Samsung PS C7000 / C6900 Plasma : Reviews - Εντυπώσεις - Σχόλια
Samsung C8000 / C7700 review
http://www.flatpanelshd.com/review.php?subaction=showfull&id=1283773778
...After calibration I measured a black level of 0.06 cd/m2. Before calibration I measured a black level of 0.18 cd/m2. Let me include some words to this strange result that is very uncommon on Plasma-TVs because they tend to have almost identical black level before and after calibration.
On this TV I saw very different black level values before and after calibration so I dug deeper to examine why this was happening. I found that the TV has far worse black level reproduction in the Standard picture mode. When you switch to the Movie mode black reproduction is improved considerably.
I also tested on different signals such as 24 Hz, 50 Hz and 60 Hz and found another strange thing here. With a 60 Hz signal I got deeper black levels than with a 50 Hz signal. This obviously have something to do with the driving method and sub-pixel refresh but it’s not supposed to do this.
However, the biggest change in black levels still occurred when switching between the Standard and Movie mode. On the Standard picture preset I measured 0.18 cd/m2 black with a 60 Hz signal. The black level was improved drastically when I switched to the Movie mode.
After I selected the Movie picture mode I measured 0.06 cd/m2 (with 60 Hz) which is not as low as last year’s B850 (that had 0.05 cd/m2) but probably what we have to settle with on the new 3D panel that is brighter and a bit different. This is a compromise from Samsung in the process of chasing that 3D picture quality. We can live with it but we also have to say that Panasonic is now in front again when it comes to black levels with their VT20 / VT25.
You have to be sure to select the movie preset, however. Also, don’t activate the Cinema Smooth option during Blu-ray playback as this will do the same thing. If you’re a European you have a 50 Hz TV-signal coming in. With a 50 Hz input on the Samsung TV the black level is not as low as with a 60 Hz or 24 Hz (Blu-ray) input. This is a potential problem but again; the most significant change was between the Movie and Standard preset so I don’t regard this as a critical problem. Just stay on the movie preset.
Conclusion
Samsung’s first 3D plasma TV has a lot of media functionality and we have also come to expect this from Samsung in the recent years. It incorporates Internet Apps, the best DLNA from any TV manufacturer, USB recording (on the EU model) and many calibration setting options. We did hear some very low buzzing but in practical use I never found it irritating.
Picture quality is in the elite of flat panel TVs today. The B850 from 2009 convinced us and C8000 (in the US) / C7700 (in EU) build on that foundation. I don’t see it as a major improvement compared to B850 but that’s not a bad thing because it puts it in the top of the picture quality scale today.
We saw very good picture characteristics such as accurate colors, low response time and low phosphor trailing. The picture is very detailed and HD picture quality is just beautiful. However, black reproduction is slightly higher than on the B850 and you have to use the Movie preset to get decent black levels. Also, retention has not yet been eliminated on C8000 / C7700.
The 3D picture quality is very good and very close to that of Panasonic VT20 / VT25. We saw only very little crosstalk, the 3D depth is good and the overall 3D picture quality is much better than on Samsung’s LCD/LED 3D models such as the C8000 LED model. The colors in the 3D mode are not very accurate but this is true for all 3DTVs at the moment. The new panel can also output enough light for decent 3D viewing during the day.
Samsung has once again released a very interesting plasma-TV and it’s definitely competing with some of the flagship models, and is an alternative to the highly praised Panasonic plasma-TVs. The very slim design, impressive picture quality and 3D picture quality at a very attractive price, makes C7700 (in EU) / C8000 (US) extremely tempting.
Απάντηση: Re: Samsung PS C7000 / C6900 Plasma : Reviews - Εντυπώσεις - Σχόλια
Διοτι δεν υπαρχει λογος να δωσει κανεις παραπανω λεφτα για να αγορασει ενα πακετο που το "κυριως πιατο του" ειναι τεχνολογικα υποδεεστερο (εστω και ελαφρα) αυτουνου που ερχεται και απο τα υπολοιπα γλυτωνει 80-90 ευρω για τα γυαλια και παιρνει και ενα Player που πρακτικα δεν το χρειαζεται (μιας και η τηλεοραση κανει το 90+% αυτων που κανει το player)
Me 1373 ευρουλακια θα παρω την C7000, ασε που υποψιαζομαι οτι η συγκεκριμενη θα περιλαμβανει και γυαλια....
Και τα 3D bluray δισκάκια θα τα παίζει μόνη της η τηλεόραση ??
Εκτός κι αν διαθέτεις,ήδη,3D bluray player....
Re: Απάντηση: Re: Samsung PS C7000 / C6900 Plasma : Reviews - Εντυπώσεις - Σχόλια
Οσο και αν σου φαινεται απιστευτο....αν εχεις το υλικο 3d περασμενο σε σκληρο..το παιζει απο κει ανετα....
