Panasonic Plasma PZ80 / ΡZ85 : Reviews - Εντυπώσεις - Σχόλια
Re: Panasonic 42PZ85/42PZ80/46PZ85 Plasma
Δορυφορικο δεκτη εχει,οσο για το Intelligent Frame Creation νομιζω οτι το εχει βαλει στο off.Παιζει να ειναι κατι αλλο;
Γιάννη δεν έχει πρόβλημα με το IFS μια χαρά παίζει, υπάρχει περίπτωση να φταίει ο δορυφορικός δέκτης....
Με τι τον έχει συνδέσει ?????
Εχει τον octagon και τον εχει συνδεσει με hdmi.
Σπασμένο τηλέφωνο το κάναμε !!!!!!!:flipout:
παίξτε λίγο με τις ρυθμίσεις στο μενού του δέκτη, αυτό που έγραψες μου θυμίζει σπασίματα hd δέκτη....
δεν υπάρχει κανένα πρόβλημα με το IFS, εγώ σαν πηγή έχω τον m-vision HD200...
Hi All,
Have just purchased the Panasonic 42PZ800A Plasma however I have noticed while watching the football it sometimes gets some bad motion blur(mainly when the ball is kicked in the air and the crowd is behind it). Also, on my PS3, when playing Fifa 08, the same thing happens. Is this something I can eliminate? Otherwise I may be taking it back to swap for a 46" Sony bravia X-series LCD...
The whole idea of chosing the plasma was to deal with the faster moving objects....
Any thoughts?
I have the same problem on new 42inch panasonic plasma, aussie rules football is suffering motion blur, as is diving etc whenthey spin in olympics. Which is not good as i went plasma to avoid this..should i contact supplier?
By the way I went into the menu and found there was a feature called "intellegent frame creation" turned on so I turned it off and there was a huge improvement. Id say 50-60% of the blur went away however I still just dont think its quite right. This is 1080p so really no matter how fast the game movement it should be crisp right?
http://www.highdefforum.com/archive/t-74972.html
Unfortunately the interpolation artefacts introduced by [Intelligent Frame Creation] when watching sports proved to be more distracting. During the live broadcast of the second leg of Champion’s League quarter-final tie between Liverpool and Arsenal, I noticed the ball breaking up/ tearing and juddering whenever it went past the crowd, indicating that IFC’s interpolation algorithm had difficulty differentiating between the ball and the fans’ heads for motion rendering.
http://www.hdtvtest.co.uk/news/panasonic-th42pz85-review-20080414104.htm
Το ξέρω Γιάννη αλλά με το το δικό μου setup δεν έχω τέτοιο θέμα, ούτε με δορυφορική λήψη sd ή hd, ούτε με το istar ........
Τα έχω διαβάσει όλα αυτά πριν πάρω την 46pz.... ίσως να παίζει και κάποιο θέμα με τις ίντσες...
Απάντηση: Panasonic 42PZ85/42PZ80/46PZ85 Plasma
Το τελευταίο 10ήμερο στην 46ΡΖ85 του κουμπάρου μου με αρκετές ώρες θέασης ποδοσφαιρικών αγώνων (επίγειο τηλεοπτικό σήμα RF), εγώ δεν παρατήρησα κανένα σπάσιμο με το IFS ενεργοποιημένο, όλα τρέχαν νεράκι και η SD εικόνα ήταν μια χαρά....:grandpa:
Έχω την εντύπωση πως "σπάσιμο" στην κίνηση είναι λίγο δύσκολο να οφείλεται σε κάποιου είδους "interpolation". Το IFC μπορεί να προσθέσει τεχνουργηματάκια όπως ουρές, halo κλπ, αλλά τα "σπασίματα" συνήθως οφείλονται σε μετατροπές του ρυθμού ανανέωσης του εισερχόμενου σήματος.
Πριν φτασουμε στο οτι φταιει η τηλεοραση αρχιζουμε απο τα βασικα , μηπως φταιει η κεραια , τα καλωδια , το σημα , ο δορυφορικος δεκτης κτλ. απλως ανεφερα το IFC επειδη το ειδα σε ξενα φορουμ , οχι μονο στο παραπανω αλλα και σε αλλα.
Παντως με τα χαλια που εχουν τα Ελληνικα καναλια ειναι πολυ πιθανο να βρισκεται καπου αλλου το φταιξιμο και οχι στην τηλεοραση.
Εμ για αυτό το λόγο έγραψα να τσεκάρει πρώτα τον δέκτη του.....
Αυτο του ειπα να κανει να ρυθμισει αν μπορει τον δεκτη του και μου ειπε οτι και οταν ειχε τον αποκωδικοποιητη της nova το εκανε παλι.Τελος παντων θα το ξανατσεκαρουμε και βλεπουμε.
Ε καλά ο δέκτης της ακατανόμαστης δεν είναι και ότι καλύτερο.....
46 pz8e επειγον...ωρες και ανεμιστηρες...
αγορασα σημερα την τηλεοραση του θεματος και στην παραδοση διαπιστωσα:
1) η κουτα ηταν μεν κλειστη αλλα δεν ειχε τις 2 πλαστικες ταινιες που ειχε η αντιστοιχη συσκευασια της 5090Η που πηρα απο το ιδιο μαγαζι.
2) το πλαστικο καλυμμα στο εσωτερικο δεν ηταν κολημμενο με σελοτεϊπ.
3) ενω εχει 5 θεσεις για ανεμιστηρες στο πισω μερος του πανελ φαινονται απο μεσα απο τις τρυπες να υπαρχουν μονο 4 ανεμιστηρες.
a) παρακαλω καποιον που ειναι κατοχος της tv αν μπορει να βοηθησει γιατι θελω να βεβαιωθω πριν πω τιποτα...
b) πως μπορω να δω ποσες ωρες λειτουργιας εχει η tv?
κατα τα λοιπα ολα μια χαρα με την tv.
Re: 46 pz8e επειγον...ωρες και ανεμιστηρες...
Για τους ανεμιστήρες έχει ξαναγραφτεί, άρα είναι φυσιολογικό.
Για να δεις τις ώρες λειτουργίας
...με πατημένο το -V στο front panel, πατάς τρεις φορές το 0 στο τηλεκοντρόλ...θα σου εμφανιστούν δύο πίνακες ...κάτω δεξιά αναγράφονται οι ώρες λειτουργίας και το πόσες φορές έχει ανοίξει η τηλεόραση....
ΠΡΟΣΟΧΗ...μη πατήσεις κανένα αριθμητικό ή πλήκτρο με χρώμα, στο τηλεκοντρόλ...
...για να βγεις από το Service Menu...είτε κλείνεις την τηλεόραση από τον διακόπτη on/off....είται πατάς exit στο τηλεκοντρόλ...
http://www.avclub.gr/forum/showpost.php?p=506367&postcount=1193
Μεταφέρω το μήνυμα σου στο νήμα με τις υπόλοιπες PZ :a0210:
Από ανεμιστήρες καλά έχεις 4......
πλαστικές ταινίες ???? τι εννοείς ???
προφανώς συγκρίνεις το πως ήταν πακεταρισμένη η κουρο, δεν πρέπει να υπάρχει σχέση !!!!
