- 28 November 2011
- 3,109
Η νεα εντυπωσιακή πρόταση ναυαρχίδα της εταιρίας που αναμένεται εντός των επόμενων λίγων εβδομάδας και στην Ευρώπη αφου προηγούμενος ξεκίνησε την σταδιοδρομία της πριν ενα μήνα στις ΗΠΑ.
Εδω τα χαρακτηριστικά της συσκευής
Axon 7
-Display 5.5-inch AMOLED display
2560 x 1440 resolution, 538ppi
Gorilla Glass 4
-Processor:
Qualcomm Snapdragon 820 quad core 2.20GHz
GPU Adrenno 530
-RAM 4/6GB
-Storage 64/128GB
-Micro SD up to 128GB
-CamerasRear: 20MP Samsung ISOCELL sensor with sapphire lens, OIS, EIS, PDAF, f/1.8 aperture, dual LED flash
-Front: 8MP
-Dual SIM:Yes
-SIM type:Nano SIM
-SIM 2 also supports microSD card expansion
-USB Type USB Type-C
USB 3.0 version
-Connectivity
Bluetooth 4.2
NFC
Wi-Fi 802.11 b/g/n/ac 2.4 GHz/ 5 GHz
-NetworksGSM/EDGE:B2/3/5/8
CDMA BC0/1/10
UMTS/HSPA: B2/B5/B4/B1/B8
LTE: B2/B4/B5/B12/B13/B17/B7/B3/B1/B20/B29/B30/B25/B26/B41
2CA: B2+B4,B2/4+B12,B2/4+B29, B2/4+B5, B41+B41, B25+B25
-Fingerprint sensor: Yes
-SoftwareAndroid 6.0.1 Marshmallow with MiFavor UI 4.0
-Battery Non-removable 3.250mAh
Quick Charge 3.0
-Dimensions and weight 151.8 x 75 x 7.9 mm
185 grams
-Gold, Quartz Grey colors
PROS
-Remarkable dual front-facing stereo speakers
-Exemplary display
-Elegant design
-Exceptional performance
-Excellent battery life
-Awesome Hi-Fi audio
-Fingerprint reader is fast and accurate
-Very good camera overall
-Software is surprisingly good
-64 GB + expandable storage
-Works with all major U.S. carriers
-Passport 2.0 premium warranty is a wonderful addition
-Amazingly affordable
CONS
-Weak low-light camera performance
-Phone is slippery in the hand
-Certain areas in the software could use some more polish
Axon 7 wants to be your Samsung Galaxy S7 and iPhone 7 replacement
http://www.techradar.com/reviews/phones/mobile-phones/zte-axon-7-1322212/review
OUR VERDICT
ZTE Axon 7 is less expensive than the best flagship smartphones, yet it looks and performs like a top-tier Android Marshmallow handset, with front-facing speakers, 64GB of storage and only a few sacrifices.
FOR
Inexpensive, yet well designed
Generous 64GB of internal storage
Awesome dual front-facing speakers
AGAINST
Slippery in the hand
Not on all US carriers
Doesn't match Samsung's camera
Sent from my iPad Air 2
Axon 7
Gorilla Glass 4
-Processor:
GPU Adrenno 530
-RAM 4/6GB
-Storage 64/128GB
-Front: 8MP
-Dual SIM:Yes
-SIM type:Nano SIM
USB 3.0 version
-Connectivity
Bluetooth 4.2
NFC
CDMA BC0/1/10
Quick Charge 3.0
185 grams
PROS
-Exemplary display
-Elegant design
CONS
OUR VERDICT
FOR
AGAINST
