Panasonic LCD-Plasma 2009
Απάντηση: PANASONIC LCD-PLASMA 2009
Καλορίζικες και καλοθέατες.
Περιμένουμε εντυπώσεις και φωτογραφίες!
Re: PANASONIC LCD-PLASMA 2009
Οι πιο πολλοι δινουν ΑΤΟΚΕΣ δοσεις οποτε αυτο που λες δεν ισχυει..
Αφου λεει πως δεν εχει ιδιες τιμες με το πλαισιο..οποτε εαν ειναι γυρω στα ~1200 ευρω για 46αρα απο το καταστημα του banner ειναι ενταξει τιμες
1200 ευρω για 46αρα G10 έστω και μετρητοίς , που την πουλάνε τόσο να παω και εγώ.
Και φυσικά ο "έρωτας" όλων...... (για το site εννοώ)...
http://www.play.com/Electronics/Ele...sat-Widescreen-Plasma-TV/Product.html?cur=258
Το play com έχει την 42αρα G15 ... 1099 λίρες... ή 1499 ευρώ... (Αλλο βεβαια που 1099 λίρες είναι ΤΩΡΑ.. 1181 ευρώ...) (due to release 30.6.09)..
Ουστ κλέφτες..
Ελπίζω να μην κουράσει.. αλλά διαβάστε και το παρακάτω...: (από το Avforums.com):
I'm just back from a local store and saw the 40w5500, 40w4500, and the panasonic plasma TX-P40G10E in close proximity to each other. I must say the w5500 looks a bit cheap compared to the rest. The lower part with the speaker doesn't look appealing. Picture wise, I couldn't see any noticeable difference between the w4500 and w5500. Both had very good colours and pretty good blacks (although thats always hard to evaluate in a store). Too bad it was so crowded I couldn't fiddle around with the settings.
The G10 looked a bit pale at first and the whites where a bit disappointing vs the w4500 and w5500. The viewing angle of the w5500 is actually pretty good, although the G10 being a plasma was definitely better. After getting hold of the store manager he went and got the remote of the G10. Like I thought, the G10 was in eco mode and brightness was to low (approximately 1/3 of max). After turning of the eco mode and cranking up the brightness a bit, the G10 was really impressive and was in my opinion better than the w4500 and w5500. Punchier whites and more realistic colours. Also the demo of the 600Hz function was pretty convincing. Showing a noticeably sharper moving text then without it.
The store manager reassured me that burn in and 'run in' is a thing of the past, although turning down the contrast the first 100 hours or so is recommended. To make a story short, I bought the TX-P46G10E and it will be in stock and delivered next week on thursday. For the ones interested, I will post my findings in the '2009 panasonic plasma' thread.
Στο μυαλό μου ήσουν ??
Τα συμπεράσματα δικά μας... -bye-
Re: Απάντηση: PANASONIC LCD-PLASMA 2009
τα ιδια πραγματα ειδαν τα ματακια μου.
μονο που εμενα δεν μου εδωσαν τηλεκοντρολ ν`αλλαξω την θερμοκρασια του λευκου...:flipout:
Αν αγοράζαμε ότι βλέπαμε από τα καταστήματα θα παίρναμε όλοι philips. Δε μας είπε ο φίλος την πηγή (άλλο τηλεοπτικό sd, αλλο hd ready mpeg-2 και άλλο transformers σε avc). Επίσης δε μας είπε για τα 24p κουβέντα. Τι έτσι στο ξεκάρφωτο, judder party ?
Πάντως 1200 ευρώ είναι πολύ λίγα λεφτά και άνετα χτυπάει κάτι lcd σε αντίστοιχες ίντσες.Οτι πρέπει. Εδώ η pz80@ 42" έκανε 11κάτι πριν μερικές μέρες που είδα.
Απόψε την είδα, την 42G10, στο Mall, στο Πλαίσιο.
Δεν ήταν σωστά ρυθμισμένη, έδινε την εντύπωση πως έπαιζε σε dynamic mode.
Η κίνηση καλή, αλλά τα χρώματα ήταν έντονα και υπερκορεσμένα λόγω των κακών ρυθμίσεων. Δυστυχώς remote δεν υπήρχε και έτσι έφυγα άπρακτος (με τράβαγε κι ο γιος μου, που ήθελε να δοκιμάσει τις ικανότητές του στην πίστα της daytona σε ένα demo ps3).
Ομορφούλα ήταν πάντως ;)
Και εγώ αυτό σκέφτηκα...
Τι ρυθμίσεις χρησιμοποίησε ??...
Μετά τη ρύθμιση η τηλεόραση πετούσε..
Μπήκε στο service menu και τα έφτιαξε τα χρώματα. Μάλλον η συγκεκριμένη ρύθμιση λείπει από τις εκδόσεις για την Αγγλία, γιατί στο review του FullHD.gr υπάρχει κανονικά μενού για ρύθμιση του white balance. (Oι Άγγλοι παίρνουν ενσωματωμένο δορυφορικό δέκτη, οπότε μην τα θέλουν όλα δικά τους :D)
Απο οτι διαβασα και σε αυτο το review σε σχεση με περυσι βελτιωση εχουμε στον θορυβο (pwm noise) που ειναι ελαχιστος οπως και στην σχεδον απουσια phosphor trails. Επισης η εικονα σε HD εχει γινει πιο sharp.
To scaling/deinterlacing απο την αλλη παραμενει στα περυσινα επιπεδα (κατω του μετριου) αλλα δεν μπορουμε να τα εχουμε ολα.
και ότι παίζει άψογα τα 24p... και 2ms latency στα παιχνιδάκια.... :grinning-smiley-043
Αλλο latency αλλο Input lag , εξηγει παρακατω τι ειναι αυτο...
Input lag is the delay introduced by the TV's video processor, which delays frames reaching the screen.
Η εικόνα που πόσταρες δεν έχει σχέση με το response time, έχει να κάνει με input lag. ^^
Διάβασε τα Links που έβαλα, τα λένε ξεκάθαρα.
Δεν είναι δυνατόν να έχει response time = 50ms ^^
Το response time το δίνει και ο κατασκευαστής, το latency = input lag δε το δίνει κανένας απ όσο ξέρω.
Ορίστε, σου κάνω και copy-paste απο τα Links που πόσταρα πριν.
"Output lag is a phenomenon associated with some types of LCD displays, and nearly all types of HDTVs, that refers to latency, or lag measured by the difference between the time a signal is input into a display and the time it is shown by the display"
"Response time is the amount of time a pixel in an LCD monitor takes to go from black to white and back to black again. It is measured in milliseconds (ms). Lower numbers mean faster transitions and therefore fewer visible image artifacts."
Δεν ειναι input lag , response time ειναι μετρουμενο σε ms , το code που βλεπεις αποκατω ειναι οι διαφορες μεταβασεις απο χρωμα σε χρωμα.
Τελος παντων η χρηση του ορος "latency" μπερδευει γιατι απο μονος του δεν λεει τιποτα πρεπει να συνοδευεται απο προσδιορισμο για του τι εννοουμε οπως "Video Latency" , "Image Latency" , "input latency" κτλ.
Καλυτερα "input/output lag" για να μπορουμε να συνενοηθουμε.
Στις g10 τι από όλα αυτά τα ωραία θα παρατηρήσουμε??
