Φακοί Cine PL - EF - E - RF -Z -L mount
The lens weighs in at 8.25kg / 18.2 lbs, and it is 41cm / 16.14″ long. It has a minimum focusing distance of 4.3′ / 131cm.
It will cover a 60mm image diameter, and it is claimed to have very minimal focus breathing and well-controlled distortion.
The retail price for the INESPEED65 37-156mm T3.6 Cinezoom is $43,800 USD. KIPON has already started to accept orders, and the lens is ready for shipping.
Specifications at a glance​
  • Formats: full frame, constant 2x squeeze; T4.5–T22
  • Focal lengths: 40-80mm, 70-135mm
  • Optics: 23 elements in 15 groups (40-80); 22 elements in 14 groups (70-135)
  • Focus throw: 305° (40-80); 302° (70-135)
  • Zoom throw / iris throw: 100° / 32.7°
  • Min focus: 0.61 m (40-80); 0.78 m (70-135)
  • Front diameter / filter: 105 mm / 77 mm
  • Weight: ~2.8 kg (40-80); ~2.6 kg (70-135)
  • Flare options: blue, amber, silver, clear
  • Mounts: PL standard; optional RF, E, Z, L bayonets; no EF optionThese specifications are taken from the official press materials.
Κey features​
  • Maintains Focus Throughout Zoom Range
  • Natural Color Rendering
  • Consistent T2.9 to T22 Aperture
  • Covers Full-Frame Sensors
  • 16-Blade Iris for Soft Bokeh
  • 29.1″ Minimum Focus Distance
  • Comes with E-Mount, Interchangeable
  • 270° Focus Rotation
  • M77 Filter Diameter, 2.3x Magnification
  • 80mm Front Diameter
The Catta 35-80mm T2.9 E-Mount Cine Zoom Lens is designed to maintain focus as you smoothly zoom in or out. The Catta line reproduces accurate color and features a smooth focus/defocus transition. It features a wide T2.9 to T22 aperture, a 16-blade iris for a smooth bokeh, and a long 29.1″ close focus range.
True to its cine design, it has a focus rotation of 270°, a 100° zoom rotation range, and a 75° iris rotation range. The lens features a Sony E-mount, and it can be easily interchanged with optional RF, L, X, and Z mounts. Multiple accessories are included with the lens, including front and rear lens caps, a shim set, a support base, a support rod, and a f
6000$ το σετ των 5 φακων.
