REDRAY player
Alexandros_Wallace
3 June 2007
4,193
Dystopia
4K FOR ALL
RED puts $1,450 Redray Player up for pre-order, stakes a claim to 4K video with proprietary format and Odemax distribution platform
Υλικό μέσο σκληρού ή μέσω δικτύου όπως γίνεται και στον ψηφιακό σινεμά.
Tech Specs:
[TABLE="class: table table-striped, width: 100%"]
[TR]
[TH="bgcolor: #111111"]DIMENSIONS[/TH]
[TD="bgcolor: #111111"]316x215; 61mm x 260 mm ( 12.4 × 2.4 × 10.2″ )[/TD]
[/TR]
[TR]
[TH="bgcolor: #1A1A1A"]WEIGHT[/TH]
[TD="bgcolor: #1A1A1A"]5.9 Lbs[/TD]
[/TR]
[TR]
[TH="bgcolor: #111111"]MATERIAL[/TH]
[TD="bgcolor: #111111"]Aluminium[/TD]
[/TR]
[TR]
[TH="bgcolor: #1A1A1A"]OPERATING TEMPS[/TH]
[TD="bgcolor: #1A1A1A"]Zero to 40 C[/TD]
[/TR]
[TR]
[TH="bgcolor: #111111"]STORAGE TEMPS[/TH]
[TD="bgcolor: #111111"]Minus 5 to 60C[/TD]
[/TR]
[TR]
[TH="bgcolor: #1A1A1A"]NOTABLE FEATURES[/TH]
[TD="bgcolor: #1A1A1A"]Network based 4K 3D Playback System.[/TD]
[/TR]
[TR]
[TH="bgcolor: #111111"]ADDITIONAL NOTES[/TH]
[TD="bgcolor: #111111"]Unique to RED, this product is the only available 4K resolution signal source for Ultra HD flat panel dispays and 4K projectors, may also be used for digital signage applcations to drive up to four 1080p displays.[/TD]
[/TR]
[TR]
[TH="bgcolor: #1A1A1A"]RESOLUTION[/TH]
[TD="bgcolor: #1A1A1A"]Up to 4096 × 2160 pixels, 2D or 3D[/TD]
[/TR]
[TR]
[TH="bgcolor: #111111"]BIT-DEPTH (COLOR)[/TH]
[TD="bgcolor: #111111"]YCbCr 12-bit 4:2:2 or RGB 8-bit 4:4:4[/TD]
[/TR]
[TR]
[TH="bgcolor: #1A1A1A"]COLORIMETRY[/TH]
[TD="bgcolor: #1A1A1A"]ITU-R BT.709[/TD]
[/TR]
[TR]
[TH="bgcolor: #111111"]PROGRAM OUTPUT[/TH]
[TD="bgcolor: #111111"]4K DCI, UltraHD, 1080p, 720p[/TD]
[/TR]
[TR]
[TH="bgcolor: #1A1A1A"]PREVIEW OUTPUT[/TH]
[TD="bgcolor: #1A1A1A"]1080p, 720p[/TD]
[/TR]
[TR]
[TH="bgcolor: #111111"]MEDIA SECURITY[/TH]
[TD="bgcolor: #111111"]REDCrypt™ digital media encryption[/TD]
[/TR]
[TR]
[TH="bgcolor: #1A1A1A"]DRM OPTIONS[/TH]
[TD="bgcolor: #1A1A1A"]ODEMAX™ digital rights management[/TD]
[/TR]
[TR]
[TH="bgcolor: #111111"]REMOTE CONTROL[/TH]
[TD="bgcolor: #111111"]IR, 802.11n, Ethernet[/TD]
[/TR]
[TR]
[TH="bgcolor: #1A1A1A"]GENLOCK[/TH]
[TD="bgcolor: #1A1A1A"]RS170A Tri-level Sync[/TD]
[/TR]
[TR]
[TH="bgcolor: #111111"]PLAYBACK FRAME RATES[/TH]
[TD="bgcolor: #111111"]24, 25, 30, 48, 50, 60 fps[/TD]
[/TR]
[TR]
[TH="bgcolor: #1A1A1A"]DIGITAL MEDIA[/TH]
[TD="bgcolor: #1A1A1A"]Internet download, SDCard or USB-2 flash media[/TD]
[/TR]
[TR]
[TH="bgcolor: #111111"]VIDEO FILE FORMAT[/TH]
[TD="bgcolor: #111111"].RED (4K), .MP4 (1080p, 720p)[/TD]
[/TR]
[TR]
[TH="bgcolor: #1A1A1A"]AUDIO FILE FORMAT[/TH]
[TD="bgcolor: #1A1A1A"].RED (up to 7.1 Ch) .MP4 (Stereo)[/TD]
[/TR]
[TR]
[TH="bgcolor: #111111"]AUDIO OUTPUT[/TH]
[TD="bgcolor: #111111"]Up to 7.1 channel LPCM, 24-bit 48Khz[/TD]
[/TR]
[TR]
[TH="bgcolor: #1A1A1A"]OUTPUT CONNECTORS[/TH]
[TD="bgcolor: #1A1A1A"]4 x HDMI 1.4 (Program), 2 x HDMI 1.3 (Preview and Audio)[/TD]
[/TR]
[TR]
[TH="bgcolor: #111111"]STORAGE CAPACITY[/TH]
[TD="bgcolor: #111111"]1TB Internal SATA Drive[/TD]
[/TR]
[TR]
