LAB12: Dac 1 SE
Gojakla
20 May 2009
5,856
DAC1 Special Edition
Non Oversampling DAC with Tube Output
Official Site
OVERVIEW
A DAC that sounds like vinyl!
We are analog sound lovers, this is a true, but nowadays digital signals flow in every modern audio system.
The challenge was to achieve sound as closer to the vinyl sound through a DAC.
By combining digital and asynchronous USB inputs with classic non oversampling TDA1543 and a tube based output stage
we managed to achieve a really musical DAC that sounds like a perfect tuned High End turntable.
Every component of DAC1 is designed to provide smooth and pleasant sound.
We achieved the character of pure analogue sound with non oversampling conversion by 8 matched parallel Phillips TDA1543
in sophisticated configuration and smooth output through Dual triode tube I/V stage.
All components are carefully chosen after hours of listening and testing, while great attention
has been paid to all the details that affect the final outcome (special audiophile power capacitors, NOS tube and more).
DAC will be a pleasure not only for your ears but for your eyes too. With its solid construction,
handcrafted finishing, luxury metal painting and retro analogue V/U meters you will fall in love with it for sure.
FEATURES
Asychronous 24/96kHz usb input
Non Oversampling mode (matched)
Triode tube I/V analog output stage (New Old Stock SQ tube)
6 Separate Regulated Power Supplies
Handcrafted audio grade transformers
Dale 1% (digital stage) and AB carbon Resistors (analog stage)
High Capacity Audiophile capacitors (Nichicon gold tune)
Jantzen Superior-Z coupling capacitors
WIMA dacs' bypass capacitors
Vibration isolated chassis
Gold plated RCA Teflon (input, output)
Analog retro nissei VU meters
5mm Aluminum face panel with luxury painting
Five Years Guarantee
SPECIFICATIONS
Power
230/240 Vac 50Hz (1Α fused)
Power consumption
80 VA max
Inputs
1xSPDIF (Coaxial RCA)
1xUSB2
(Optional Toshlink input)
Frequency response
20Hz to 20 KHz +0dB/-1dB
Output level
2.25Vrms
THD
lower than 0.2%
Available colors
Etna Black
Pearl White
Custom color
Dimension (WxHxD)
43x11x29 cm
Weight
6 Kg
AVMentor Μετρήσεις
GALLERY
--> Full AVMentor Review
--> Mono&Stereo Review
Τιμή: 1499
καλά πλάκα μας κάνουνε?
1500 γιούργια?
ούτε εξ ελ αρ, ούτε οθονίτσα μπροστά να βλέπουμε τι παίζει, 24/96????? 24/96?????
ΕΛΕΟΣ!
Ούτε ένα 500ρικο δεν αξίζει.
Και τι'είν'ετούτα τα βούμετρα? που είμαστε? στο 1922?
τσκ τσκ τσκ
:grinning-smiley-043
...και τελος πάντων όταν λέμε ότι "σαουντς λαηκ βινυλ" τι εννοούμε?
σαν clearaudio? σαν linn? σαν Kuzma? σαν τι βινυλ? πετάμε ένα βινυλ και τελειώσαμε????
ΥΓ:παίδες τώρα είδα ότι είναι ελληνικό! Κι άλλο ελληνικό dac? έχω μείνει πίσω! μπράβο ωρε!
ΥΓ2:δεν υπάρχει κάπου ένα θρέντιον που να παρουσιάζονται οι ελληνικές κατασκευαστικές επιχειρήσεις προϊόντων ήχου???
Καλά ρε Στέργιε, σοβαρολογούσες? Δε ντρέπεσαι? :)
Η εταιρία αυτή είναι πολύ τίμια, αξιολογότατη και χαμηλού προφίλ.
Ποιος μου έσβησε ποστ?
Και καλα κανεις,θα ήταν επίσης off.
Σε δυο συνεχόμενα νήματα την ίδια μέρα...είπαμε...
