  • Apple M5 Pro chip – 15-core CPU with 5 super cores and 10 performance cores, 16-core GPU, Hardware-accelerated ray tracing, 16-core Neural Engine, 307GB/s memory bandwidth / 18-core CPU with 6 super cores and 12 performance cores, 20-core GPU, Hardware-accelerated ray tracing, 16-core Neural Engine, 307GB/s memory bandwidth
  • Apple M5 Max chip – 18-core CPU with 6 super cores and 12 performance cores, 32-core / 40-core GPU, Hardware-accelerated ray tracing, 16-core Neural Engine, 460GB/s / 614GB/s memory bandwidth
  • 24GB / 36GB / 48GB unified memory (Configurable to 128GB (M5 Max with 16-core CPU)
  • 1TB / 2TB SSD (Configurable to: 4TB, 8TB, or 16TB SSD)
  • macOS
  • Backlit Magic Keyboard with Touch ID, Ambient light sensor, Force Touch trackpad for precise cursor control and pressure-sensing capabilities
  • Wi-Fi 67 802.11be, Bluetooth 6.0
  • 12MP Center Stage camera with support for Desk View, 1080p HD video recording, Advanced image signal processor with computational video
  • Studio‑quality three-mic array with high signal-to-noise ratio and directional beamforming, 3.5 mm headphone jack with advanced support for high-impedance headphones, High-fidelity six-speaker sound system with force-cancelling woofers, Wide stereo sound
  • Support for spatial audio when playing music or video with Dolby Atmos on built-in speakers, Spatial audio with dynamic head tracking when using AirPods (3rd generation), AirPods Pro, and AirPods Max
  • 3 x Thunderbolt 5 USB Type-C with support for Charging, DisplayPort, Thunderbolt 5 (up to 120 Gbps), USB 4 (up to 40 Gbps), SDXC card slot, HDMI 2.1 port, MagSafe 3 port
  • 14″ Dimensions: 15 x 310.8 x 216.3 mm (Height X Width X Depth); Weight: 1.38kg (M5 Pro) / 1.4kg (M5 Max)
  • 16″ Dimensions: 16 x 355.5 x 244.2 mm (Height X Width X Depth); Weight: 1.82kg (M5 Pro) / 1.84kg (M5 Max)
  • 14″ – 72.6-watt-hour lithium-polymer battery with up to 22 hours video streaming and up to 14 hours wireless web; 70W USB-C Power Adapter (included with M5 Pro with 16-core GPU) / 96W USB-C Power Adapter (included with M5 Pro with 20-core GPU), USB-C to MagSafe 3 Cable
  • 16″ – 100-watt-hour lithium-polymer battery with up to 24 (M5 Pro) / 22 (M5 Max) hours video streaming and up to 17 (M5 Pro) / 16 (M5 Max) hours wireless web; 140W USB-C Power Adapter, USB-C to MagSafe 3 Cable
New MacBook Pro with PROLED XDR Display and Touch: The world’s best laptop display
Apple
New MacBook Pro with PROLED XDR Display: The first-ever Mac with Touch
Apple​
Reactions: vadergr
Γιάμμυ.
Όχι για την touch που μου είμαι ψιλοαδιάφορη (ακόμα και στο iPad όταν το έχω στο keyboard folio με το trackpad δουλεύω), αλλά για την OLED και το Dynamic Island. Ήλπιζα να έχει και FaceID αλλά δεν πειράζει.
Πολλά τα λεφτά βέβαια, και ανεπίτρεπτο το 24 RAM στη μικρή έκδοση… που θέλει +$600 (!!!!) για να πάει στα 48.
14"
  • M5 Pro / 24 GB / 1 TB: 3.449€
  • M5 Pro / 48 GB / 1 TB: 4.349€
  • M5 Max / 36 GB / 2 TB: 5.349€
16"
  • M5 Pro / 24 GB / 1 TB: 4.049€
  • M5 Pro / 48 GB / 1 TB: 4.699€
  • M5 Max / 36 GB / 2 TB: 5.749€
[thelec.net]...Η Samsung Display (SDC) θα είναι ο αποκλειστικός προμηθευτής των πάνελ OLED για το πρώτο MacBook της Apple με δυνατότητα αφής...https://www.thelec.net/news/articleView.html?idxno=12616
Η Samsung Display θα κατασκευάσει τα πάνελ στη γραμμή παραγωγής OLED 8,6ης γενιάς (Gen 8.6) στο Asan, στην επαρχία South Chungcheong.
Τα πάνελ θα ενσωματώνουν τεχνολογία oxide TFT, αρχιτεκτονική OLED δύο επιπέδων (two-stack tandem) και τεχνολογία αφής ενσωματωμένη στο πάνελ (on-cell touch).
