Sony KD XG9505 / 49XG9005 : Reviews - Εντυπώσεις - Σχόλια
teo GTP
8 November 2009
196
Volos a.k.a Monaco of Thessaly
Εγώ μια xg9505 την πρόλαβα στον κωτσο.
KD XG9505 : F.A.L.D. Direct LED LCD,VA panel (RGB-Vertical stripe),
100/120Hz με MCFI + αναβόσβησμα του οπίσθιου φωτισμού,X-Motion Clarity,
X1 Ultimate,
WCG (aka Triluminos Display, PFS phosphor),
android tv 8.0 (Oreo) upgradable to Android tv 9.0 (Pie) ,
HDR10,HLG,Dolby Vision,IMAX Enhanced,
X-Wide Angle (75",85").
55",65",75",85"
αντικαθιστά την KD XF9005
XG9505 vs XF9005
Παρακάτω οι διαφορές της XG9505 σε σχέση με την XF9005:
X1 Ultimate vs X1 Extreme
X-Wide Angle 75",85",VA panel + wide angle prism filter
Better and faster operating system-new SoC (CPU,GPU,RAM)
Dolby Atmos support
New sound system-Multi Acoustic Audio (πλευρικά tweeter)
Input Lag reduced
new remote control (RMF-TX600E,Silver )
hands free Voice Control-μικρόφωνα στο λογότυπο Sony)
pre-installed Autocal app
XG9505: 4 full 4K/60 HDMI inputs
metal thinner legs
eARC support : yes
new action menu
Netflix calibrated mode
Airplay 2 and HomeKit compatibility will be available via firmware upgrade
XG9505 new SoC :
Platform: Sony BRAVIA UR2
MediaTek MT5893
Installed RAM 2.5 GB
Core Architecture:4x ARM Cortex-A73 @ 1500MHz
CPU Cores:4
GPU Renderer:Mali-G71
Μέσω της εφαρμογής AIDA64
KD65XG9505
True RGB VA-type LCD panel which delivers deep blacks by LED LCD standards. Native ANSI blacks was 0.033 cd/m2 if peak white was set at 120 cd/m2 with local dimming disabled.
-[65"]...F.A.L.D:6 vertical columns x 10 horizontal rows : 60 independently dimmable zones ,
-PFS LED
-DCI-P3 colour gamut coverage : 93,9%
HDR:
Peak Brightness
10% window: 1098 nits on a 10% window after calibration to D65 white point
Full-field: 720 nits
...Sony 's local dimming algorithm is the best in the business.It strikes a wonderful balance between keeping blacks deep and blooming to a minimum.The biggest compliment I can pay to Sony 's local dimming is that it very rarely draws attention to itself,in terms of luminance fluctuations or dimming lag,however given the limited number of local dimming zones ,some blooming or haloing artifacts are inevitable,when there is bright object against dark background,if watched in a pitch-black room,especially in HDR where backlight is driven to maximum,to fulfill the peak brightness demand on high dynamic range HDR content.All high nit LED LCDs in fact ,I strongly recommend the use of some gentle bias lighting to reduce the visibility of blooming and make letterbox bars look darker...
KD49XG9005 :F.A.L.D. Direct LED LCD,VA panel (RGB),
X1 Extreme,
android tv 8.0 (Oreo),
Airplay via app,
3840 x 2160 QFHD -4K UHD.
αντικαθιστά την KD49XF9005 ,η διαφορά είναι στα πόδια της βάσης που στην KD49XG9005 είναι μεταλλικά και πιο λεπτά.Η 49XG9005 (2019) αντικαταστάθηκε από την KD49XH9505 (2020).
