---My Personal Raidho---
Με έναν πρόχειρο υπολογισμό, χρειάζομαι περίπου +17 dB παραπάνω για την ίδια ένταση που επιτυγχάνω με τα Senn HD-650. Θεούλη μου!
Μάλλον δεν τα οδηγεί το Sansa. :)
Από τον γνωστό τύπο στο Headfi με τον εξοπλισμό της παρακάτω εικόνας (ναι, είναι τα SR-009 και το πανάκριβο dac της MSB!) - εντάξει, τα Αγγλικά του δεν είναι και τα καλύτερα, αλλά συμπεράσματα μπορεί να βγάλει κανείς:
"Well the the sound of the he6 is much more musical. Richer in sound quality that is pleasing to my ears. The detail of the stax is fantastic but clinical or sterile. I know it sounds stupid but it is not. If you want to hear every little pice of detail it's there but you do not feel connected to the music. I know people write about this and I always thought they were full of it . But they are not. Here is another example. A fellow headfi bud had the 007 we did a mini meet . As I did not like the 007 as it lost some of the detail compared to the 009. But he did like his better and I can understand why. I think and I am guessing here. The 009 has so much detail that it is hard to here the music cause my brain is way to busy to hear the music . It's kinda like walking into a room with many clocks on the wall all different and ticking. It's hard to enjoy just one clock. I hope this helps. Now the he 6 is bloated with bass as I use a little EQ to remove this, but the sound is almost warming. It is pleasing to my ears. Now I would imagine if I used the 009 more I might feel better about them. And I have done this and it gets better. But if I put the other ones back on I feel I missed out on the euphoric feeling all along .
The only other headphone that I like more than the he 6 or at least even is the sennheiser HE60 . It has the euphoric feeling of the he6. But had the level of detail of the 009. So I can see the Orpheus praise that people talk about as the he60 is close to them."
Μένει να δω και εγώ προσωπικά τι μπορούν να κάνουν τα συγκεκριμένα ακουστικά.
Οι εντυπώσεις μου θα περιγραφούν σε ξεχωριστό νήμα που θα ανοίξω το βράδυ.:a0210:
Προσωρινή παύση λοιπόν στο παρόν νήμα...
Το κοίταζα και φυσικά σε σκέφτηκα. Μια που η κουβέντα εχει παει στο δίπλα νημα ειναι ωραίος τροπος να κλείσουμε εδω
Το ακούσαμε αυτό το δωμάτιο για αρκετή ώρα με τα μεγάλα και τα μεσαία ηχεία... κάναμε και πλάκα με τον σχεδιαστή...
Πολύ καλός ήχος...
Που η πολυ Χρηστο? Θα τον αρρωστήσεις τον Σταυρο..
Δυνατο ηχειο χωρις αμφιβολια
