New AirPort Extreme @2013
airb
25 May 2008
16,260
Λιβαδειά
Size and Weight
◾ Dimensions: 3.85 inches (98 mm) by 3.85 inches (98 mm) by 6.6 inches (168 mm)
◾ Weight: 2.08 pounds (945 grams)
Wireless
◾ IEEE 802.11a/b/g/n/ac
◾ Six-element beamforming antenna array
◾ Simultaneous dual-band 2.4GHz and 5GHz
◾ Radio output power: 32.5 dBm maximum (varies by country)
◾ Channels 1-11, 36-48, and 149-165 approved for use in the United States and Canada
◾ Channels 1-13, 36-64, and 100-140 approved for use in Europe and Japan
◾ Channels 1-13, 36-64, and 149-165 approved for use in Australia, Hong Kong, and New Zealand
Compatibility
◾ Interoperable with 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac-enabled Mac computers, iOS devices,
Apple TV, Windows-based PCs, and other Wi-Fi devices
◾ NAT, DHCP, PPPoE, VPN Passthrough (IPSec, PPTP, and L2TP), DNS Proxy, IPv6 (6to4 and manual tunnels)
Security
◾ Wi‑Fi Protected Access™ (WPA/WPA2)
◾ WPA/WPA2 Enterprise
◾ MAC address filtering
◾ NAT firewall
◾ 802.1X, PEAP, LEAP, TTLS, TLS, FAST
◾ Time-based access control
Interfaces
◾ Simultaneous dual-band 802.11ac wireless
◾ Gigabit Ethernet WAN port for connecting a DSL modem, cable modem, or Ethernet network
◾ USB 2 port for connecting a USB printer or hard drive
◾ Three Gigabit Ethernet LAN ports for connecting a computer, Ethernet hub, or networked printer
◾ Built-in power supply
Number of Users
◾ 50
Electrical and Environmental Requirements
◾ 100-240V AC, 50-60Hz; input current: 0.2 amp
◾ Operating temperature: 32° to 95° F (0° to 35° C)
◾ Storage temperature: -13° to 140° F (-25° to 60° C)
◾ Relative humidity (operating): 20% to 80%, noncondensing
◾ Maximum operating altitude: 10,000 feet
◾ Maximum storage altitude: 15,000 feet
Agency Approval
◾ FCC Part 15 Class B, Canada RSS-210, EN 300-328, EN 301-489, EN 301 893, ARIB STD-T66,
RCR STD-T33, AS/NZS 4268: 2003, UL 60950, CSA-C22.2 No. 60950, GB 4943.1-2011
System Requirements
- Setup and Administration
◾ iPhone, iPad, or iPod touch with iOS 5 or later and AirPort Utility 1.3
◾ Mac with OS X Lion v10.7.5 or later and AirPort Utility 6.3
- Wireless Device Access
◾ Any Wi‑Fi-enabled device that uses the 802.11a/b/g/n/ac specification
- Shared Printing with a USB Printer
◾ USB printer
◾ Mac with OS X v10.2.7 or later
◾ PC with Windows XP (SP3), Windows Vista (SP2), Windows 7 (SP1), or Windows 8
- Shared USB Hard Drive
◾ Mac with OS X v10.4.8 or later
Software and Documentation
◾ Printed documentation included
◾ AirPort Utility for Mac available for free download
◾ AirPort Utility for iOS available for free download
◾ Bonjour for Windows available for free download
Apple.com
Τιμές:
AirPort Extreme: 219€
AirPort Time Capsule 2TB: 339€
AirPort Time Capsule 3TB: 439€
http://www.ifixit.com/Teardown/AirPort+Extreme+A1521+Teardown/15044/1
