Samsung 40Α656 vs Panasonic 42PX80 vs Sony40D3500 vs JVC 42DS9
samsung A656
* Excellent black level with decent shadow detail
* Very good standard-def video processing (especially video and film mode deinterlacing)
* Comprehensive set of picture adjustment controls available in user menu (including white balance and a rudimentary colour management system)
* [100Hz Motion Plus] reduces motion blur (but may cause interpolation artefacts; see Cons)
* "Just Scan" allows for exceptional detail from 1:1 pixel mapping
* Displays 1080p/24 video signal from Sony PS3 without exhibiting telecine judder
* Generous connectivity with 4 HDMI 1.3 input, USB port, etc.
* Settings can be stored independently for each input
* Can accept and display 1920x1080 progressive video signal over VGA
* User menu and EPG navigation quicker and more responsive than last year's models
* Swivelling table-top stand comes pre-attached out-of-the-box for quick setup
Cons
* [100Hz Motion Plus] may introduce interpolation artefacts like tearing, stutter or shimmering around moving objects
* Shiny "Ultra Clear Panel" reflects ambient light and causes glare
* Mild input lag (except in "Game" mode or over VGA) may affect sensitive gamers
* Some clouding and backlight unevenness (though reduced to unobtrusive levels after calibration)*
* Slight low-pitched hum from back of TV unless the screen is very bright*
sony 40w4000
* Accurate primary colours with excellent decoding
* Exquisite high-definition detail from "Full Pixel" 1:1 pixel mapping
* Handles 1080p/24 video signal correctly without telecine judder
* [Film Mode] "Auto" can deinterlace film-based 1080i material to 1080p without resolution loss
* Better than average scaling of standard definition content
* Solid connectivity with 3 x HDMI 1.3, USB input, etc.
* TV speakers deliver impressive resolution, soundstage and dynamic range
* Settings can be saved independently per input
* Speedy and responsive EPG and channel navigation
* Table-top stand swivels and easy to set up
Cons
* No white balance control in user menu for greyscale calibration
* Motion resolution not as good as those on HDTVs equipped with MCFI/ 100Hz technology
* Fails to apply 3:2/ 2:2 pulldown to 480i/ 576i film-based content even with [Film Mode] set to "Auto"
* Backlight setting not saved if the Sony KDL40W4000 does not go into "true" standby mode
* XMB user menu rendered in lower resolution and lags intermittently
* Slight clouding and LCD backlight bleed (though negligible once calibrated)
* Mild low-pitched electronic hum from back of TV (not a problem at normal sitting distance and TV volume)
ολα σε ενα ......συγκεντρωμενα
So, in LE40A656, has Samsung finally come up with a candidate that can mount a serious challenge to Sony Bravias at the top of the LCD hill? We believe so. Make no mistake, the Sony Bravias still hold the edge in colour balance and gaming response. And when present, their 100Hz MCFI technology is slightly more accomplished than Samsung's. But with standard-definition video processing, connectivity and most importantly price stacked firmly in Samsung's favour, the future looks extremely rosy for the LE40A656 indeed.
Απο οτι καταλαβα το scaling ειναι το ιδιο καλο και στις δυο τηλεορασεις απλως σε καποιες Αμερικανικες σειρες οπως το CSI λογω του 2:2 pulldown της Samsung δειχνει καλυτερα.
Συμφωνώ..
Η Sony εχει πιο accurate χρωματική απόδοση, η Samsung εχει τα 100Hz
Τελικα ζυγίζοντας +- και οι 2 τηλεοράσεις ειναι αστέρια δινοντας στους υποψήφιους αγοραστές πολύ καλό value/money.
Απάντηση: Re: Samsung 40Α656 vs Panasonic 42PX80 vs Sony40D3500 vs JVC 42DS9
Ρε παιδιά κατι που μου έκανε εντύπωση ειναι η μεγάλη πτώση στην κατανάλωση μετά το calibration (εαν κατάλαβα καλά)
223 Watt πριν, 99 μετά ..
Είναι δυνατόν ?
http://www.hdtvtest.co.uk/Samsung-LE40A656/Calibration.htm
Ναι Γιώργο, έχουμε αναφερθεί και στο παρελθόν για αυτό και ισχύει για όλες τις τηλεοράσεις. Στην ρύθμιση "δυναμική" το backlight είναι στο 10 και μετά από calibration πάει στο 1-2, άρα δεν καίει τσάμπα η λάμπα. -bye-
Και το "Ηχος-Εικονα" νομιζω στα 109 Watt την ειχε μετρησει.
Δηλαδη περιπου τα μισα απο μια αντιστοιχη πλασμα 42".
