GearBest gadgets offers
Gearbest
7 February 2017
1,601
Xiaomi mijia Car DVR Camera black
Flash Sale Price 62.06
Specification
General Brand: Xiaomi
Model: mijia
Type: HD Car DVR Recorder,Wireless Dashcam
Image Sensor: CMOS
Storage Max External Card Supported: TF 64G (not included)
Display Screen size: 3.0inch
Primary Info. Aperture Range : F1.8
Video/Image/Audio Decode Format: H.264
Video Resolution: 1080P (1920 x 1080)
Audio System: Built-in microphone/speacker (AAC)
Functions WIFI: Yes
WiFi Function: Image Transmission
Loop-cycle Recording : Yes
G-sensor: Yes
Auto-Power On : Yes
Parking Monitoring: Yes
Original Xiaomi xiaofang Smart 1080P WiFi IP Camera - WHITE
1/2.7 inch CMOS Sensor Night Vision IR-cut Motion Detection 110 Degree FOV 8X Digital Zoom
Flash Sale Price 22.81
General
Brand: Xiaomi
Shape: Mini Camera
Color: White
Technical Feature: Infrared
IP camera performance: Motion Detection,Night Vision,Real-time video capture and recording
Motion Detection Distance: 9m
Compatible Operation Systems: Android,IOS
Power
Specification of Power Supply: DC 5V 1A
Working Voltage: DC 5V
Network
Wireless: WiFi 802.11 b/g/n
WiFi Distance : 10m
System and Hardware Info
Mobile Access: Android,IOS
Alarm Notice: Email Photo
Local-storage: Micro SD card up to 64GB
Language: English
Maximum Monitoring Range: 9m
FOV: 110 degrees
Video Image Audio
Sensor: CMOS
Sensor size (inch): 1/2.7
Resolution: 1920 × 1080
Audio Input: Built-in mic.
Audio Output: Built-in speaker
Night Vision
Infrared LED: 2pcs
Infrared Distance: 9m
Physical Environment
Environment: Indoor
Waterproof: No
Operate Temperature (℃): 0 - 40 centigrade
Working Humidity (%) RH: 90 pct
GS63H Car 4K DVR Camera - BLACK
Flash Sale Price 63.89
Adopted Novatek NT96660 chip and OV4689 pro 1/3 inch COMS image sensor, features with 4K FHD recording, brings you clear and high quality videos; and has a variety of functions, such as WiFi connection, GPS navigation, loop-cycle recording, motion detection, auto power on, and so on, provides you a more comfortable and worry-free driving environment.
Main Features:
● 2.4 inch LCD screen 4K FHD car camera
● 150 degree wide angle and F1.8 aperture
● Adopting Novatek NT96660 chip, and OV4689 pro 1/3 inch COMS image sensor
● WiFi connection allows you to operate the camera conveniently
● GPS navigation offers you accurate position
● Gravity sensor keeps the video not covered in case of an emergency
● Loop-cycle recording, saves the storage space efficiently
● WDR wide dynamic technology, records more clear even under low-light environment
● Support 5 - 10m motion detection distance
● Auto power on and delay shutdown, no need to operate it by your hands
● Time stamp is conducive to look through
● Support HDMI full HD video transmission
● Advanced H.264 photography compression technology keeps high quality videos and plays a part of saving storage as well
● Support maximum 128GB TF card memory storage ( not included )
● Built in 250mAh Li-polymer battery
Quelima SQ11 Mini Camera 1080P HD DVR - BLACK
14.62
General
Brand: Quelima
Model: SQ11
Type: Mini DVR
Chipset: Generalplus1248
System requirements: Mac OS x 10.3.6 above,Win 7,Win 8,Windows 2000 / XP / Vista
Image Sensor: CMOS
Storage
Max External Card Supported: TF 32G (not included)
Power
Battery Capacity (mAh): 200mAh
Charge way: USB charge by PC
Working Time: about 100mins
Battery Charging Time: 2 - 3 hours
Working Voltage: 5V
Primary Info.
