www.sonyalpharumors.com
Features
- Real time preview, params adjustments and all calculations
- GPU processing and rendering, all algorithms fully multi-threaded
- Rolling shutter correction
- Supports already stabilized GoPro videos (captured with Hypersmooth enabled) (Hero 8 and up)
- Supports and renders 10-bit videos (up to 16-bit 4:4:4:4 for regular codecs and 32-bit float for OpenEXR - works directly on YUV data to keep maximum quality)
- Customizable lens correction strength
- Render queue
- Keyframes
- Ability to create custom settings presets
- OpenFX plugin (eg. for DaVinci Resolve), which allows you to apply stabilization in video editor without any transcoding
- Visual chart with gyro data (can display gyro, accel, magnetometer and quaternions)
- Visual display of smoothed quaternions
- Modern responsive user interface with Dark and Light theme
- Adaptive zoom (dynamic cropping)
- Support for image sequences (PNG, OpenEXR, CinemaDNG)
- Based on telemetry-parser - supports all gyro sources out of the box
- Gyro low pass filter, arbitrary rotation (pitch, roll, yaw angles) and orientation
- Multiple gyro integration methods for orientation determination
- Multiple video orientation smoothing algorithms, including horizon levelling and per-axis smoothness adjustment.
- Cross-platform - currently works on Windows/Linux/Mac, with Android and iOS apps coming
- Multiple UI languages
- Supports variable and high frame rate videos, all calculations are done on timestamps
- H.264/AVC, H.265/HEVC, ProRes, DNxHD, PNG and OpenEXR outputs, with H.264 and H.265 fully GPU accelerated (ProRes also accelerated on Apple M1 Pro/Max/Ultra)
- Automatic lens calibration process
- Fully zero-copy GPU preview rendering (working but experimental)
- Core engine is a separate library without external dependencies (no Qt, no ffmpeg, no OpenCV), and can be used to create OpenFX and Adobe plugins (on the TODO list)
- Automatic updates of lens profile database
- Built-in official lens profiles for GoPro: HERO 6, 7, 8, 9, 10; RunCam: Thumb, ThumbPro, 5 Orange; Insta360: GO 2 in all shooting modes
Supported gyro sources
- GoPro (HERO 5 and later)
- Sony (a1, a7c, a7r IV, a7 IV, a7s III, a9 II, FX3, FX6, FX9, RX0 II, RX100 VII, ZV1, ZV-E10)
- Insta360 (OneR, OneRS, SMO 4k, Go, GO2, Caddx Peanut)
- DJI Avata
- Blackmagic RAW (*.braw)
- RED RAW (*.r3d)
- Betaflight blackbox (*.bfl, *.bbl, *.csv)
- ArduPilot logs (*.bin, *.log)
- Gyroflow .gcsv log
- iOS apps: Sensor Logger, G-Field Recorder, Gyro
- Android apps: Sensor Logger, Sensor Record
- Runcam CSV (Runcam 5 Orange, iFlight GOCam GR, Runcam Thumb, Mobius Maxi 4K)
- Hawkeye Firefly X Lite CSV
- WitMotion (WT901SDCL binary and *.txt)
Info for cameras not on the list
- For cameras which do have built-in gyro, please contact us and we will implement support for that camera. Refer to the documentation for information about the gyro logging process.
- For cameras which don't have built-in gyro, please consider using Betaflight FC or check out our flowshutter project.
v1.2.0
Improvements
- New gyro sources: DJI Avata, Blackmagic RAW (.braw), RED RAW (.R3D), Ardupilot binary log (.bin)
- Horizon lock actually locks the horizon now
- Blackmagic RAW (.braw) direct video playback
www.newsshooter.com
Δεν έχω Gimbal, αλλά είναι στις προσεχείς αγορές. Ολο και περισσότερο βρίσκω πως χρειάζομαι ένα.Αν έχεις φυσικά και gimbal του βάζεις να κάνει πανοραμικό πόσες λήψεις θέλεις και χώρο που θα καλύψει και έχεις μεγαλύτερο αρχείο με περισσότερες επιλογές κροπ από μια λήψη με ευρυγώνιο…
Πολύ καλό, αλλά με 1.2 κιλά maximum load, με περιορίζει αρκετά.
Ευχαριστώ.Οι κλασικές λύσεις DJI RSC2, RSC3 και για πιο μεγάλο payload RS2 & RS3 Pro.
Υπάρχουν κ τα Zhiyun Crane 3S κλπ που σηκώνουν περισσότερα κιλά και είναι σκυλιά.
Αλλά πρέπει να σταθμίσεις ανάγκες σου, ευκολίες προταιρεότητες...
Άλλα έχουν καλό λογισμικό, άλλα σηκώνουν κιλά και αντέχουν σε επαγγελματική χρήση, αλλά είναι μεγάλα και βαριά, άλλα θέλουν περισσότερο σετάρισμα... Θέλει ψάξιμο.
