[Επίσημο] MacBook Pro with M6 14" @2026
airb
25 May 2008
16,633
Λιβαδειά
  • 14.2-inch (3024×1964 pixels) / 16.2 (3456×2234 pixels) Liquid Retina XDR display at 254 pixels per inch, ProMotion technology for adaptive
    refresh rates up to 120Hz, Up to 1,000 nits sustained (full-screen) brightness, 1,600 nits peak brightness, 10,00,000:1 contrast ratio
  • Apple M6 chip – 12-core CPU with 2 super cores, 4 performance cores and 6 efficiency cores, 12-core GPU, Hardware-accelerated ray tracing,
    Dual 16-core Neural Engine, up to 170GB/s memory bandwidth
  • 16GB / 24GB / 32GB unified memory
  • 1TB / 2TB SSD (Configurable to: 4TB)
  • macOS
  • Backlit Magic Keyboard with Touch ID, Ambient light sensor, Force Touch trackpad for precise cursor control and pressure-sensing capabilities
  • Wi-Fi 7 802.11be, Bluetooth 6.0
  • 12MP Center Stage Camera with support for Desk View, 1080p HD video recording, Advanced image signal processor with computational video
  • Studio‑quality three-mic array with high signal-to-noise ratio and directional beamforming, 3.5 mm headphone jack with advanced support for
    high-impedance headphones, High-fidelity six-speaker sound system with force-cancelling woofers, Wide stereo sound
  • Support for Spatial Audio when playing music or video with Dolby Atmos on built-in speakers, Spatial audio with dynamic head tracking
    when using AirPods (3rd generation), AirPods Pro, and AirPods Max
  • 3x Thunderbolt, 5x USB 4 Type-C with support for Charging, DisplayPort, SDXC card slot, HDMI 2.1 port, MagSafe 3 port
  • Thunderbolt 5: Up to 40 Gbps / USB 4: Up to 40 Gbps
  • Dimensions: 155 x 312.6 x 221.2 mm
  • Weight: 1.55kg
  • 72.4-watt-hour lithium-polymer battery with up to 24 hours video streaming and up to 16 hours wireless web
  • 70W USB-C Power Adapter
The new 14” MacBook Pro with M6
Apple
The new MacBook Pro with M6 delivers blazing-fast performance and up to 24 hours of battery life
Apple​