KD49XG9005 SoC
Platform : Sony BRAVIA ATV3
MediaTek MT5891
Core Architecture: 4x ARM Cortex-A53
CPU Cores: 4
Installed RAM : 2 GB
GPU Renderer : Mali T-860
GPU Cores : 2
H KD49XG9005 αντικαταστάθηκε το 2020 από την KD49XH9505
KD49XH9505 :F.A.L.D. Direct LED LCD,VA panel (RGB),
X1 Ultimate,
android tv 9.0 (Pie),
HDR10,HLG,Dolby Vision,Dolby Atmos
Airplay 2 & Homekit
new User Interface
new remote
SoC
Model: BRAVIA 4K UR2
MediaTek MT5893
CPU Cores:4
CPU Clock : 1032 - 1500 MHz
Core 1 Clock : 1500 MHz
Core 2 Clock : 1500 MHz
Core 3 Clock : 1500 MHz
Core 4 Clock : 1500 MHz
OpenGL ES:3.2
49XG9005
e1c49af2-sony-kd-49xg9005-le-meilleur-televiseur-de-moins-de-50-pouces-du-marche__w800.jpeg
d1d69345-sony-kd-49xg9005-le-meilleur-televiseur-de-moins-de-50-pouces-du-marche__w800.jpeg
6440b12b-sony-kd-49xg9005-le-meilleur-televiseur-de-moins-de-50-pouces-du-marche__w800.jpeg
KD75XG9505
854833
854849
Dimensions XG9505...https://avclub.gr/forum/showthread....p-2019?p=1058298333&viewfull=1#post1058298333
ΥΠΟΣΤΗΡΙΞΗ ΠΡΟΪΟΝΤΟΣ-ΓΕΝΙΚΑ-FAQ-ΕΓΧΕΙΡΙΔΙΟ ΧΡΗΣΗΣ-iMANUAL-ΣΥΝΔΕΣΙΜΟΤΗΤΑ-FIRMWARE
[sony.gr]...KD-XG95 series...https://www.sony.gr/electronics/support/lcd-tvs-android-xg95xx_x95xxg-series/kd-55xg9505
[sonypremiumhome.com]...XBR-55X950G specifications...http://www.sonypremiumhome.com/premium-television/X950G.php
Οδηγός βοήθειας...https://helpguide.sony.net/tv/gaep2/v1/el/index.html
Ενημέρωση υλικολογισμικού: Καλώς ορίσατε στο Android 9 Pie για τηλεοράσεις Sony 2018-2019 (σειρές AF9, ZF9, AG9, ZG9, XG85/XG87 και XG95) - Από τις 11 Δεκεμβρίου 2019...https://www.sony.gr/electronics/support/televisions-projectors/articles/00236430
-Ενημέρωση υλικολογισμικού σε v6.3598 (έκδοση Android 9 Pie)...https://www.sony.gr/electronics/support/downloads/00016479
sony_atvotafull_2018_1603598100_eua_auth.zip
Ημερομηνία κυκλοφορίας : 29-01-2020
Συνδεσιμότητα XG95:
HDMI input x4 (η μια έχει eARC)
USB x3 (μια USB 3.0)
Analog Audio Out mini jack 3.5mm x1 (έξοδος ακουστικών)
Digital Optical Audio Out x1
Bluetooth 4.2: για σύνδεση keyboard/mouse/gamepad, υποστηρίζει και A2DP για Bluetooth ακουστικά,ηχόμπαρες.
Προηγμένη λειτουργία εγγραφής βίντεο PVR ready: ναι ,από 32GB και πάνω
Composite input (AV) / Component input (Y / Pb / Pr) : Yes / No
Διαχείριση καλωδίων : Ναι
Υποστήριξη DTS/DivX : Ναι
Wi-Fi 802.11 a/b/g/n/ac
Είσοδος Ethernet-LAN x1
Remote control με φωνητικό έλεγχο και με συντόμευση για Google Play & Netflix.
Συνδεσιμότητα smartphone :Video & TV SideView (iOS/Android)
DVB-T2 HD (H.265/HEVC)x2,DVB-S2 x2
Made in Slovakia.
