Onda V975M
Simos.I
Μέλος Δ.Σ.
33,851
Land of Dystopia
Onda V975M Amlogic M802 2.0GHz 9.7 inch
Onda V975M Quad Core 2.0GHz 9.7 Inch Retina Screen Android Tablet 16GB White
Onda V975M Quad Core is the latest Amlogic M802 Quad Core Android Tablet. Onda V975M features Amlogic M802 Cortex A9 28 Nanometer Process Technology
CPU and Mali 450 MP4 Octa Core GPU
Super Quad Core Processor
Onda V975M Quad Core features Amlogic M802 Quad Core Processor,with the latest ARM Cortex A9r4,Single Core CPU speed up to 2.0GHz
Octa Core GPU
Onda V975M Tablet features Mali 450MP Octa Core GPU,with 8 Core 600MHz
TSMC 28nm HPM Technology
With the latest 28nm HPM technology,Amlogic M802 Processor and Mali 450MP Octa Core,Antutu Test Over 30000
64bit Dual Channel 2GB DDR3 16GB Storage
Onda V975M RAM update to 2GB 64bit Dual Channel
4:3 Retina Screen
Onda V975m Quad Core features 2048*1536 Screen PPi over 264 Retina Screen,310W Pixel resolution the same as iPad 4.
HD Dual Camera
Onda V975m features 5.0M HD Back Camera the same as iPhone OV Camera.Front 2.0M HD Camera.
Onda V975M Quad Core Tablet Features:
OS: Android 4.3
CPU: Quad Core Amlogic M802 Cortex A9r4 28nm 2.0GHz
GPU: Mali 450 Octa Core GPU
RAM 2GB,DDR3
Storage 16GB
Shell Material Metal
Screen: Capacitive Touchscreen, 2048*1536 High-resolution Screen
Resolution: 2048*1536 Pixels
Visible Angle: 178°
Screen PPI: 264
Display: Retina IPS Screen
Daul Camera:Front 2.0 Megapixels,Back 5.0 Megapixels Auto Foucus (iPhone 4 OV Camera)
Onda V975M Quad Core Tablet PC other Details:
Video: 4K HD Videp Play with formats of MP4/3GP/3G2/RM/RMVB/ASF/FLAC/APE/MOV etc.
Gravity Sensor Yes
Skype Yes
Multi-Touch Yes, 10 points touch
OTG: Yes
Play Store: Yes, built in
Extend Card Support TF card up to 32GB extended
Email and Browser: Yes, built in
WIFI: Yes, 802.11 b/g/n
3G : Not built in, support external 3G dongle
Earphone Interface 3.5mm
Video 1080P, AVI/MOV/MP4/RMVB/FLV/MKV…
Music MP3/WMA/WAV/APE/AAC/FLAC/OGG
Ebook UMD, TXT, PDF, HTML, RTF, FB2…
Work Time: Up to 8~10 hours
Battery : 8500 mAh
Onda V975M Quad Core Weight: 539g
Onda V975M Quad Core Size: 242*179*8.3mm
Μόνο 160 .
Δεν έχει gps
Περισσότερα εδώ:
Re: Yπερτούμπανο;
HDMI δεν βλέπω .
όντως δεν υπάρχει!!
κι όμως υπάρχει..................
Από αριστερά προς τα δεξιά: το κουμπί τροφοδοσίας, υποδοχή ακουστικών, Micro HDMI, Micro USB
Στο V975m ρυθμίσεις της διασύνδεσης ολοκληρωμένη, υποδοχή ακουστικών, υποδοχή Micro SD κάρτα επέκτασης, διεπαφές USB Micro τοποθετούνται στην κορυφή της πλευράς της ατράκτου, οι διασυνδέσεις OTG από κοινού με την κατηγορία ότι μια Micro USB. Μια άλλη πλευρά το πλάτος περιορίζεται από την έλλειψη της εξόδου βίντεο που έχει επιλεγεί μικρό χώρο αποτύπωμα θύρα Micro HDMI, προαιρετικά εξαρτήματα όταν δίνουμε προσοχή.
Μετάφραση από τα κινέζικα ( δυστυχώς)
http://toutiao.zol.com.cn/4293919
κλοπηράιτ κάργα βλέπω.....
Μπορεί να είναι...................
http://www.myphone.gr/forum/showthread.php?t=383722
όχι κι άσχημο ?
Απάντηση: Re: Yπερτούμπανο;
Φωτια μας αναψατε! Αν καποιος εχει παρε-δωσε με Κινα και παραγγειλει to 32αρι, ας μου στειλει ένα pm για τα διαδικαστικα .Δεν εχω παραγγειλει ποτε από Κινα και εχω ένα μικρο αγχος. Αν μπορει να με βαλει στην παραγγελια του καποιος από Αθηνα και να του το προπληρωσω, θα με βολευε ακομα παραπανω! Πολλα ζηταω ε;
Χρειαζομαι ένα ταμπλετ σχετικα συντομα και αυτό φαινεται ότι πρεπει!
