iFI xCAN - έφτασε Ελλάδα!
Γιώργος ΚΟΨ
20 June 2006
3,372
GLYFADA
Το νέο βραβευμένο iFi Audio xCAN με την τελευταία τεχνολογία της X της IFi και Bluetooth έφτασε και στην χώρα μας!
https://ifi-audio.com/products/xcan/
Xtra connection.
Delivering high quality Bluetooth connectivity, and capable of storing up to eight wireless devices at once, the xCAN enables you to stream your favourite music from:
iTunes
Spotify
Apple Music
Tidal
As well as listen to your favourite artists, box sets and movies on your smartphone, portable audio device, laptop, and TV.
Add to that a 1000mW of power per channel and dual mono amplifier and your are rocking!
Χαρακτηριστικά:
Inputs Wireless ESS Sabre 44.1/48k 16-Bit (AAC, aptX, aptX LL and SBC)
Wired 3.5mm (TRS or TRRS S-Balanced*) and 2.5mm (TRRS)
*ONLY found in iFi components such as nDSD BL. Do NOT feed using normal TRRS Balanced output sources.
No USB audio input
Max Output S-Balanced > 3.8V / 45 mW (@ 300 Ohm)
> 3.5V / 380 mW (@ 32 Ohm)
> 3.1V / 600 mW (@ 16 Ohm
Balanced > 7.6V / 90 mW (@ 600 Ohm)
> 7.2V / 800 mW (@ 64 Ohm)
> 5.7V / 1,000 mW (@ 32 Ohm)
THD & N S-Balanced < 0.005% (@ 100 mW/1.26V 16 Ohm)
Balanced < 0.006% (@ 360 mW/2.4V 16 Ohm)
SNR S-Balanced > 121dBA (@ 3.8V)
Balanced >120dBA (@ 7.6V)
Recommended HP Impedance 16~600 Ohm
Max. Input S-Balanced 3V RMS
Balanced 6V RMS
Gain -95dB to +18dB adjustable in 114 1dB steps (using volume control)
Frequency Response < 2Hz – > 200kHz (-3dB)
Playback Time > 8 hours (charging via USB port)
Dimensions 95 (l) x67 (w) x19 (h) mm
Weight 127g (0.28 Ibs)
Βρείτε το στο δίκτυο συνεργαζόμενων ifi audio stores σε ολη την Ελλάδα με την εκτεταμένη εγγύηση της Audio Soul Ultra