Unboxing :
Unboxing Sony KD65XG9505+picture settings...https://avclub.gr/forum/showthread....p-2019?p=1058297260&viewfull=1#post1058297260
Reviews - tests :
75"...[lesnumeriques.com]...Sony KD-75XG9505 test...https://avclub.gr/forum/showthread....p-2019?p=1058287933&viewfull=1#post1058287933
75"...[flatpanelshd.com]...Sony KD75XG9505 review,picture settings...https://avclub.gr/forum/showthread....p-2019?p=1058291743&viewfull=1#post1058291743
5 horizontally and 12 vertically (5x12=60) the number of dimming zones
75"...[hdtvpolska.com]...Sony KD-75XG9505 test...https://avclub.gr/forum/showthread....p-2019?p=1058298333&viewfull=1#post1058298333
75"...[homecinemamagazine.nl]...Sony KD-75XG9505 review,picture settings...https://avclub.gr/forum/showthread....p-2019?p=1058300227&viewfull=1#post1058300227
75"...[tweakers.net]...Sony KD75XG9505 review...https://avclub.gr/forum/showthread....p-2019?p=1058317950&viewfull=1#post1058317950
75"...[dday.it]...Sony KD75XG9505 test...https://avclub.gr/forum/showthread....p-2019?p=1058332051&viewfull=1#post1058332051
75"...[altadefinizione.hdblog.it]...Sony KD75XG9505 review...https://avclub.gr/forum/showthread....p-2019?p=1058345031&viewfull=1#post1058345031
65"...[hdtvtest.co.uk]...Sony KD-65XG9505 review...https://avclub.gr/forum/showthread....p-2019?p=1058304362&viewfull=1#post1058304362
55"...[rtings.com]...Sony XBR55X950G review,calibration settings...https://avclub.gr/forum/showthread....p-2019?p=1058295372&viewfull=1#post1058295372
55"...[avforums.com]...Sony KD-55XG9505 review...https://avclub.gr/forum/showthread....p-2019?p=1058343011&viewfull=1#post1058343011
55"...[avmania.e15.cz]...Sony KD55XG9505 test...https://avclub.gr/forum/showthread....p-2019?p=1058303186&viewfull=1#post1058303186
55"...[geex.x-kom.pl]...Sony KD55XG9505 review...https://geex.x-kom.pl/recenzje/nieu...yli-test-i-recenzja-telewizora-sony-55xg9505/
μετάφραση google pl to en
49"...[lesnumeriques.com]...Sony KD49XG9005 test...https://avclub.gr/forum/showthread....p-2019?p=1058365086&viewfull=1#post1058365086
49"...[digitec.ch]...Sony KD-49XG9005 teardown...https://www.digitec.ch/de/page/tv-teardown-ich-falde-einen-fernseher-auseinander-14307
Comparison :
65"...[hdtvtest.co.uk]...Samsung QE65Q90RA vs Sony KD-65XG9505...https://avclub.gr/forum/showthread....p-2019?p=1058332687&viewfull=1#post1058332687
55"...[rtings.com]...Sony XBR55X900F vs Sony XBR55X950G side-by-side comparison...https://www.rtings.com/tv/tools/compare/sony-x900f-vs-sony-x950g/585/764
Sony X950G vs LG SM9500 side-by-side comparison...https://www.rtings.com/tv/tools/compare/sony-x950g-vs-lg-sm9500/764/838
55XG9505 με βάση: πλάτος x ύψος x βάθος : 123cm x 78cm x 28cm
55XG9505 χωρίς βάση πλάτος x ύψος x βάθος : 123cm x 71cm x 7cm
55"...http://www.sonypremiumhome.com/pdfs/55X950G_20181009.pdf
65"...http://www.sonypremiumhome.com/pdfs/65X950G_20181119.pdf
75"...http://www.sonypremiumhome.com/pdfs/75X950G_20181119.pdf
85"...http://www.sonypremiumhome.com/pdfs/85X950G_20181214.pdf
-Αρχικές τιμές στην ελληνική αγορά:
KD85XG9505 : 5.399
KD75XG9505 : 4.599
KD65XG9505 : 2.849
KD55XG9505 : 2.049
KD49XG9005 : 1.549
teo GTP
8 November 2009
196
Σήμερα παρέλαβα το θηρίο.
KD85XG9505
Αντικατέστησε την 55ρα Panasonic u10
Άναμμα σεταρισμα λογαριασμού και εύρεση καναλιών μέσα σε λίγα λεπτά.Πολύ γρήγορη.
Εντυπωσιακή , επιβλητική και στιβαρή κατασκευή με μεταλλικά πόδια και μεταλλικό περίβλημα οθόνης.
Στα της εικόνας, χωρίς καμία ρύθμιση πλέον του προφίλ σινεμα που επιλέχθηκε, απλά γράφει μια εντυπωσιακή εικόνα,πολύ καλύτερη από την pana τουλάχιστον στο επίπεδο του μαύρου, όπου στην u10 είχε μια συνεχή αυξομείωση πράγμα κουραστικό
Τα δείγματα που χρησιμοποίησα είναι κάποιες ταινίες που εχω σε ανάλυση 4Κ αλλά και 1080. Το μόνο που μου ξένισε ήταν όταν δοκίμασα δείγματα με hdr όπου τα μαύρα απλά εξαφανίζονται και γίνονται γκρι. Δεν ξέρω αν διορθώνεται με tweeking στα μενού της τηλεόρασης. Δεν είχα και κουράγια λόγω κούρασης.
