Sony KDL W5500 : Reviews - Εντυπώσεις - Σχόλια
Re: Sony KDL W5500
Παιδιά καμιά ιδέα για καλό στήριγμα της 40w5500 στον τοίχο? η κάθετη περιστροφή δεν είναι απαραίτητη. περισσότερο θέμα συμβατότητας με ενδιαφέρει...
Re: Sony KDL W5500
Vogel's
http://www.vogels.com/web/Consumer.htm
Βάζοντας τον τύπο της τηλεόρασής σου, βγαίνουν οι συμβατές βάσεις:
http://www.vogels.com/web/Consumer/...dbid=5&typeofpage=81807&brand=83&equipid=4452#
Re: Sony KDL W5500
καλησπερα παιδια,μηπως γνωριζει καποιος να μου πει,γιατι απο σημερα εγινα κ εγω κατοχος της εν λογω τηλεορασεως 40'',πως τη συνδεσατε με pc σε dvi-hdmi γιατι εγω τη συνδεσα κ δεν δειχνει εικονα,κ οταν αλλαζω τiς ρυθμισεις στο nvidia control κ κανω clone display,αναγνωριζει την tv αλλα οταν παω να σωσω τις αλλαγες ξαναγυρναει στο monitor...τι μπορει να φταει?:frusty:
Re: Sony KDL W5500
Although any of our four contenders would make a perfectly enjoyable main living room TVs, it's actually reasonably easy for us to come up with final running order today.
This finds LG's 42LH5000 propping the others up. We feel a little shoddy about this, given that it follows LG's usual pattern of offering ridiculous bang for your buck. But the set's black level shortcomings and occasional 200Hz problems are enough to hamper it amid the accomplished company it's come up against here.
In third place we've put Philips' 42PFL8404. This set is certainly a chip off the old Philips block when it comes to the amount of fancy processing it's got going on, but it's a bit too labour intensive for our liking, and its black levels are disappointing.
In second place - cue moany comments from plasma obsessives - we've put Panasonic's P42G10. This TV certainly has its moments, specifically with HD movies. But the latest advances with LCD technology have started to make Panasonic's plasma images look slightly muted, and highlighted some colour tone issues to boot.
The winner of this group test, then, is Sony's 40W5500. For while there's still room for improvement when it comes to the set's online features and backlight consistency, its pictures for the vast majority of the time really are nothing short of a joy to behold.
Group test: 40-42in TVs
Re: Sony KDL W5500
1 LG, 1 philips, 1 panasonic και 1 sony δεν είναι και φοβερός ανταγωνισμός.
Να είχε τουλάχιστον μια σάμσουνγκ...
Το μόνο που με βρίσκει σύμφωνο είναι ότι η LG είναι ακόμα πιο χάλια και από τις philips... :flipout:
Πραγματικά δεν βλέπω τον λόγο να αγοράσει κανείς κάποια από τις 2 μάρκες... :blush:
Re: Sony KDL W5500
:flipout:
Η πλακα με την W5500 ειναι οτι βγαινει σε πολλα site κορυφαια...
πχ...
http://www.erenumerique.fr/televiseur_sony_kdl40w5500_la_qualite_au_meilleur_prix-art-2302-1.html
http://www.digitalversus.com/article-364-4908-16.html
...αλλα σε πωλησεις αν κρινω απο το φορουμ πρεπει να ειναι πολυ πισω απο την Β650 αλλα και την Β750...
Re: Sony KDL W5500
Μια samsung θα στεκοταν διπλα στη Sony με διαφορα ανασας , αναλογα το μοντελο ...
LG τωρα μπορεις να πεις πως σε καποια περιπτωση θα παρεις για την φτηνη τιμη σε καποιες μεγαλες ιντσες αλλα philips κι εγω δεν μπορω να καταλαβω γιατι θα επελεγε καποιος , πληρωνοντας πολλα για να παρει λιγα ...
-bye-
Re: Sony KDL W5500
:flipout:
πχ...
Αφού το ξέρουμε ότι είναι χειρότερη από την W4500... -bye-
Re: Sony KDL W5500
Χειροτερη σιγουρα δεν ειναι...
http://www.digitalversus.com/duels.php?ty=10&ma1=16&mo1=311&p1=3863&ma2=16&mo2=425&p2=4903&ph=16
Ειδικα το contrast ειναι σχεδον 50% πανω ...
Μονο στην χρωματικη απεικονιση η W4500 φαινεται να μπορει να εχει ευρυτερη γκαμα...
Και εδω ισχυει ο κανονας οτι ενα καινουργιο μοντελο παντα ειναι καλυτερο απο αυτο που αντικαθιστα...
Re: Sony KDL W5500
http://www.hdtvtest.co.uk/news/sony-kdl-40w5500-kdl40w5500u-20090323144.htm
Sony KDL-40W5500 vs. Sony W4500
For
* Sharper standard-definition upscaling/ upconversion quality
* Able to correctly process 3:2 and 2:2 pulldown for SD film mode deinterlacing
* White balance and gamma controls now available in user menu
* No undefeatable edge enhancement applied to 1080 source
* One extra HDMI port
* Applicast, USB video playback and DLNA media streaming capabilities
Against
* Primary chromaticities not as accurate
* Higher input lag even in [Game Mode]
Both sets exhibit roughly the same amount of clouding and backlight bleed out of the box, which can be reduced to unobtrusive levels with the correct picture settings.
Re: Sony KDL W5500
Αυτές πάντως είναι σίγουρα σημαντικές βελτιώσεις, ενώ αυτό:
...είναι μεγάλο μείον (για εμάς τους βλαμμένους :flipout: ) μεν, αλλά όταν σου δίνει αυτό:
...έχεις και μία δυνατότητα να το διορθώσεις, χωρίς να μπλέξεις με τα ακατανόητα service menu της Sony και να δημιουργήσεις πρόβλημα στην εγγύηση. :D
Re: Sony KDL W5500
τελικά ρε παιδιά ποιά είναι καλύτερη η 4500 ή η 5500!!!!
Re: Sony KDL W5500
ιδιο ειχανε και οι δυο,αν και βεβαια πλεον αποτελουν χρονοντούλαπο της ιστοριας!!
Re: Sony KDL W5500
Συμφωνα με τις μετρησεις του site η W4000 φαινεται να εχει καλυτερη αντιθεση απο την W4500...
http://www.digitalversus.com/duels.php?ty=10&ma1=16&mo1=219&p1=3466&ma2=16&mo2=310&p2=3862&ph=14
Πως γινεται αυτο? Μηπως ειχε καλυτερο πανελ?
Άμα είσαι τόσο αναξιόπιστος όσο το digitalversus, γίνεται μια χαρά... :flipout:
Re: Sony KDL W5500
Γιατι ειναι αναξιοπιστο?
Οι μετρησεις του μαυρου πχ. συμφωνουν τοσο με το HDTVtest οσο και με το flatpanels...
Για την G15 μαλιστα η μετρηση (0,03 cd/m2) συμφωνει με την μετρηση του Γιωργου και του Μανωλη στην G10 του Χρηστου (czoun)...
http://www.digitalversus.com/duels.php?ty=10&ma1=60&mo1=559&p1=5595&ma2=60&mo2=645&p2=6384&ph=16
Αλλοι ειναι αυτοι που περνουν μετρησεις που δεν συμφωνουν με κανεναν αλλο πχ. fullHD.gr...