Το εχει δοκιμασει φιλος μου και ειδα στην Ηλεκτρονικη στην Κηφησιας (απεναντι απο το MEDIAMARKT) να παιζει η LED C7000 3D ταινιουλα απο σκληρο!
Ενημερωση απο Κωτσοβολο.
Περασα απο τον Κωτσοβολο στην Συγγρου.
Η προσφορα υπαρχει αλλα το το Bluray ειναι το 5900 και οχι το 6900 και τα 3d γυαλακια που δινουν δεν ειναι τα επαναφορτιζομενα αλλα καποια με μπαταρια (και καπως ασχημουτσικα...χαχα)
Samsung BD-C5900 !!! Tweet me! ΗD Players & Recorders - Blu-ray Players Κυριακή, 13 Ιούνιος 2010 12:20 Next 3D Blu-ray....
Φέτος η Samsung, έχει ρίξει στην αγορά πολύ γερά Blu-ray players. Και το κρίνουμε από τον τομέα της ποιότητας. Σε λίγο θα είναι και πολλά από άποψη 3D εικόνας...
Η πληροφορία είναι αποκλειστική και σίγουρη.
Το νέο που θα μάθουν εν καιρώ και οι άλλοι, είναι ότι η Samsnug θα ρίξει στην αγορά ένα νέο 3D Blu-ray player.
O κωδικός του θα είναι ΒDP-5900, θα έχει κοινό DNA με το BDP6900 και φυσικά θα αποτελεί μία πιο προσιτή επιλογή.
Το πότε θα λανσαριστεί δεν το γνωρίζουμε. Αυτό που γνωρίζουμε είναι ότι θα φέρει ενσωματωμένη την 3D λειτουργία. Εννοούμε δηλαδή ότι δεν θα είναι 3D ready ώστε να χρειάζεται Firmware update.
Δεν υπάρχει για να την δεις ζωντανά. Και από ότι ξέρω ήρθαν ελάχιστες στην Ελλάδα είχε μια το Πλαίσιο για ετοιμοπαράδοτη δεν ξέρω αν υπάρχει ακόμη . Είναι η ίδια με την 50´αν θες 63´θα σου σύστηνα να την πάρεις, αν την βρεις θα είσαι πολύ τυχερός.
Κάθε μαγαζί Κωτσόβολος είναι φραντσαΐζ , οπότε κάνει ότι θέλει, αυτό έμαθα, γι αυτό υπάρχουν αυτές οι διαφορές στις προσφορές.
Αυτο που λες ΔΕΝ μπορει να αφορα τις κεντρικες προσφορες του φυλλαδιου.
Οτι ειναι στο φυλλαδιο ισχυει.
Για προσφορες εκτος φυλλαδιου ισως και αν ισχυει αυτο ('χ για κομματια εκθεσιακα...κοκ).....αν και το franchise γενικα δεν συνεπαγεται "ανεξαρτητη πολιτικη".....
Πήγαν δυο φίλοι για την προσφορά σε δυο διαφορετικά μαγαζιά του Κωτσοβολου, τους έδωσαν διαφορετική προσφορά , δηλαδή άλλο Blue Ray-ο ένας το 5900 και ο άλλος το Home Theater- και ο ένας 12 άτοκες δόσεις και ο άλλο καθόλου άτοκες δόσεις.
Καλημέρα ο κολλητός μου θέλει να πάρει τι συγκεκριμένη τηλεόραση σε 50 ίντσες .
Με έβαλε να ρωτήσω 2-3 πράγματα αν λέει σε 3d σαν τι πανασονικ? H μετατροπή από 2d σε 3d αν λέει? Και το τελευταίο αν σε παιχνίδια στο ps3 η στο 360 παίζει καλά στις γρήγορες κινήσεις τον game. Άλλο ένα που τον απασχολεί είναι και το ποδόσφαιρο παίζει καλά χωρίς προβλήματα?
Ευχαριστώ περιμένουμε τις απάντηση σας
ΥΓ. να περιμένει την 7000 η να πάρει την 6900 καθότι τρελαμένος να τη πάρει τώρα?
1) Λέει σαν την Panasonic, δηλαδή οι πενήντα ίντσες είναι λίγες. Η απόσταση για 3D πρέπει να είναι 2 μέτρα για να την ευχαριστηθείς.
2) Η μετατροπή από 2D→3D λέει, εφόσον σου αρέσει αυτό το μέγεθος . Σκέψου πως και η Panasonic ανακοινώσε καινούργια μοντέλα με μετατροπή 2D→3D.
3) Στην γρήγορη κίνηση η Plasma είναι κορυφαία καμία σχέση με LCD . Αυτό σημαίνει πολύ καλή για παιχνίδια και ποδόσφαιρο .
4) Όσο για το 6900 ή 7000 δεν μπορώ να σου απαντήσω, εγώ πήρα την 6900 γιατί δεν ξέρω αν φέρουν ποτέ στην Ελλάδα την 7000 ή την 7700 και ποτέ.
