OPPO BDT-101CI Blu-ray Transport
xavito
29 October 2008
9,833
[oppodigital.co.uk]...Oppo BDT-101CI specs...http://www.oppodigital.co.uk/ecommerce/product/oppo-bdt-101ci.aspx
Advanced Features
  • Universal disc format support including Blu-ray, Blu-ray 3D[SUP]1[/SUP], DVD, DVD-Audio, Super Audio CD, CD, HDCD and more
  • Upscaling to Ultra HD (4K) resolution
  • VRS (Video Reference Series) ClearView video processing
  • Dolby TrueHD and Dolby Digital Plus decoding
  • DTS-HD Master Audio decoding
  • Bitstream output compatible with Dolby Atmos and DTS-X
  • Three USB ports for playback of media files[SUP]2[/SUP] (AVCHD, MKV, AVI, MP4, WAV, FLAC, APE, DSD, etc.)
  • Ethernet port for BD-Live, firmware upgrade and home network media file playback
  • True 24p video for Blu-ray encoded in 24Hz frame rate and optional conversion of DVD to 24p
  • Multiple zoom modes
  • Advanced picture control including video smoothing, detail and edge enhancement
  • Premium 32-bit audio DAC by AKM
  • Optical and coaxial digital audio outputs
  • Rigid steel chassis and centre mounted disc loader with motion balance and vibration isolating mechanisms
  • Back-lit remote control
Notes:
[SUP]1[/SUP] Requires proper 3D television and glasses.
[SUP]2[/SUP] Compatibility with user-encoded contents or user-created discs is on a best-effort basis with no guarantee due to the variation of media, software and techniques used.
Custom Installation Features
  • Versatile modular design with many customised options
  • One or two HDMI outputs via the additional HDMI output module
  • Optional HDBaseT output module for long cable runs
  • Stereo or optional 7.1ch analogue audio output module
  • Optional rack mount kit
  • Large front panel buttons with finger guards
  • RS232 and IP control for system integration
  • Switchable rear IR sensor for a clean IR blaster/emitter installation
  • HDMI CEC (Consumer Electronics Control)
  • Three customisable picture adjustment presets
  • Settings can be locked to prevent inadvertent changes
[oppodigital.co.uk]...Understanding the Differences between the BDT-101CI and BDP-103...http://www.oppodigital.co.uk/custom...se/differences-between-101ci-and-103-105.aspx
[hdfever.fr]...OPPO BDT-101CI: Modular Blu-ray player with AKM DAC and 4K uspcaling...http://www.hdfever.fr/2015/10/30/oppo-bdt-101ci/
μετάφραση google fr to en
Indicative prices:
OPPO BDT-101CI + stereo sound card: 549
7.1 Sound Card: 100
2nd HDMI 2.0 Card: 100
HDBaseT card: 299
[hdfever.fr]...Reception OPPO BDT-101CI: unpacking & presentation of internal electronic modules...http://www.hdfever.fr/2015/11/06/reception-et-deballage-oppo-bdt-101ci/
- Audio Output RCA 2.0 ( 549)
- RCA audio output + 2.0 second output HDMI ( 649)
- Audio Output RCA output + 2.0 HDBaseT ( 849)
- RCA Audio Output 7.1 ( 649)
- RCA audio output + 7.1 second output HDMI ( 749)
- Audio Output RCA output + 7.1 HDBaseT ( 949)
- with RCA 2.0 audio output ( 699)
- with RCA audio output + 2.0 second output HDMI ( 799)
- with RCA 2.0 audio output + output HDBaseT ( 999)
- with RCA 7.1 audio output ( 799)
- with RCA audio output + 7.1 second output HDMI ( 899)
- with RCA audio output + 7.1 output HDBaseT ( 1,099)
Teardown BDT-101CI
source photos:[hdfever.fr]...:grinning-smiley-043
Κάπως έτσι λοιπόν όλες οι εταιρίες γίνονται γνώστες .
ΜΜΜ modules με ΑΚΜ dac και όχι μόνο....Κίνηση ΜΑΤ για να είναι μέσα στην τεχνολογία και όχι να αλλάζει μοντέλο κάθε φορά.
Προσωπικά εδώ και καιρό έχω καταργήσει τον AV μου και σαν προενισχυτη χρησιμοποιώ το oppo 103 EU αφού διαθέτω τελικούς.
Η εικόνα ακόμη και από τα δορυφορικά nova, hol ,apple tv αναβαθμιζονται μέσα από το player αφού διαθέτει εισόδους hdmi και αυτό το διαπιστώνεις άμεσα όχι μόνο στις μεγάλες ιντζες αλλά και στις μικρές.
Όσον αφορά τον ήχο ...Θα πω μόνο να το δοκιμάσουν όσοι διαθέτουν τελικό και ίδια σειρά ηχείων ίδια καλώδια κτλ ,αφού δεν διαθέτει ισοστάθμιση,να χρησιμοποιησουν εφαρμογές για τα db ...Υπάρχουν ένα σωρό και μάλιστα τσάμπα και προπάντων αυτί ...
Δεν θα το συνιστούσα όμως για δικαναλο, αφού το άκουσμα σαν cd player είναι ιδιαίτερα πνιγμένο στα άκρα
Η συγκεκριμένη εταιρία αν προσέξει τις αναβαθμίσεις του λογισμικού νομιζω ότι δεν θα διαθέτει αντίπαλο .IMG_1356.jpgIMG_1357.jpgIMG_1360.jpg
