Panasonic GH-4
kbouk
8 January 2010
32,093
ΠΕΙΡΑΙΑΣ
Στις 7 Φλεβαρη (αυριο) ανακοινώνεται η νεα ναυαρχίδα της Panasonic GH-4 με τεχνικά χαρακτηριστικά που διέρευσαν ηδη στο 43rumors :
16,05 Megapixel sensor. It’s a new sensor with semi-conductor protection tech to reduce noise and improved dynamic range.
- quad core processor and venus Engine
- ISO up to 25,600.
- 12fps, 7,5 fps with continuous focusing
- GH4 uses the new UHS I class III SD card format
- Depth From Defocusing (uses Panasonic lens database to fine tune AF!)
- AF as fast as 0.07 seconds. 49 AF points.
- 4K video at 4096×2160 pixels and max frame rate of 96fps.
- Bit rate of up to 200Mbp
- Magnesium body
- Price not unveiled yet
- There is an optional Interface Unit (see image below). Has 2 XLR, 4 SDI, micro HDMi output, color bar signal, audio reference signal, external time control
Απάντηση: Re: Panasonic GH-4 ανακοινώνεται ......
Η μηχανη ανακοινωθηκε, μερικα τελευταια νεα :
1) Pricing will be announced in mid March only! (Camera will cost less than $2000 or 2000 Euro).
2) This is the world’s first mirrorless interchangeable lens mount camera recording 4K
3) The external XLR / HD-SDI add-on for this camera allows for uncompressed 10bit 4K output over 3G HD-SDI – the kind of spec Canon currently charges $25,000.
4) DFD (Depth-of-Defocus) autofocus works like this: During live view (before a half-press of the shutter button), the camera will occasionally make a tiny adjustment to focus, to check whether subjects in the frame are in front of or behind the current focus point. In addition to this information, the camera judges how far out-of-focus objects in the scene are, based on how blurred they are, assessed using a profile detailing the blur behavior of the lens at its current aperture. Although this combination of data itself doesn’t give the GH4 enough information to achieve precise focus, it does give it a clear idea of where it should start using conventional contrast detection AF process to achieve fine focus.
5) Recording 4K will crop your image by an ulterior 1,2x factor.
6) The new sensor seems to be able to get more detail out of the highlights than the sensor in the Olympus EM1.
Κατά πάσα πιθανότητα χρησιμοποιεί τον αισθητήρα που ανακοινώθηκε τον Νοεμβριο του 2013 ..
Το χαρακτηριστικό που τον ξεχωρίζει είναι η πρωτοφανής ταχύτητα full scan για consumer αισθητήρα photo-video
Μπορεί να δωσει 16,4Μp 12bit σε 14.7 fps !!!. Σε λίγο μικρότερο bitdepth 10bit (χρήσιμο σε video) φθάνει τα 22,5fps και αν υπολογίσουμε το κροπ 16/9 μπορεί να φτάσει τα 30fps.
Bέβαια δεν φαίνεται στην παρουσίαση τι θόρυβος υπάρχει σε αυτούς τους χρονισμούς ..
Στα video mode γίνονται συνεννώσεις (binning) πίξελ οπου ζευγάρια-τετράδες-εννιάδες πιξελ διαβάζονται με την μία οπότε πολλαπλασιάζεται το frame rate.
Αποτι φαίνεται η Panny δεν τσίτωσε τους χρονισμούς στη GH4 (προφανώς βρηκαν μια χρυσή τομή ταχύτητας/θορύβου/συμπεριφοράς σε θερμοκρασία) καθώς στο 4Κ βιντεο το καδρο είναι σε 1,2Χ κροπ (το 70% των πιξελ χρησιμοποιείται).
Το αναμενόμενο μετα απο αυτά τα χαρακτηριστικά είναι το Rollig Shutter να είναι ελαχιστοποιημένο τουλάχιστον σε 1080p .. σε 4K οχι τόσο.
Eπίσης πολύ καλή συμπεριφορά σε electrοnic shutter (και να δούμε μήπως κατήργησαν μερος απο το μηχανικό κλείστρο .. την μία κουρτίνα ?? ..)
Απόρροια αυτής της ταχύτητας του αισθητήρα είναι και τα κόλπα που μπορούν να κάνουν με το AF, DFD κλπ. (προλαβαίνουν να κάνουν πολλές μετρήσεις σε real time).
Φαίνεται να πλησιάζουν με Contrast Detection AF τις επιδόσεις των Phase detection και υβριδικών συστημάτων ..
Ο επεξεργαστής θα πρέπει να είναι εργοστάσιο in a chip !!.
Απάντηση: Panasonic GH-4 ανακοινώνεται ......
Και εγω ειδα την βαση και λεω περνει δυο σκληρους των 4TB για να γραφεις 4k βιντεο.
ενα ωραιο αρθρο για το νεο συστημα εστιασης DFD http://www.imaging-resource.com/PRODS/panasonic-gh4/panasonic-gh4A.HTM#DFD
Εχει γίνει το καλύτερο photo-site το Imaging resource, συνεχίζει όπως πολύ ωραία παρουσίασε την έλειψη αα απο την D800, το μηχανικό αα της Κ3, το πρωτοποριακό κλείστρο της GM-1 ..
Τι γελοιοτητα ειναι αυτο το πραγμα απο κατω ?
Δεν εβγαζαν μια κανονικη βιντεοκαμερα που εχουμε να δουμε της προκοπης κομματι εδω και χρονια ?
Και άλλα 3 χιλιάρικα για pc για επεξεργασία των 4k αρχείων.
Και άλλα 3 χιλιάρικα για αγορά ultrahd tv.
