provlima meta thn allagi ths lampas help!
atsala
5 April 2009
1
eimai katoxos provolea benqmp610 kai alaksa thn lampa to provlima oti meta thn allagh den mporo na kano reset midenismo sto time lamp kai o projectoras klini se 40 deyterolepta. h odigies pou diabasa sto manual einai aytes alla den antapokrinete(Press and hold the Exit 5 button on the
projector for 5 seconds to display the total used
lamp time.
ii. Press Auto on the projector or on the remote
control to reset the lamp hour to “0”.
iii. Wait about 5 seconds to let the OSD disappear. eyxaristo ek ton proteron...:))