[TH="bgcolor: #1A1A1A"]POWER[/TH]
[TD="bgcolor: #1A1A1A"]120 – 240V 50 – 60Hz A.C.[/TD]
[/TR]
[/TABLE]
Full Press Release:
RED Digital Cinema is now taking pre-orders for the REDRAY® 4K Cinema Player.
With the recent launch of 4K resolution displays and projectors into the Consumer Electronics market, REDRAY fills a crucial role as an OTT network based appliance, and is the first media source capable of providing true 4K content to these displays.
REDRAY's debut will come as no surprise to those who have followed RED closely, yet the specs and capabilities of REDRAY are sure to generate excitement from cinema purists and consumers alike. Future-proof resolution and wide dynamic range and have contributed to the rapid growth of 4K imaging for cinema and advertising.
Along with playing 4K .RED files, REDRAY features the ability to play back and upscale H.264 based HD files to Ultra HD resolution (3840×2160). Compared to existing distribution methods such as Blu-ray, which are limited to 8-bit, 4:2:0 color precision, REDRAY supports up to 12-bit 4:2:2 color precision to eliminate image artifacts and deliver a truly cinematic visual experience.
Equally impressive as the output fidelity is REDRAY's exceptionally low 4K data rate averaging less than 2.5MB/s, which means a .RED file can deliver a feature-length film at full 4K resolution on a USB flash drive or via an OTT media network. With 1TB of internal storage, REDRAY supports up to 100 hours of 4K content.
REDRAY 4K media is protected against piracy by REDCrypt file encryption and supports optional ODEMAX™ digital rights management.
REDRAY connects to your HD or 4K TV/Projector via a single HDMI 1.4 cable, or four HDMI 1.3 cables, plus a dedicated HDMI output for 7.1 channel 24-bit 48KHz surround sound audio. For those interested in digital signage, a single REDRAY can simultaneously drive up to four HD panels or two 4K displays creating an immersive advertising opportunity for those looking to expand their branding.
REDRAY is the only 4K 3D playback system to support high frame rate playback (4K 3D at 48 or 60fps), allowing viewers the opportunity to experience the very latest technical developments in 3D filmmaking. Using the included IR remote or the REDRAY iOS application (available from the Apple App Store), users can connect to REDRAY via wireless network to select and manage their 4K and HD content, stored on the internal 1TB capacity hard disk drive.
Pre-order a REDRAY now. Volume shipments to commence in Q1 2013.
In 2006, RED Digital Cinema began a revolution with the 4K RED ONE digital cinema camera. By 2008, the camera that changed cinema also began to change the world of stills. The same camera being used to shoot features like The Hobbit and The Girl with the Dragon Tattoo was being used to shoot covers for magazines such as Vogue and Harper's Bazaar. Additionally, the 5K EPIC and SCARLET cameras are built around a modular foundation that gives the flexibility of full customization for each shoot. For more information, visit www.red.com.
