- 17 June 2006
- 10,573
- Model No. PD7130/PD7150 DLP Front Projector
- DLP Panel Display method: PD7130 → 0.65” WXGA, DC3
- Device method: Digital Light Processing (DLP®)
- Display Type DLP Chip, RGB optical shutter method Resolution 1280 x 720 pixels
- Lens 7130: F2.4~2.5, f=19.1~23.9
- Projection Lamp 250 W / 200 W switchable UHP lamp
- Input Sources Video VGA, YCbCr, YPbPr1, 2 CVBS (Composite Video), S-Video, DVI-D, Control RS 232 (For computer), IR Receiver, 12V trigger
- Computer Compatibility VGA, SVGA, XGA, SXGA
- 2D Lens Shift Ability Up/Down: +115%/-100%, Left/Right: ± 15%
- Brightness: 900 ANSI Lumen
- Digital Keystone Correction 2D keystone correction
- Projection Lens Zoom lens with manual focus and manual zoom adjust
- Contrast Ratio PD7130: 4500:1
- Uniformity 90%
- Screen Size 30 ~ 300 inches
- Throw Ratio (16:9) 1.34:1 ~ 1.68:1
- Aspect Ratio 16:9 Native
- Projection Distance 1.7 m ~ 5.7 m
- Video Enhance 4-Line Y/C separation(2D) DLTi, DCTi
- Projection Method Front / Rear, Desktop / Ceiling
- OSD Control Projector keypad
- IR remote control
- Video system NTSC 3.58 / NTSC 4.43 / PAL / PAL-M / PAL-N / PAL 60 / SECAM /
SDTV-480i/576i, EDTV-480p/576p, HDTV-720p/1080i
- Dimensions( W x L x H) PD7130: 445 mm x 420 mm x 180 mm (17.5" x 16.5" x 7.1")
- Weight 17.6 lbs
- Power Supply 100 ~ 240 V at 50 ~ 60 Hz
- Power Consumption 370 W (Standby mode < 5W)
- Operating Temperature 5°C to 35°C
- Audible Noise 29dBA (Eco mode)
πηγη....
http://www.cine4home.de/tests/projektoren/Planar/Frame.htm
