Nice Hybrid TV Tuner....
Browser
10,573
Προκειται για μια καρτα pci x της Lifeview, η οποια εχει 2 διπλους δεκτες.
Μπορουμε δηλαδη να τη σεταρουμε ειτε σαν δυο αναλογικους ειτε σαν δυο ψηφιακους, ειτε εναν κι εναν.
Ταυτοχρονη ομως θεαση κι απο τους δυο δεκτες μπορουμε να εχουμε μονο οταν την σετερουμε σαν dvb-t και analogue, δυνατοτητα που μας δινει η MST (multiple streaming technology) που εχει εφαρμοσει η εταιρια .
  • [FONT=Verdana, Arial, Helvetica, sans-serif]Watch and record DVB-T digital terrestrial TV on your PC[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]Listen to digital terrestrial radio on your PC [/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]Supports worldwide analog TV standards, including NTSC/PAL/SECAM[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]Supports worldwide audio decoding standards, including NICAM, A2, MTS, BTSC and EIAJ[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]S-Video and composite video inputs[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]Dual hardware MPEG encoders for analog TV/video[/FONT]
  • [FONT=Verdana, Arial, Helvetica, sans-serif]Compatible with Windows Media Center Edition 2005[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]MST: Multiple Streaming Technology[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]- Watch any two channels simultaneously, digital or analog[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]- Watch up to 4 live video streams at the same time*[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]- PIP: Watch each stream in separate movable, resizable windows[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]- M-PIC: Watch each stream in side by side, full-frame screens[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]- Record from one video source while watching the others at the same time[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]*DVB-S, DVB-T, S-Video and composite video
Περισσοτερα εδω.....
http://www.lifeview.com.tw/html/products/internal_tv/flytv_express_x1_mst_t2a2m.htm
Συμφωνώ και εγώ με το συγκεκριμένο tuner, μένει να δούμε αν ισχύουν αυτά που λένε τα τεχνικά χαρακτηριστικά και στην πράξη.
Συγκεκριμένα αν στα MCE 2005 "παίζουν" ταυτόχρονα στο live tv και τα αναλογικα αλλά και τα ψηφιακά κανάλια. (πρόβλημα το οποίο δεν έχω λύσει ακόμα με το pinnacle dual hybrid pci x).
Αν κάποιος έχει την συγκεκριμένη κάρτα και το έχει καταφέρει παρακαλώ ας απαντήσει.
Οι εφαρμογες που ερχονται μαζι με τις καρτουλες συνηθως παιζουν.
Το θεμα ειναι οπως ειπες κι εσυ με τα frontend .
Αλλα στην ουσια δεν ξερω ποια μπορει να ειναι η χρηση περαν του οτι το ενα μπορει να γραφει απο το ενα tuner κι εσυ να βλεπεις το αλλο.
Τι χρειαζεται να τα βλεπουμε και τα δυο......
Συγνώμη αν δεν το διατύπωσα σωστά, αλλά δεν εννοώ να "παίζουν" και τα 2 ταυτόχρονα (αναλογικό και ψηφιακό). Προσωπικά δεν έχω καταφέρει να κάνω και τα 2 να βρίσκονται στην ίδια λίστα καναλιών και να κάνεις zapping εναλλάξ τα κανάλια (αναλογικά και ψηφιακά).
Υ.γ. Απάντησα γρήγορα πάντως :smile:
Μόνο για PiP PaP κλπ
Προσωπικά αυτό που μ' ενδιαφέρει είναι να κάνω την σάρωση των καναλιών και π.χ. στο 1 να βρίσκεται το ΕΤ1, στο 2 το ΕΤ2 κλπ κλπ και στο τέλος στο 10 να αποθηκεύω το Πρισμα +, στο 11 Cine + κλπ κλπ.
Ή στην χειρότερη να επιλέγω μέσα από τα Media Center αν θα βλέπω ψηφιακά ή αναλογικά κανάλια. Αλλά να έχω την δυνατότητα να τα παρακολουθώ μέσα από το ίδιο πρόγραμμα.
Δεν μ' ενδιαφέρουν τα Pip - Pap κλπ κλπ.
Ξέρει κανένας αν αυτό γίνεται?
Ευχαριστώ
Υ.Γ. Μιλάω μόνο για Windows MCE ή Vista Media Center.
Το ότι μέσα από τα media center δε μπορείς να παίζεις από δύο διαφορετικά tuner είναι "θεμα" Microsoft κι όχι κάρτας tv...
Αναμένεται σύντομα αναβάθμιση των media center όπου θα μπορείς να παίζεις από δύο tuner. Θα χρειάζεσαι όμως δύο κάρτες tv.
Πιθανότερη release περίοδος είναι η Άνοιξη
Ευχαριστώ πολύ για την ενημέρωση. Μόλις απέφυγα αγορά νέας κάρτας (έψαχνα κάτι με H/W acc). Θα περιμένω τότε. (το πολύ πολύ να περιμένω να γίνουν όλα ψηφιακά και να τελειώνει η ταλαιπωρία μου δλδ το 2012 και βάλε....).
