Media Player iplay HD3
Το δικό μου μάλλον το έκαψα. Έκανα την αναβάθμιση αλλά δεν εμφάνιζε το μενού. έμενε σε μαύρη οθόνη. Τώρα πλέον δεν ανταποκρίνεται ούτε σαν σκληρός. Έχει κανένας καμία ιδέα πως να τον επαναφέρουμε?
Εχω το ιδιο θεμα. Εχει κανεις λύση?
Στη σελίδα τους γράφουν τα παρακάτω που ίσως φανουν χρήσιμα :)
Video output is distorted, black/white, or blank with no signal on the Slim-HD
Quick Answer:
The Micca Slim-HD is likely not set to the correct output mode. To change the output modes using the Micca Slim-HD remote, press the [AV] button if the analog composite AV connection is used, or the [HDMI] button if the HDMI connection is used. Wait 3-4 seconds to give your TV time to adjust. For optimal HDMI settings, go into the Settings menu and adjust the display output mode to match your TV's resolution.
Detailed Answer:
If there is no image on the TV/HDTV or if the image is distorted or in black and white, perform the following checks in the order given:
Double check all AV connections to make sure that the cables are securely connected
Make sure that the TV is set to the correct input and input mode
Make sure that the media player is on so that the Power indicator is illuminated. If not, press the Power button on the front of the player to turn the player on.
Press the [AV] button on the remote control if the composite AV connection is used.
Press the [HDMI] button on the remote control if the HDMI connection is used.
The above steps will set the media player's display output mode back to the default of NTSC for AV connection or 480p for HDMI connection.
Once an image is visible on the TV/HDTV, go into the Settings menu and set the Display output mode for optimal results:
For Composite/CVBS Connection – Set the Display output mode to NTSC
For HDMI Connection – Set the Display output mode to the maximum resolution supported by the HDTV. For example, if the HDTV supports to 1080p(60fps), set the Display output mode to 1080p(60fps). If the HDTV supports up to 720p(60fps), set the Display output mode to 720p(60fps). Consult the HDTV’s user’s manual for the maximum input resolution it supports.
During playback of a movie, press the [16:9/4:3] button on the remote to change the playback aspect ratio. Select one that best fits your TV.
The Display output mode only needs to be set once. It only needs to be changed if the media player is used with a different TV/HDTV.
Λοιπόν...επειδή την πάτησα και γώ με κάποιον που έλεγε οτι η τελευταία έκδοση firmware του micca δουλεψε ρολοι και πήρα τον δίσκο στο χέρι, το έψαξα και βρήκα αυτό εδώ...
Αλλα επειδή είναι πολλά,συνοψίζω: 1.κατεβάζουμε την Live suite 1.07
2.Κατεβάζουμε το firmware που είναι για την συσκευή μας... σε μένα δούλεψε ένα παλιό επίσημο της micca...αυτό εδω
3. Ανοίγουμε το case του media player...βίδες-βιδούλες και φτάνουμε στην πλακέτα...θα προσέξετε ότι δίπλα στο κουμπάκι του power έχει ένα μεγάλο ολοκληρωμένο της Samsung...μια DRAM...όπως το κοιτάτε με το κουμπάκι του power δεξιά θα χρειαστεί να βραχυκυκλώσουμε τα ποδαράκια δίπλα του μετρώντας απο το 5 έως και το 8 με την μύτη ενός ίσιου κατσαβιδιού...δηλαδή απλά ακουμπάμε την μύτη καλά πάνω στα ποδαράκια 5 έως 8 όταν χρειαστεί.
4.Τώρα λοιπόν η διαδικασία...... :::αφου εγκαταστήσουμε το live suit κλπτ το ανοίγουμε φορτώνουμε το firmware που θέλουμε (εικόνα κύβου).....βάζουμε την τροφοδοσία του ρεύματος την κανονική απο την μπρίζα και αφότου ανάψει το λαμπάκι το σβήνουμε κρατώντας το power για περίπου 8 δευτερόλεπτα.....βάζουμε το usb στον υπολογιστή και στον δίσκο (επειδή τον σβήσαμε δεν ανάβει τπτ).... τώρα το πιο σημαντικό βήμα, βάζουμε το κατσαβίδι για να βραχυκυκλώσουμε τα παραπάνω pin 5 με 8 που λέγαμε και πατάμε μπροστά στο ir led με το τηλεχειριστήριο το πληκτρο OK (δηλαδή το play) και παράλληλα ανοίγουμε τον σκληρό με το κουμπί power (ολα αυτά μαζι!!!)....απο προσωπική εμπειρία τώρα εμένα δούλεψε και άναψε το κοκκινο led και μέτα απο 1-1,5 sec βγάζουμε το κατσαβίδι και ξαναπατάμε το OK πρίν σβήσει το κοκκινο LED και το βλέπει το πρόγραμμα και ξεκινάει να flasharei το νέο firmware...άλλοι λένα ότι απλά περιμένουν με το κατσαβίδι το κουμπι power και το πλήκτρο OK και οτι γίνεται...σε μένα δν γινόταν...έπειτα φορτώνει μια μπάρα μέχρι το 100% και όταν τελειώσει περιμένουμε 2 λεπτά, πατάμε οκ στον υπολογιστή και αφαιρούμε μόνο το usb απο τον υπολογιστή...περιμένουμε άλλα 5 λεπτά και μετά σβήνουμε τον σκληρό...αν όλα πήγαν καλά ο δίσκος δουλεύει ξανά με έκδοση micca χωρίς το logo του ΟΤΕ και τα χαρακτηριστικά που δίνει η micca...
Οποιος θέλει διαβάζει και το ξένο site για παραπάνω (ο media player βασίζεται στο Ider I6-FH (Boxchip F10)) ....σε μένα δούλεψε (η αρχική οθόνη
...δεν έχετε να χάσετε τπτ αν είναι brickarismenos...