Θα δοκιμάσω μάλλον αύριο.
Το πρόβλημα μου είναι ότι δεν έχω βρει κάποιον οδηγό στο νετ για κάποιες στοιχειώδεις ρυθμίσεις.
xavito
29 October 2008
9,275
Με γεια και καλοθέατη η 85άρα.
Σε κάποια reviews έχουν και ρυθμίσεις εικόνας,βέβαια για να πάρεις το μέγιστο χρειάζεται ειδικός εξοπλισμός και κάποιος που να γνωρίζει από calibration γιατί ακόμη και τα πάνελ στο ίδιο μοντέλο παρουσιάζουν αποκλίσεις και δεν είναι ακριβώς τα ίδια.
flatpanelshd.com 75"
Picture settings:
(Note: We include calibration settings only for SDR, not HDR. For our calibration we have deactivated the ambient light sensor that automatically adjusts the backlight setting according to your environment. You may prefer to have it enabled.)
Profile:personal
Brightness:
Brightness:15 (ρυθμιστικό οπίσθιου φωτισμού)
Contrast:90 (επίπεδο λευκού)
Gamma:0
Black level:50 (επίπεδο μαύρου)
Adv. contrast enhancer:Off
Automatic local dimming:Medium (SDR) / High (HDR)
X-tended Dynamic Range:Off
Color:
Color:50
Color balance:0
Color temperature:Expert 1
Live color : off
Clarity:
Sharpness:50
Reality creation : off
Resolution:-
Random noise reduction : off
Digital noise reduction: off
Smooth gradation:Low (SDR/HDR10) / Off (Dolby Vision)
Motion:
MotionFlow:personal
Smoothness:1-2
Clarity:1
Film mode: off
homecinemamagazine.nl (75")
The best choice starts from the Cinema Pro mode.
SDR (standard dynamic range) settings
General:
Image mode: User
Auto Image mode: Off
Brightness: 15-35*
Color: 50
Light sensor: on *
*The 'User' image mode provides the best calibrated start. We did notice that it is very clear (with Sony, 'Brightness' refers to the level of the backlight). If you look at darkening, lower it earlier to 15. If you stay at 35, it is best to activate the light sensor.
Advanced settings:
Brightness:
Brightness: 15-35 *
Contrast: 90
Gamma: -2
Black level: 50
Black adjust: off
Advanced. Contrast optimization : Off
Automatic Local dimming: Middle
X-tended Dynamic Range: Off (With Xtended Dynamic Range, your SDR images can give an HDR effect, but it mainly makes images brighter, and brings a little extra white detail.)
Color:
Color: 50
Color tone: 0
Color Temperature: Expert 1
Live Color: Off
Sharpness-Clarity:
Sharpness: 50
Reality Creation: Auto *
Reduce random noise: Low *
Reduce digital noise: Low *
Smooth Gradation: Low
*Reality Creation: improves detail display. The Auto mode is generally fine, whoever prefers the pure approach turns it off, or switches to Manual 20. For more detail you can go up to 40, but avoid higher settings.
*Activate both noise suppressions in the lowest position, especially if you set Reality Creation higher than 20. In that case we would even recommend 'Middle'.
If you would like to see some extra sharpness and depth in the image, activate Reality Creation. In that case, you absolutely want to activate the noise reduction, otherwise this setting also makes all noise much more visible. Color gradations remain nicely free of color bands, thanks to 'Smooth gradation', these settings are best left in the low position.
Motion-Movement:
MotionFlow: Auto, or flexibility 2, brightness 1.
Film Mode: Auto
*Motionflow: out for the purists, car for those who opt for the easiest solution. Manual tinkering is also possible. Then set flexibility to 2 and brightness to 1.
Just like the XF90 (which remains available this year) and the ZF9, the XG95 uses X-Motion Clarity. He thereby combines the local dimming options of the background lighting with 'black frame insertion' (BFI) to achieve sharper motion detail without greatly dimming the brightness of the image. You leave Motionflow on, by the way, in the 'auto' mode if you simply want the smoothest result with the best detail. An artifact here or there remains possible. Alternatively, choose 'Manual' and set Suppleness to 2 or 3 (depending on your taste) and Brightness to 1, with these settings the Sony brings out all the details, and the image hardly loses brightness.
