- 17 June 2006
- 5,478
Προβολέας 720p Cineversum 70 Ultra με 2680 ώρες λειτουργίας. Ο προβολέας είναι πλήρως λειτουργικός, αλλά θα χρειαστεί σύντομα καινούργια λάμπα.
Optimum Diagonal.......70" to 120"
Optimum Base............150 to 270 cm
Technology.................single chip DLP™
Color Wheel................6 segments (RGBRGB)
Color Refresh..............5x NTSC / 6x PAL
Chip Type...................Darkchip3™
Resolution..................1280x720
Contrast Ratio............> 3800:1
Lens..........................1.40:1 - 1.80:1
Aperture......................No
Vertical Shift...............Manual - 0% +55%
Horizontal Shift............No
Zoom and Focus...........Manual
Lamp..........................250W UHP
Lifetime.......................> 1500 hours (on average)
Light Output................typical 1200 ANSI lumens
Inputs.........................1 Composite Video (1 RCA) / 1 S-Video (4 pin mini DIN) / 1 Component (3 RCA) / 1 RGBHV or Component (5 RCA) / 1 HDMI (/w HDCP)
Control........................RS-232 Control
12V Trigger.................2x (power/masking)
Main Voltage Range.....90-230V AC / 50-60 Hz
Width..........................449 mm - 17.7"
Height..........................156 mm - 6.2"
Depth..........................420 mm - 16.6"
Weight........................7,9 kg - 17.4 lbs
Τιμή: 200 , Αθήνα
Τιμή: 200 , Αθήνα