Wide Angle: 120 degree wide angle
Lens Size: 3.6mm
Camera Pixel : 1.2MP
Aperture Range : f2.0
ISO: ISO100
Video/Image/Audio
Video format: AVI
Video Resolution: 1080P (1920 x 1080),720P (1080 x 720)
Video System: NTSC
Video Frame Rate: 30fps
Video Output : AV-Out
Image Format : JPEG
Image resolution: 12M (4032 x 3024)
Audio System: Monophony
White Balance Mode: Auto
Functions
Waterproof: No
Waterproof Rating : 0
Loop-cycle Recording Time: 5min
Motion Detection: Yes
Motion Detection Distance: 5 - 10m
Night vision : Yes
Night Vision Distance: 15m
GPS: No
Time Stamp: Yes
Anti-shake: No
Parking Monitoring: No
Other
Operating Temp.: -10 - 50 Deg.C
Power Cable Length: 80cm
Ourtime X200 3G Smartwatch Phone - BLACK
Flash Sale Price 82.15
Brand: Ourtime
Type: Watch Phone
OS: Android 5.1
CPU: MTK6580
Cores: 1.3GHz,Quad Core
RAM: 512MB
ROM: 8GB
External Memory: Not Supported
Compatible OS: Android
Network
Wireless Connectivity: 3G,Bluetooth 4.0,GPS,GSM,WiFi
Network type: GSM+WCDMA
Frequency: GSM 850/900/1800/1900MHz WCDMA 850/2100MHz
Bluetooth Version: V4.0
Display
Screen type: Capacitive
Screen size: 1.39 inch
IPS: Yes
Camera
Camera type: Single camera
Front camera: 2.0MP
Connectivity
SIM Card Slot: Single SIM
TF card slot: No
Speaker: Supported
Media Formats
Picture format: BMP,GIF,JPEG,PNG
Music format: MP3,OGG,WAV
Video format: 3GP,AVI,FLV,MKV,MP4
Languages
Languages: English, Indonesian, German, Spanish, French, Italian, Polish, Portuguese, Vietnamese, Turkish, Russian, Hebrew, Arabic, Persian, Hindi, Bengali, Thai, Burmese, Korean, Japanese, Simplified/Traditional Chinese
Additional Features
Additional Features: 2G,3G,Alarm,Bluetooth,Browser,Calendar,GPS,MP3,Not ification,People,Sound Recorder,Wi-Fi
Functions: Heart rate measurement,Message,Pedometer
Original Xiaomi Mi IV Hybrid Dual Drivers Earphones - SILVER
Flash Sale Price $16.29
Product Details
Headset type: Dynamic
Connectivity: Wired
Connecting interface: 3.5mm
Application: Computer,DJ,Mobile phone,Portable Media Player
Plug Type: Full-sized
Frequency response: 20~20KHz
Impedance: 32ohms
3D Printer DIY Kit - EU PLUG BLACK
Flash Sale Price $135.99
Supports SD card or off-line print, specially convenient when without computer.
● 140 x 120 x 130mm printing area, just right for you.
● LCD screen shows your printing information directly and easy for you to manipulate.
● 0.1 - 0.3mm layer resolution accelerates the design process.
● Supports multiple 3D printing filament: ABS / PLA / wood / nylon PVA / PP / luminescent.
● All metal pulleys for improving functionality and performance.
● Quick-release feed gears for faster and more fluent filament feeding.
● Operating system: Windows XP / Mac / Linux.
● Designed to provide redefined usability, quality and performance.
● Made from piano-black laser-cut acrylic frame to maintain the garage-built feel and the handmade charm.
● Suitable for a wide range of customers, young or old, professional or amateur etc..
● High printing precision, stainless steel rail rods, gears, bearings and connectors for smoother movement.
● It is unassembled DIY kit, which provides you an unforgettable step-by-step learning experience of 3D printer from scratch. As long as you have a passion for creativity, you can not afford to miss this product.
Elephone EleCam Explorer Elite 4K Action Camera - BLACK
Discount : 19% OFF
$69.48
Upgrade Chipset NTK96660: NTK96660 chipset with fully improved performance, enables you conveniently record 4K video and capture high-speed motion scenes
Support WiFi Connection: Operation via APP to make remote control and easily preview and share videos with people
Wiredrawing Texture: Glossy and delicate wiredrawing texture bring you an excellent feeling
Underwater Mode Fill-in Light: Light effect will be improved by 15 to 30 percent, enables you to take better pictures
Good Image Permeability: 12MP for fine capturing dynamic, 4K video recording and image freeze-frame at 60fps brings you clear and vivid quality
170 Degrees FOV: Wide angle ensures excellent vision and retains more realistic scene, captures immersive view
Built-in Gyro: Electronic image stabilization will greatly reduce camera shake and vibration in order to get the perfect shot
Special Slow Photograph Function: New photography modes of night and time-lapse at night provide customizable exposure settings for single and time-lapse photo
Waterproof Case: Strong protective box with waterproof performance 98 feets (30m) is used for Explorer
APP Control: Scan the QR code to download APP "Explorer Elite", for both iOS and Android system
Built-in a battery
Suitable memory card: above class 6
Original Xiaomi ROIDMI Car Bluetooth Charger Adapter - BLACK
Flash Sale Price $9.69
Original Xiaomi ROIDMI 5V / 3.1A car charger adapter
3.1A total large output current for fast charging
FM transmitter and car charger
Short-circuit protection
Input: 12 - 24V, 0 - 2.4A
Output: 5V 2.1A, 5V 1A
Output power: 15.5W
FM: 87.5 - 108MHz
Bluetooth: V4.0 or above
Original Xiaomi Mi Band 2 Smart Watch for Android iOS - BLACK
Flash Sale Price $21.99
- Bluetooth Synchronization
With Bluetooth 4.0, this smart watch is available for smartphones with Bluetooth functions.