If you watch a lot in strong daylight, try the Cinema setting.
If you look at darkening, it is best to activate the light sensor
HDR settings:
Here too the User image mode is the best choice.
senos
19 December 2007
393
Re: Sony KD XF9005 : Reviews - Εντυπώσεις - Σχόλια
Καλησπέρα. Το πρόβλημα με τον αισθητήρα του πληκτρολογίου που έχει αναφερθεί σε κάποιες και χρειάζεται η τηλεόραση επισκευή σε service ισχύει και για την 9505; Δεν έχω δει ξεχωριστό θέμα για αυτήν.
alej
30 June 2012
145
Re: Sony KD49XG9005 την προτείνετε για άμεση αγορά;
Αν θες να κάνεις καταλληλότερη επιλογή πες δυο λόγια και για τα υπόλοιπα παρακάτω:
Απόσταση θέασης : ~2,50m
Θέση θέασης (απέναντι σχετικά,πλάι): Απέναντι
Συνθήκες φωτισμού (φως ημέρας,χαμηλός,σκοτεινός,καθόλου): Μέρα / χαμηλός
Χρήση-περιεχόμενο (ταινίες,σειρές,αθλητικά,gaming,digea,) : 4Κ Netflix / 4K Youtube / Ελάχιστα TV / Ταινίες FHD & 4K
Πηγές (sd,hd,HDR,streaming): Netflix / Youtube / SSD
Προηγούμενη tv: 26'' 1080i
Απαιτήσεις σε ποιότητα: The best.
Επίσης, υπάρχουν εφαρμογές στο Apple Store για αυτήν την οθόνη;
H KD49XG9005 επειδή είναι VA panel,F.A.L.D. LED LCD με 100/120Hz panel είναι η καλύτερη στην κατηγορία 49"-50" .
Αυτό σκέφτηκα και την πήρα. Ευχαριστώ για την απάντηση.
Από Plaisio, 799 (τιμολόγιο) με δώρο 5ετης εγγύηση γιατί τους ανέφερα ότι στο site του Public έτσι την έχουν.
Πρώτες εντυπώσεις.. μου έχει πέσει το σαγόνι!!!!
Συνδέθηκε σε wifi 5GZ και το 4K πάει σφαίρα. Το Android πολύ γρήγορο (με εντυπωσίασε μιας και είμαι apple fan) και ακόμα την ψάχνω.
Έχω βάλει της Sony ένα 4Κ video στο Youtube και έχω ζαλιστεί...
Ερώτηση αν το ξέρει κάποιος. Δεν έχει βρει όλα τα HD κανάλια της digea (έτσι λέγεται;). Π.χ. το Open HD και το ΕΤ1 HD. Καμία ιδέα;
xavito
29 October 2008
9,275
Είναι θέμα λήψης σήματος από την κεραία ,κοίταξε κεραία,πρίζα,καλωδίωση.
Everflow
6 June 2010
14
@alej
Με γεια!:ernaehrung004:
Αν έχεις την 49ρα, είναι εύκολο να μετρήσεις το πλάτος του stand της?
alej
30 June 2012
145
@alej
Ευχαριστώ!
Μέγιστο πλάτος 99,5cm
alej
30 June 2012
145
Υπάρχουν εφαρμογές στο Apple Store για αυτήν την οθόνη; Το Cromecast πως δουλεύει; Επίσης, είδα ότι είναι Homekit και Airplay. Τα έχει δοκιμάσει κανείς;
X-ray7
5 July 2012
93
Πήρα κι εγώ από Media Markt την 65αρα 65XG9505 με χρήση και της προσφοράς των yellows. Μου βγήκε 1200 ευρώ.
Η αλήθεια είναι ότι όταν ξεκίνησα να βλέπω το ντοκυμαντέρ του νετφλιξ κο έφτασε να μου παίζει το επεισόδιο με 15mbps και 2160 εντυπωσιάστηκα παρά πολύ από αυτό που έβλεπα σκεφτόμενος ότι ακόμα βλέπω μεσω streaming και δεν έχω κουμπώσει καλά καλά το σκληρό με τις ταινίες μου.
