--- Sony XBR6/XBR7/XBR8 ---
συκρινεις μαλλον αλλα μεγεθη φιλε μου,καθοτι νομιζω η 32Α558 ειναι στα 850Ε καλυτερη τιμη.Αν θελεις να συγκρινουμε ιδια κατηγορια προιοντος η 32W4000 ειναι στα 970 νομιζω και η philips στα 1100Ε(32PFL9603).Αν παμε στις 40" το εισαγωγικο της sony η 40D3500 ειναι στο χιλιαρικο,μαζι με το εισαγωγικο της samsung 40Μ87 παλι στο χιλιαρικο.
Κάποιος διαχειριστής να διαγράψει τα link που είχα βάλει στο #18 και δεν λειτουργούν πλέον ( δεύτερη φορά που την πατάω έτσι με το akihabara :slapface:). Θα βάλω πάλι φωτογραφίες όταν το επιτρέψει ο σερνάμενος server της Sony.
Ευχαριστώ.
Done -bye-
Κάποιοι δημοσιογράφοι είχαν την τύχη να επισκεφθούν τις κεντρικές εγκαταστάσεις της Sony και να δουν από κοντά και τις νέες LCD της εταιρίας.
That same day, we also looked at the new Bravia and XBR line of LCD flat panel HDTVs, and got a first hand look at as yet unreleased models. A comparison of one of their new 46-inch XBR8 flat panel LCDs up against Samsung's top of the line LN-T4681F LED backlit LCD, and Pioneer's PDP-4280 proved to be eye opening, indeed. The point of the demonstration was to show off the XBR8's hugely improved black level performance. All three sets were set at their factory settings - as they would be set when you would get them home from the store. Naturally I would have preferred if all three were properly calibrated as that would create a level playing field that would make conclusive determinations of their respective performance much more valid. Nonetheless, the blacks on the new XBR8 series look to be the best of any LCD that I have seen to date by a good margin. This improved black level performance is due mainly to two brand new features available only in the flagship XBR8 series. First and most importantly, the Triluminous feature, which is a backlight system that is RGB instead if just white. This combined with the ACE Pro or Local dimming feature are the two new innovations that combine to vastly improve the black level performance of their XBR8 line of LCD panels. Sony also claims to have improved their Motionflow 120Hz feature dubbed "Motionflow Pro", a feature that is also only available in the flagshilp models. Motionflow Pro now incorporates Temporal Frame Interpolation and IB Reduction, which the company claims creates new frames after reducing image blur. The XBR 8 line will be available in the fall of this year.
http://www.tweaktv.com/the-miller-channel/oled-and-new-developments-in-lcd-flat-panel-hdtvs.html