- OLED Touch Screen
Just touch the circular button gently, the OLED screen will display current time, steps, heart rate, distances, calories, etc.
- Heart Rate Monitor
It can dynamic-static monitor your heart rate, provide data for you at any time.
- Incoming Calls / APP Message Alert
When someone calls or sends any messages in your phone, the watch will remind you via vibrating, so you will never miss them!
- Sleeping Monitoring
Accurately monitor total effective sleeping time and motions time every night, also APP will give you periodical evaluation, help you develop good living habits.
- Sport Monitoring
This smart watch can record steps, calories and distance. Let you know your sports data, adjust your exercise program and get a healthier life!
- Intelligent Alarm Function
Wake you up every morning, will not be late for work; idle alert to remind you with vibration, stretch your legs after working for a long time.
- No Passcodes Required
Every Mi Band 2 have an exclusive ID, when your smartphone closes with the band, your phone will be unlocked, just identify yourself with Mi Band 2.
- IP67 Waterproof
The IP67 waterproof allows the bracelet to be held in the water for a maximum of 30 minutes at a depth of 1 meter. ( Don't wear the bracelet when diving )
- Full Compatibility
Support Android 4.4 or above and iOS 8.0 or above with Bluetooth 4.0.
- Download APP
You can search the name "MI FIT" in the "App Store" or "Google Play" to download the APP combined with Mi Band 2 to enjoy happy sports time.
Original Xiaomi Wireless Bluetooth 4.0 Speaker - WHITE
Flash Sale Price $18.99
Mini portable wirless bluetooth speaker with square box design
USB cable for Andriod can be the charging source for the stereo speaker
Built-in 1200mAh Li-battery, support for 10 hours playing
Durable structure with ABS surface and aluminum alloy side box
Support bluetooth 4.0 protocol, good compatibility
M88 Smart Band Android iOS Compatible - BLACK
Flash Sale Price $16.99
Perfect Personal Health Tracker: blood pressure monitor, heart rate monitor, pedometer, distance, calories and sleeping monitors.
Ultra-long Battery Life and USB Rechargeable: it consumes less power and can generally last for 5 days. You can see the battery indicator on the screen. It is USB rechargeable and you can charge it on any devices using the USB charger.
Waterproof Design: IP67waterproof standard, suitable to use at home, office and during outdoor activities.
High-quality Materials: PC case and TPU band for long use.
Compatible: fits most Android and iOS phones.
XDUOO X10 HD Lossless Music MP3 Player - BLACK
119.99$ with coupon: X10HDS
- 2.0 inch colorful HD display
- Support 2pcs micro SD card up to 128G separately, the total storage is 256G
- Support DSD / WAV / APE / FLAC / ACC / MP3 lossless format
- CNC aluminum alloy material shell, using sandblasting and dense oxide technology, which has sweat-proof, wear-resistant, anti-fingerprint functions
- With PO / LO / OPT and other output modes
- Support the master copy 24Bit / 192Khz HD sampling rate
Specification:
Screen: 2.0 inch TFT LCD
Screen resolution: 240 x 320
Image format: JPEG
Battery: 2400mAh Li-ion battery
Working time: 10h
Standby time: automatically off
Charging time: 12h
Interface: micro
Language: Simplified Chinese, Traditional Chinese, English, Japanese, Korean, French, Germany, Polish, Russian, Thai, Spanish, Indonesian
Memory play: yes
Waterproof: no
Flash Sale Price $13.99
120 degree FOV provides you wide view
● Night vision supports capturing high definition pictures during night or dark environment
● One key to lock the video in case of emergent situation
● Support maximum 32GB TF card memory storage ( not included )
● Built in 200mAh Li-ion battery
Tronxy X5 Aluminum Profile 210 x 210 x 280mm 3D Printer - US PLUG BLACK
$ 269,99 with coupon TronxyX5
Main Features:
● Extremely simple assembly, more stable performance
● Support SD card off-line function
● Stronger frame construction: aluminum profile ensure stable prints
● Durable metal extruder: upgraded to metal parts, equipped with high torque stepper motor, stable rotating speed and uniform extrusion force, feeding filament smoother
