Παρουσιάστηκε εχτές η Lumix S5D και θα είναι διαθέσιμη από το Νοέμβριο στα 1.599 Euro με τον νέο pancake kit lens LUMIX S Series 18-40mm F4.5-6.3 and 2.099 Euro σε κιτ με τον ζουμ 28-200mm F4-7.1. Μια εισαγωγική FF είναι δηλ. μια S5 που παρεμεινε χωρίς PDAF αλλά έχει κάποιες βελτιώσεις ειδικά για βίντεο.
Based on the compact design of the LUMIX S5,
the redesigned S5D is DJI LiDAR AF capable. When the S5D is paired with the DJI LiDAR Range Finder Module and DJI RS 3 Pro Gimbal, the ranging data is sent to the camera via USB and the camera controls focus, eliminating the need for a focus motor. This allows for easier handling with a more compact size and greater freedom when working.
There is no need to calibrate the lens, saving time during setup. Thanks to the LiDAR's 43,200 high-speed measuring points at a distance of 14 meters, extremely fast autofocus is realized, which is effective even when shooting in low light conditions.
The LUMIX S5D offers excellent video performance and can record 4K 60p/50p 4:2:0 10-bit and 4K 30p/25p 4:2:2 10-bit internally for up to 30 minutes. It is also capable of outputting 4K 60p/50p 4:2:2 10-bit via HDMI. There is no time limit for internal 4K 30p/25p 4:2:0 8-bit recording.
In addition to C4K video recording, the LUMIX S5D can record RAW video data via HDMI at resolutions of 5.9K (5888x3312) 29.97p/25p, 4.1K (4128x2176) 59.94p/50p and Anamorphic 3.5K (3536x2656)/ Spend 50p on the ATOMOS NINJA V. A variety of auxiliary functions for video recording, such as the Vector Scope Display, Master Pedestal Adjustment and SS/Gain Operation (SEC/ISO, ANGLE/ISO, SEC/dB) are also available.
With the Slow & Quick mode, impressive slow motion and time lapse videos are possible in 4K (1-60fps, 30x fast to 2.5x slow) or in FHD (1-180fps, 60x fast to 7.5x slow).
High image quality even in low light conditions with Dual I.S.
The LUMIX S5D features Dual Native ISO sensitivity, a technology first introduced in Panasonic's VariCam range of professional cinema cameras. Typically, image noise increases with increasing sensitivity for a single native ISO image sensor. However, the Dual Native ISO image sensor in the S5D minimizes noise generation by selecting an optimal circuit before gain processing depending on sensitivity. This enables recordings with a high sensitivity of a maximum of ISO 51200. Dual Native ISO offers filmmakers a greater variety of artistic possibilities as well as the ability to use less light on set, saving time. The LUMIX S5D's dual native ISOs are 640 and 4000.1
The LUMIX S5D has a large LVF (Live View Finder) with a high magnification ratio of approximately 0.74x as well as a high-precision, fast
OLED (Organic Light-Emitting Diode) display with a high resolution of
2,360K dots. By using OLED for the LVF, a fast response is achieved with a minimum delay of less than 0.005 seconds. With an eye relief of approximately 20 mm, it offers high visibility and comfort for glasses wearers.
A 3.0-inch LCD with a clear viewing angle in a 3:2 aspect ratio and a high resolution of
1,840K dots enables touch control. Composition while recording in various popular aspect ratios such as 16:9, 4:3, 1:1, 4:5, 5:4 and 9:16 can be checked using the frame marker feature. A REC frame indicator shows whether the camera is currently recording or not.
The S5D will be available from
November at a price of
1,599 euros (RRP) for the kit with the LUMIX S Series 18-40mm F4.5-6.3 lens or
2,099 euros (RRP) for the kit with the 28-200mm F4-7.1 lens .