Στα 3.5 μέτρα θα χει τη τηλεόραση άπλα επειδή έχει δη τι πανασονικ (δεν έχει το χρήμα να τη πάρει) φοβάται μην είναι η μέρα με τη νύχτα.
Ξέχασα να σας ρωτήσω και για το pc που θα το ενώσει και αυτό επάνω θα έχει πρόβλημα με τις στατικές εικόνες?
Ευχαριστούμε για την απάντηση
Δεν υπάρχουν πελώριες διαφορές , αλλού μπορεί να σου αρέσει η μια και αλλού η άλλη.
Στην αρχή στο στρώσιμο καλό είναι να μην την αφήνει πολύ ώρα σε μια στατική εικόνα , βεβαία δεν πρέπει να τρελαινόμαστε πολύ και με αυτό το στρώσιμο.
Το κακό είναι πως πολλά πράγματα τα έχουμε κάνει επιστήμη , παλιά αγοράζαμε τηλεόραση δεν προσέχαμε τίποτα και έπαιζε μια χαρά ,τώρα με όλο αυτό το marketing μας έχουν κάνει την ζωή μας δύσκολη, μας γεμίζουν φόβους για να μπορούν να μας ελέγχουν.
Re: Απάντηση: Samsung PS C7000 / C6900 Plasma : Reviews - Εντυπώσεις - Σχόλια
Οι 50 ίντσες στα 3,5 μέτρα είναι μια χαρά, στο θέμα πια είναι η καλύτερη η Panasonic or sam.το καλύτερο είναι να τις δει με τα δικά του ματιά, διότι οι προτιμήσεις του καθενός είναι διαφορετικές.
Στο θέμα του στρωσίματος συμφωνώ με τον takisspanos το παρα…
Να σας πως πια είναι καλύτερη η Panasonic ή Samsung δεν μπορώ να πω, την Panasonic την έχω δει πάρα πολλές φόρες σε πολλά καταστήματα με ένα υλικό πάρα πολύ καλό, επίσης την είδα στην έκθεση 3D και πράγματι ήταν ενθουσιώδη. Ήταν πολύ προσεγμένος ο χώρος και ο φωτισμός. Εμένα προσωπικά μου άρεσε πιο πολύ η V20 από την VT20. Στο σπίτι μου η Samsung παίζοντας ένα βιντεακι που χρησιμοποιεί η Panasonic ΝΟΜΙΖΩ πως η Panasonic στο 3D παίζει καλύτερα, δεν έχω δει κάποιο ολοκληρωμένο έργο όποτε μονό υπολογισμούς μπορώ να κάνω. Στο 2D η Samsung σκοτώνει είναι απίθανη , πραγματικά τρισδιάστατη, βάθος πεδίου, διαύγεια, απίθανο μαύρο, πιστεύω πως είναι πάρα πολύ καλή .
Και να συμπληρώσω σε μισή περίπου τιμή από την πανί. 2500 ευρώ για t.v. είναι πολλά, σε 2-3 χρόνια και πολύ λέω θα θεωρούνται ξεπερασμένες.
Samsung plasma 63" - PS637700
Παιδιά καλημέρα,
Καινούργιος στο club. Είμαι σε αναζήτηση της 63άρας plasma της Samsung PS63c7000 αλλά υπάρχει ένα πέπλο μυστηρίου σχετικά με το αν/πότε θα έρθει στην Ελλάδα. Ψάχνοντας στο internet βρήκα διαθέσιμη σε διάφορα on-line stores με έδρα το εξωτερικό (pixmania, expansys, open247) την PS63c7700, η οποία καταλαβαίνω οτι είναι η ίδια τηλεόραση και σε αρκετά καλή τιμή. Καταλαβαίνω επίσης οτι πρόκειται για παραεισαγωγή (με international εγγύηση κανονικά) παρακάμπτοντας τον Φουρλή.
Θα αγοράζατε ποτε έτσι; Αν την παραγγείλω στην Ελλάδα (Πλαίσιο κτλ) είναι άγνωστο το πότε θα έρθει. Επίσης με φοβίζει η μικρή διαφορά στον κωδικό.
Καμμιά γνώμη;
Να είστε καλά.
Γιώργος
H C7770,αν δεν κανω λαθος, εχει και δορυφορικο δεκτη (οπως η panasonic vt20),που δεν εχει η c7000.Εγω περιμενω το πλαισιο (δηλαδη τον απαδεκτο τον Φουρλη) απο 10/8 για την 63αρα.Πριν κανενα διμηνο ειχα κανει σε νεο ελληνικο ιντερνετοκαταστημα παραγγελεια ,ο οποιος φερνει τα προιοντα απο Γερμανια και ουτε τηλεφωνο δεν με πηραν.