Gallery:
Περισσότερα:
RedStore
Redray 4K Cinema Player is ready to pre-order: $1,450 for high-res, high framerate home viewing
και η εταιρεία που θα αναλάβει τη διανομή...
http://odemax.com/
ODEMAX.COM Distribution Platform for REDRAY
ODEMAX delivers the only comprehensive distribution platform for 4K movies. Designed to exclusively support the REDRAY Player and CRIMSON Projection systems from RED Digital Cinema, ODEMAX.COM is an all-inclusive environment for home and theatrical delivery of feature films, with built-in digital rights management, sales, marketing and analytics tools. ODEMAX provides filmmakers, production companies and independent distributors, direct channel access to the new cloud enabled REDRAY 4K home players.
DISTRIBUTOR ACCESS: January, 2013
HOME & THEATRICAL SERVICE: March, 2013
[email protected]
σίγουρα περιμένουμε καλύτερα πράγματα από αυτά που ξεκινάει η sony.
Οπως την βλέπω τη δουλειά θα έχουμε διαφορετικό υλικό, διαφορετικά φορμά αλλά με πιο universal χαρακτηριστικά.
Πιο πολύ θα δουλεύουμε με digital downloads και με κέντρα διανομής υλικού ανάλογα τα γούστα και την χρήση.
Φαντάζομαι κάτι αντίστοιχο με αυτό που γίνεται τώρα στη μουσική.
Μπορείς να ακούς τσάμπα χαμηλής ποιότητας μουσική από το youtube, soundcloud, mixcloud
να αγοράζεις mp3 από το itunes, amazon και να αγοράζεις ΗR . flac από το hdtracks ή DSD από το 2L.
Ε φαντάζομαι ανάλογα τις απαιτήσεις, το χρήμα και το HW κάτι αντίστοιχο θα συμβεί και για την εικόνα.
Hδη έχουμε τα netflix , hulu, itunes movies.
Η sony και οι φίλοι της, θα το παλέψουν λογικά για δισκάκι αλλά δεν νομίζω να επιβιώσει.
Από τη στιγμή που τα studio δεν κάνουν τίποτα από πίσω, δεν νομίζω να πάμε σε νέο στανταρ όπως
είχαμε παλαιότερα το DVD ή το BluRay.
Δηλαδή και να ανακοινωθεί κάτι επίσημα δεν νομίζω να *πάει*.
Κάτσε να δούμε και τι θα γίνει τελικά με τα H265/VC-2.
Αν ο player όμως είναι κλειδωμένος σε εναν πάροχο; Ίδιο αποτέλεσμα!
Δεν κατάλαβα τι ακριβώς εννοείς.
Αφού μιλάμε για πληρωμένες υπηρεσίες προφανώς και θα υπάρχουν κλειδώματα κάθε είδους.
Δεν θα αλλάξει κάτι τώρα.
Εννοώ οτι παλι θα έχουμε φορμάτ war αλλά όχι με δισκάκια. Δηλαδή το αν θα έχουμε ως πηγή σάιτ η σκληρούς δίσκους δεν αλλάζει κάτι.
Να το ξανα πω άλλη μια φορά γιατί μπορεί να το διατύπωσα λάθος.
Θα παλέψουν πάρα πολύ να πείσουν το ευρύ κοινό οτι αξίζει το upgrade στα 4Κ και σε ότι άλλο βγάλουν,
οπότε δεν τους παίρνει να ρισκάρουν σε πόλεμο format.
Το βλέπεις ότι όλες οι εταιρείες βγάζουν τηλεοράσεις 4Κ με hdmi.
Αυτό λέει πολλά για το οτι θέλουν να αποφύγουν θέματα συμβατότητας.
Δεν έχει σκοπό κανένας να το μπλέξει περισσότερο το θέμα.
Υποθετικά μιλώντας , ότι και να βγάλουν και ότι περιορισμοί προκύψουν θα έχουν να κάνουν καθαρά με θέματα πόρων και κλειδώματος.