Re: Απάντηση: Re: Yπερτούμπανο;
Κώστα, δεν σου κρύβω ότι είμαι στο τσακ, να δώσω παραγγελία, αλλά κάτι με κρατάει πίσω, υπάρχει βέβαια η ασφάλεια ( η όποια) του paypal, αλλά δεν ξέρω φοβάμαι να το τολμήσω, ίσως η λύση του κινέζικου στην Ευρώπη θα ήταν περισσότερο δελεαστική, υπήρχε λέω υπήρχε το ipadaleternative.com με κατάστημα στην Αγγλία, αλλά έχει κάποια προβλήματα πια με το θάνατο του ιδιοκτήτη........
Re: Yπερτούμπανο;
Aκούγεται έντονα και αναβάθμιση σε Kit Kat, η οθόνη του είναι η LP097QX1-SPA1 της LG και είναι η ίδια πού έχει το ipad 3.
Re: Yπερτούμπανο;
Την άλλη Δευτέρα το Pandawill δίνει το ONDA των 32GB στα 150 ή 157 και την Πέμπτη το μοντέλο των 16GB στα 132 ή 140
Re: Yπερτούμπανο;
Δεν ξέρω εάν έκανα καλά, έδειξα εμπιστοσύνη στο Geekbuying 180 κομπλέ, hdmi ΚΑΛΏΔΙΟ, eur charger, ΟΤG, CASE, POWER TANK, SD 32GB
Re: Yπερτούμπανο;
Αν σου βγήκε μόνο 180 με όλα αυτά τα καλούδια, καλά έκανες. Το GB έχει αποκτήσει καλή φήμη τελευταία.
Re: Onda V975M - Yπερτούμπανο;
Πως τα κατάφερες και επεσε τοσο η τιμη; Εγω όταν βαζω τα ιδια προϊόντα , μου βγαινει 297$ , δηλαδή 215€. Βγαλε κι 7€ από ένα κουπονι που μου εδωσαν, παμε στα 208. Για βοηθα λιγο, μπας και γλιτώσουμε τιποτα!
Eφυγε και η δικη μου παραγγελια! Αντε να δουμε, αν τελικα αξιζει το tabletακι τον ντορο.
Το μονο αρνητικο που διαβαζω είναι η ελλειψη bluetooth. Aν και από ότι βλεπω , πρεπει να υπαρχει και εκδοση με bluetooth στα 268$. http://www.hongkongeek.com/en/andro...let-onda-v975m-android-43-with-bluetooth.html
Δεν ξερω κατά ποσο είναι αξιοπιστο το site στο παραπανω link όμως. Μην παρω και καποιον στο λαιμο μου!
Απο που παρηγγειλες και ποσο τελικα; Σε 2 μερες θα εχει και happy hour στο pandawill gia τα 16 gb.
Από geekbuying. Πηρα το 32αρι ταμπλετ, μια δερματινη θηκη, microsd 32gb, hdmi καλωδιο , φορτιστη και μου βγηκε γυρω στα 190€ με ένα κουπονι των 10$ . Ο κωδικος πρεπει να είναι NPZMKVAT.
Το ηξερα για το 16αρι από pandawill , αλλα ηθελα το 32αρι.
Καλορίζικο! Άμα μπορείς να μας μεταφέρεις τις εντυπώσεις σου. Φαίνεται πολύ καλό αλλά δεν έχω αγοράσει πότε αντικείμενο τόσης αξίας από Κίνα και είμαι λίγο επιφυλακτικός...
Χθες είχε το Panda το 32αρι στα 157 περίπου αλλα, με όλα τα υπόλοιπα που πήρες με 190, μια χαρά προσφορά σου βγήκε :)
Δεν ξέρω πραγματικά, για την αξιοπιστία, όπως αναφέρεις, προτίμησα το geekbuying, λόγω της εμπιστοσύνης που του δείχνουν στο myphone.gr
Δεν ξέρω πολύ έχουν "καεί" από το pandawill, βέβαια υπάρχει και η εγγύηση του paypal.
Από geekbuying. Πηρα το 32αρι ταμπλετ, μια δερματινη θηκη, microsd 32gb, hdmi καλωδιο , φορτιστη και μου βγηκε γυρω στα 190 με ένα κουπονι των 10$ . Ο κωδικος πρεπει να είναι NPZMKVAT.
Σε έπεισα φαίνεται.......
Θεωρητικά προς το τέλος του μήνα, θα το έχω, για να δούμε.......
Απάντηση: Onda V975M - Yπερτούμπανο;
Το εκπτωτικο κουπονι πως το παιρνουμε ;Αυτο που αναφερθηκε παραπανω δεν ισχυει.
