καινουργιοι catalyst...!!!!
Re: Τι σας έχω!???
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include:
* 3DMark03-GT3: Display corruption is no longer noticed when running the application on a system using an ATI Radeon X1650 product. Further details can be found in topic number 737-27069
* Call of Duty: Setting AA to either 2 or 4x no longer results in display corruption or the Vista operating system failing to respond when using an ATI Radeon X800/850 series of product. Further details can be found in topic number 737-25523
* Dungeon Lord: Minor and intermittent display corruption is no longer noticed when playing the game with CrossFire™ enabled. Further details can be found in topic number 737-27070
* Prey: Using the mouse to maneuver around the game screen no longer results in corruption being noticed. Further details can be found in topic number 737-27077
* Tribal Trouble: Launching the game on a system containing an ATI Radeon X1900/1950 product and running Windows XP no longer results in the game failing to load and the operating system failing to respond. Further details can be found in topic number 737-27076
* Choppy playback of media previews and captured files is no longer noticed in the media center and movie maker after applying WMP 11 update. This issue may also be experienced under the Windows Vista operating system. Further details can be found in topic number 737-25807
* A Microsoft .NET Framework error no longer appears when switching between user accounts and or toggling between Catalyst™ Control Center skins. Further details can be found in topic number 737-26746
* Making changes to the 3D-All Setting aspect no longer results in the SmoothVision slider and labels failing to be redrawn properly. Further details can be found in topic number 737-26747
* The response time for the Catalyst™ Control Center no longer appears slow when attempting to make changes to the display devices when having both a CRT and HDTV connected and extended desktop mode enabled. This issue may also be experienced under the Windows Vista operating system. Further details can be found in topic number 737-25806
* Catalyst™ Control Center->3D: Setting AA to 4x and attempting to read a PDF using Adobe PDF Reader version 8.0 no longer results in corruption being noticed when setting the reader preferences to Page Display found within the Categories options. Further details can be found in topic number 737-27068
* Desktop brightness is now restored on the secondary display device after a full screen OpenGL game exits. Further details can be found in topic number 737-27071
* Momentary display corruption is no longer noticed when changing the color depth on a system running Windows XP and containing an ATI Radeon X1800 series product. Further details can be found in topic number 737-27075
Τους εβαλα χθες και μπήκαν νερό όλα (σπάνιο να μην εχω ουτε ενα θεματακι με ccc ή κατι) δεν είδα προβλημα αλλα και τιποτα τρομερό εκτος απο μια αλλαγη στο ccc μικρης σημασιας (δεν θυμαμαι καν τι ήταν) Πιθανον να φτιάχνουν κατι, γιατι οταν χαλάνε (7.3) δεν το αναφέρουν.....
περναω netframe και μετα το "πακετακι" των 28mb της ΑΤΙ ή πρωτα τους "μαμα" και μετα update απο πανω???
Re: Απάντηση: καινουργιοι catalyst...!!!!
Για δες ρε μαστορα αν εφτιαξε το brightness/contrast μην κανω παλι φορματ...
Το μεσημεράκι νωρίς που παω σπιτι θα δω και θα γράψω (ο βλακας δεν το κοιταξα....)
Εγω παντως που τους εβαλα χτες το βραδυ, μου ξεσκισαν το συστημα!!!
Αργουσε να μπει στο control panel, kai οσον αφορα το brightness - contrast, αλλου γι αλλου !
Δεν ερχοταν με τιποτα στα σωστα του ... Πολυ λαθος οι αρχικες ρυθμισεις που δεν μπορουσα με τιποτα να τις ξαναφερω , οσο και αν προσπαθησα.
Τους απεγκατεστησα και ξανα στου παλιους καλους 7,2.
Δεν μιλαω μονο για λιγο καψιμο στα ψηλα και στα χαμηλα, αλλα για απουσια σχεδον ολων των διαβαθμισεων (ψηλα και χαμηλα).
Στην ουσια ηθελε ξανα σεταρισμα ο προβολεας .
H πλακα ειναι οτι στο δευτερο pc Που εχω εκτος του Htpc , με dual xeon, 2 gb ram, ati 9800 pro kai winxp pro +sp2, οι νεοι drivers δεν εχουν αυτο το προβλημα !
Ti sto καλο συμβαινει ?
Δε με λετε . Ολοι sapphire 1950 εχετε ?
Καταλαβαίνω το σκεπτικό σου, γιαυτό θα τους δοκιμάσω και εγώ το βράδυ στην Gigabyte X1650 μου να δούμε αν κάνει τα ίδια.
Απάντηση: Re: Απάντηση: καινουργιοι catalyst...!!!!
Για δες βρε Δημητρη, Η συγκεκριμενει κοντευει να γινει απο προταση , προταση προς αποφυγη....:chinscratch:
