Πως είναι ένα βίντεο σε ανάλυση 10K (10328×7760)
Sotiris
7,030
http://www.videoman.gr/73848
Οι πληροφορίες βέβαια που έχει από κάτω είναι λίγο μουφα.
Πως ειναι δυνατόν να έχεις τέτοια λεπτομέρεια με zoom στο video;
Αυτό είναι καθαρά zoom στον φακό.
Edit: Εδώ εξηγεί σωστά τον τρόπο.
https://www.youtube.com/watch?v=vGtGVMqKdwA
"10328x7760 - A 10K Timelapse Demo" is a video I put together showcasing the extreme resolution of the PhaseOne IQ180 camera of which it was shot. This footage comes from some shots I did while shooting 4K and 8K timelapses in Rio De Janeiro for a major electronics manufacturer. Each shot is comprised of hundreds individual still images, each weighing in at a whopping 80 megapixels. Each individual raw frame measures 10328x7760 pixels.
Each shot was very minimally processed and included curves, input sharpening, saturation adjustments. The h264 compression really kills alot of the fine detail. No noise reduction was done on any of the shots. I tried to keep the shots as close to raw as possible so you may see some dust spots, noise, and manual exposure changes I made while shooting. For a final video edit these adjustments would be smoothed out and fixed. Normally I run shots where I manually change exposure during the shot through LRTimelapse, but unfortunately the program can't seem to handle such huge raw files. I also had to loop some shots in order to have enough runtime to do some zooms, so you may see a jump in the footage here and there.
Each shot sequence starts off with the full resolution footage scaled down to fit within a 1920x1080 resolution (14% scale). The next shot in each shot sequence is the full resolution shot scaled to 50%, so basically zooming in quite a bit. From there we go into the full resolution shot scaled to 100%, which is an extreme zoom/crop. As you can see, the quality and detail holds up extremely well, it’s pretty amazing.
I wanted to show a couple things with this demo video. First, the extreme resolution of this camera (and medium format in general). Second, the amazing amount of flexibility this resolution allows for in post production. You can literally get about 8-10 solid 1920x1080 shots out of a single shot. You can also get about 5-6 solid 4K shots out of a single shot.
If you enjoyed this demo videos please feel free to pass it around and share it. If you enjoy my work, or want to see some of my other work (including the full Rio video) you find me on all the social media outlets below.
BEST VIEWED FULLSCREEN IN FULL HD