Στη συνέχεια έβαλα ένα βίντεο από YouTube για diming test. Με το που πείραξα το local diming μέσα από τις ρυθμίσεις έμεινα άφωνος με το ποσό μαύρο έβγαζε η οθόνη βλέποντας το φυσικά σε δωμάτιο με κλειστά όλα τα φώτα.
Για χρήση του κινητού ως χειριστήριο μπορείτε να χρησιμοποιήσετε την εφαρμογή Video & TV Sideview για iOS.
Με το air play δεν έχω βγάλει άκρη ακόμα για το πως παίζει.
alej
30 June 2012
145
Όσοι την έχετε βάλτε το Blade Runner στο Netflix είναι 4Κ και είναι απόλαυση. Έχει και 8 στο IMDB. Επειδή προέρχομαι από αρχαικό μοντέλο η διαφορά είναι τεχνολογικό σοκ. Έχει την εικόνα που έβλεπα στα καταστήματα και ζήλευα και είμαι σίγουρος πως όταν βάλω και τις ρυθμίσεις που προτείνουν πιο πάνω τα παιδιά θα είναι ακόμα καλύτερα!
X-ray7
5 July 2012
93
Θα σου πρότεινα να δεις και το "Ο πλανήτης μας" αφού έχεις προχωρήσει στις ρυθμίσεις για να χαζέψεις κι εσύ μαζί με ένα :p
Σχετικά με το προφίλ Cinema Pro έχει κανείς ιδέα πως το ενεργοποιούμε; Παίζει από συγκεκριμένες πηγές μόνο; Γιατί στο Netflix δεν μου το εμφάνιζε για να το επιλέξω.
Panos1345
4 March 2015
41
Πάτρα
Αγόρασα και εγω χθές την 65αρα 65XG9505 με yellows 1200 ευρώ και έδωσα άλλα 150 για 5ετη εγγύηση (Media Markt). Ευτυχώς που δεν έκανα το λάθος να την πάρω αρχές Νοέμβρη στις εκπτωσεις που είχε 1800 ευρώ. Τελικά το Black Friday δίνει πράγματι φοβερές εκπτώσεις. (Στο μαγαζί γινόταν χαμός και απο το e-shop δεν είναι διαθέσιμη απο χθες το πρωί)
Θα ήθελα να σε ρωτήσω πως είδες οτι έπαιζε με 15mbps;
Για ταινίες πιο χαμηλής ανάλυσης απο σκληρό δίσκο τι προτείνετε για ρυθμίσεις;
X-ray7
5 July 2012
93
Εγώ ήμουν έτοιμος να πάρω πριν 2 μήνες την 55XF9005 και μετρώντας το σημείο τοποθέτησης στο σαλόνι μου είδα ότι με παίρνει και για 65άρα.
Για καλή μου τύχη ενώ έλεγα να πάω στην 65XF9005 έβαλαν σε προσφορά και την 65XG9505.
Με τον συνδυασμό των yellows κατεβαίνει ακόμα περισσότερο η τιμή και νομίζω ότι μιλάμε για μέγιστο value for money
Για το Netflix ουσιαστικά πρόκειται για το κουμπί i+ που βρίσκεται κάτω από τον αριθμό 7 στο τηλεχειριστήριο της συγκεκριμένης τηλεόρασης (το λεγόμενο display button όπως έγραψε και ο czoun).
Στην παλιά μου sony νομίζω βρισκόταν σε άλλο σημείο αλλά είχε πάλι το σύμβολο i+ πάνω.
tip. Αν παίζεις κι από PS4 netflix το βλέπεις πατώντας μέσα το δεξί αναλογικό (το λεγόμενο R3).
alej
30 June 2012
145
Καλορίζικες όλες και καλές θεάσεις. Θα το δω το Ο Πλανήτης μας γιατί μου αρέσουν τα ντοκυματέρ.
Μια ερώτηση σχετική με την θέση της TV. Δείχνει να έχει μια μικρή κλίση προς τα πίσω. Μήπως δεν έχω βάλει καλά τις βάσεις; Ή έτσι είναι όντως; Δεν με ενοχλεί στη θέαση αλλά αν πρέπει να διορθώσω κάτι να το κάνω.
senos
19 December 2007
393
Καλησπέρα. Την παιρνω κι εγώ την Πέμπτη. για να βάλω δίσκο για εγγραφές πάνω της σε ποια θύρα πάει και χρειάζεται δικό του ρεύμα η παίρνει μόνο από το usb;