Το αντίστοιχο Ayazi σαφώς ομορφότερο[υποκειμενικό] και οικονομικότερο
Η μή ύπαρξη ενισχυτή ακουστικών είναι μικρότερη έλλειψη καθώς απουσιάζει η ισορροπημένη έξοδος πού το θεωρώ σοβαρότερο .
Το πώς παίζει άγνωστο φυσικά ,για μένα
ΟΚ, όλα καλά και όλα ωραία με την άποψη του "αναλογικού" ήχου που προσεγγίζει το βινύλιο κτλ κτλ (κοινώς, περί ορέξεως.... σε πολλούς αρέσει το rolloff στα ψηλά και η αυξημένη αρμονική παραμόρφωση, παρέα με το ανύπαρκτο jitter rejection κτλ κτλ) αλλά ρε παιδιά, αυτό το Αγγλικό κείμενο δεν μπορούσατε να το περάσετε από κάποιον που ξέρει καλά Αγγλικά πριν το βγάλετε; Άντε μετά να μας πάρουν στα σοβαρά στις αγγλόφωνες χώρες..
Τώρα το είδα Δημήτρη. Προβληματικό το κείμενο για παρουσίαση ιστοσελίδας.
Ελπίζω οι κατασκευαστές να το βελτιώσουν.
οι κινέζοι που έχουν χειρότερα γιατί πάνε μπροστά?
Για αρχή, δεν πηγαίνουν όλοι μπροστά.. Αυτοί που πηγαίνουν το κάνουν έχοντας τιμή μικρότερη από το 1/2 του συγκεκριμένου και ευκολίες και επιδόσεις άλλου πλανήτη. Με αυτές τις προϋποθέσεις απ' ότι φαίνεται συγχωρούνται τα κινεζοαγγλικά..
Όταν στοχεύεις σε μια αγορά μη-τεχνοκρατική (όπως το συγκεκριμένο), το "πως" το πουλάς του μηχάνημα παίζει τον μεγαλύτερο ρόλο. Η επικοινωνία γίνεται κρίσιμος παράγοντας.
πάντως αυτοί είναι made in Europe....
Αρα δικαιολογείται το 500άρι overhead
Και ναι και όχι.. Και οι Κινέζοι βγάζουν λεφτά από τα δικά τους.. και όχι λίγα.. Και οι Κινέζοι έχουν και ένα σεβαστό κόστος R&D σε νέες τεχνολογίες (FPGAs με χιλιάδες γραμμές κώδικα στις σοβαρές υλοποιήσεις..).
Kαι ναί και όχι. Το ντάκ αυτό είναι να το πούμε ..ειδικών αποστολών... Κάποιοι μμουσικόφιλοι αρέσκονται να ακούνε την μουσική τους με μια κάπως πιό ρετρό αναπαραγωγή. Όχι ρετρό με την κακή ένοια αφου η επιρρόή της λάμπας στον ήχο άσχετο αν είναι σωστή ή λάθος πάντα είναι ευχάριστη..
Οκ προφανώς και το ντάκ πάσχει σε σχέση με άλλα μοντέρνα όσον αφορά τα specs αλλα τουλάχιστον εδώ ο κατασκευαστής είναι ειλικρινής ως προς το τί προσφέρει και εν γνώσει του απευθύνεται σε ειδικό κοινό χωρίς να προσπαθεί να παινέψει το ντάκ του λέγοντας οτι κάνει πράγματα που ουσιαστικά δεν τα κάνει πουλώντας "νερό καματερού"..
Παρότι δεν είμαι καθόλου φάν αυτής της λογικής νομιζω οτι το συγκεκριμένο είναι καλό σε αυτό που κάνει (ναι έχω ακούσει και βρήκα πολύ διασκεδαστικό το αποτέλεσμα) και επειδή ακριβώς κάνει σαφείς τις επιδόσεις του βοηθώντας τους υποψήφιους αγοραστές το βρίσκω τίμιο σαν προσέγγιση.
Τώρα όσον αφορά την τιμή σίγουρα θα μπορούσε να ήταν χαμηλότερη.
