Extreme Tech: 360 DVD, HD DVD playback still seriously flawed
blizard
Banned
11 March 2007
1,001
"Early this year I wrote about how the Xbox 360 is a flawed DVD player, complete with pictures of some of the various errors you can expect. I hoped Microsoft would fix it with each major update. So when I looked over the really long and detailed list of Dashboard updates the other day, a few things stuck out at me. One is the nebulous "Improved deinterlacer support for video playback." Could this be the DVD fix I was hoping for?
Nope. I just updated the Xbox 360 in the lab and ran it into a TV using the VGA input at 1080p. With this I used the popular HQV DVD test disc, and the Xbox 360 scored a whopping 40. That's out of 130! Rather than show you the whole scoring chart, let me break it down for you: The 360 passed the Color Bars/Vertical Detail test (nearly everything does), the Picture Detail test, and the horizontal and vertical crawls. That's it. It failed every noise reduction, film mode, jaggies, and cadence detection test there is. In nearly every case, it was a clear failure; not…even…close.
Oh, the hi-def situation isn't much better. HQV makes a hi-def test disc for HD DVD and Blu-ray players, and the 360 scores a zero (out of 100). These tests are much simpler, involving simply de-interlacing 1080i content of both regular and film mode content, and noise reduction. It's like nothing is going on there at all. "
http://www.extremetech.com/article2/0,1697,2228134,00.asp
ΕΛΕΟΣΣΣΣ !!!!!!
Οχι άλλο κάρβουνο ! (εεεεε.... ποστ κατά του HD-DVD ήθελα να πώ)
ΑΑΑΑ !! Και για να μήν το ξεχάσω : Οταν κάνεις highlight κομμάτια απο το κείμενο, γράφε και οτι το highlight είναι δικό σου και δεν είναι του συγγραφέα του κειμένου ! Οχι τίποτε άλλο αλλα για να μη σε παρεξηγήσουν οι υπόλοιποι ως πολωμένο / πορωμένο ...
Φιλικά,
Φίλιππος
ΥΓ : Sony, PS3, Microsoft, XBox360, Blu ray, HD-DVD, όλα καλά είναι και ταυτόχρονα όλα για τον @@@@ είναι ... Το θέμα είναι to keep an open mind....
Δεν είναι κάτι ιδιαίτερο βρε φίλε ... πλέον όλοι έχουν παραδεχτεί ότι το 360 δεν ήταν καλό player, όπως ακριβώς έχουν παραδεχτεί και τα προβλήματα υπερθέρμανσης που είχε .
(δεν πέφτουν πλέον να σε φάνε τα xbot όταν ακούν τέτοιες αναφορές, χαλάρωσε)
ΥΓ
Μπήκε για ενημέρωση μπας και κανείς δεν το έχει καταλάβει, και με το hdmi συν τα updates περιμένει αποτελέσματα ανάλογα των Toshiba player ή του ps3
Μια παρατήρηση από εμένα: τα αποτελέσματα του HQV HD έχουν πολύ περιορισμένη χρησιμότητα, μιας και αναφέρονται σε υλικό HD το οποίο είναι interlaced. Όλοι ξέρουμε ότι είναι ελάχιστοι οι τίτλοι σε HD DVD οι οποίοι είναι 1080i, και σχεδόν κανένας από αυτούς δεν είναι τίτλος ταινίας.
Επίσης, τα Xbox 360 & PS3 είναι παιχνιδομηχανές, και ως τέτοιες πρέπει να αντιμετωπίζονται. Το ότι παίζουν DVDs / HD DVDs και DVDs / BDs αντίστοιχα δεν σημαίνει κάτι. Δεν διεκδικούν τον τίτλο των κορυφαίων players (καλά, το PS3 μπορεί άθελά του να τον διεκδικεί για BDs..).
Και πια από τις δυο παιχνιδομηχανές θεωρείται καλύτερη από το κοινό δεν είναι μυστικό.. ;)
Αν οι κονσόλες είναι μόνο για παιχνίδια όπως λες , δεν θα είχε βγει καν το HD-DVD add on... υπάρχει κόσμος που ενδιαφέρεται ακόμα και για το upscale απλού dvd, και σε αυτούς απευθύνεται το άρθρο.
ΥΓ
Η συζήτηση γενικά για κονσόλες δεν ταιριάζει εδώ, αλλά οι περισσότεροι ξέρουν ποια έχει το καλύτερο value , έχει βγάλει παιχνιδάρες τελευταία και θα συνεχίσει.
Σαν παιχνιδομηχανή το 360 θεωρείται γενικώς ανώτερο, αλλά να το βάλεις να παίξει DVD ή HD-DVD για high - quality εμπειρία το θεωρώ γελοίο (που δεν είμαι και ιδιότροπος) αφού το μηχανάκι κάνει σαν ηλεκτική σκούπα! Απευθύνεται σε μικρότερες ηλικίες που δεν τα ενοχλεί η βαβούρα.
Ιδίως για τους φανατικούς βιντεόφιλους του forum, δεν τίθεται θέμα.
εντάξει ρε παιδιά είπαμε, κι εγώ είχα πάρει από τους πρώτους το HDDVD drive του 360 αλλά για πλάκα.... :flipout: έτσι για να λέω ότι έχω και καλά hddvd player μέχρι να βγει κανά σοβαρό combo.
Τι συγκρίνετε τώρα;...
Re: Απάντηση: Extreme Tech: 360 DVD, HD DVD playback still seriously flawed
:SFGSFGSF::music-smiley-005::Banane0::aktion033:
ΣΩΣΤΟΣ!!:music-smiley-005:
Ετσι οντως ειναι, οπως τα λεει ο blizard και ο Τασος. Το 360 ειναι κακο οσον αφορα τις ταινιες.
Αλλα απο την αλλη, το ps3 ειναι κακο σε παιχνιδια........................
Παιρνεις και τα δυο, και εισαι ησυχος.
