Τεχνολογίες panel LCD-TFT
Re: Τεχνολογιες panel LCD-TFT
Μερικα ενδιαφεροντα στατιστικα απο την περυσινη χρονια...
Σύμφωνα με τον πίνακα το 11% των Sony φοράει ASV της Sharp.
Ήρθαν στην ευρωπαϊκή αγορά τέτοια μοντέλα ?
Στην Αμερικη κυκλοφορουν 42αρες με πανελ Sharp. Για Ευρωπη δεν εχω ακουσει τιποτα.
Φαντάζομαι το contrast ratio που θα έχουν...
Η LG παρουσιασε ενα νεο τυπο πανελ που ονομαζεται e-IPS. Προοριζεται κυριως για μονιτορ ως εναλλακτικη απεναντι στα TN...
LG Display e-IPS LCD Panel Update
This is a follow-up post to LG Display (LPL) 23″ e-IPS 1080p LCD Monitor Panel.
IPS is synonymous with excellence in LCDs. And it's going to get much better. LG Display has developed what it calls e-IPS. e-IPS is a version of the company's trademark IPS technology that brings the cost down. Way down. LG Display target market is toward the larger LCD monitor market that is currently dominated by TN (Twisted Nematic) technology. That would be 22", 23" and 24" LCD monitors. LG Display has stated that its e-IPS LCD panels will be price competitive with TN LCD panels. I am very excited and look forward to 23" e-IPS LCD based LCD monitors. So how did LG Display do it? The answer after the break.
IPS LCD panels require a bit more in terms of light source (CCFL lamps) to achieve a certain level of brightness. In other words, IPS LCD panels have a slightly lower aperture ratio. What LG Display did was improve the structure of the TFT (thin-film transistor) to enhance the aperture ratio. And that in turn means that in order to achieve the same brightness level you can do with less CCFL lamps. The backlight unit (BLU) is the most expensive part of a LCD so reducing the cost of the BLU is essential in bringing the manufacturing costs down--low enough to compete head-to-head with TN panels.
The 'e' in e-IPS might stand for 'economy' for the low price but I'm thinking that the words 'enhanced' or 'eco' are also accurate in describing the technology. Enhanced because the TFT structure was improved to let more light through. Eco because an e-IPS-based LCD monitor will be consuming much less power.
http://www.displayblog.com/2009/02/13/lg-display-e-ips-lcd-panel-update-2/
Δηλαδή βρήκαν τρόπο να περνάει περισσότερο φως με τους κρυστάλλους "ανοιχτούς" ...
... να δούμε αν θα βρουν ποτέ τρόπο να περνάει λιγότερο φως με τους κρυστάλλους "κλειστούς" :AFADF0:
Samsung and LG to Cooperate on LCD R&D
The world's leading LCD panel manufacturers Samsung Electronics and LG Display will launch joint research and development for LCD panel equipment.
The Korea Display Industry Association announced Thursday that the two giants agreed to co-develop OLED deposition equipment this year, after cooperating on manufacturing digital exposure equipment last year. The OLED deposition equipment serves an important role in making LCD panels.
Samsung and LG will expand their cooperation in R&D to next-generation display processing technology and source technology for core materials.
http://english.chosun.com/site/data/html_dir/2009/05/15/2009051500810.html
Samsung-Sony venture starts $1.5 billion LCD line
A flat-screen joint venture between Samsung Electronics Co Ltd and Sony Corp said on Tuesday it began volume production at a new manufacturing facility that took $1.5 billion to build.
The five-year old venture, named S-LCD, said in a statement that the new production line would use larger "eighth-generation" (8G) motherglass and produce liquid crystal display (LCD) panels for TV brands including Samsung and Sony.
Sales of flat-screen TVs have remained healthy in the midst of the global downturn thanks to sharp price falls over the past year. Panel makers have been stepping up output as prices stabilize, while China's policy of subsidizing electronics purchases in rural areas has boosted demand.
S-LCD invested 1.8 trillion won ($1.46 billion) in the new line, its second 8G facility located south of Seoul. It said it would ramp up monthly production capacity to 70,000 glass sheets by year-end.
Samsung is the world's biggest maker of LCD panels and LCD TV sets, while Sony is the No. 2 LCD TV brand.
http://www.reuters.com/article/technologyNews/idUSTRE5511HL20090602
LG Display 4th pixel!
H LG Display, πρώην LG.Philips, παρουσίασε μια τηλεόραση τεχνολογίας LCD 32 ιντσών η οποία καταναλώνει 50% λιγότερη ενέργεια από μια συμβατή 32αρα.
Η νέα τεχνολογία της LG Displays ονομάζεται White Plus και αυξάνει τη φωτεινότητα προσθέτοντας ένα λευκό pixel ανάμεσα στα υπάρχοντα τρία (RGB) pixels.
http://www.fullhd.gr/2008-09-02-19-07-25/1443-lg-display.html
S-LCD: Samsung & Sony χέρι-χέρι
Eίναι γνωστό ότι οι Samsung και Sony έχουν κοινό (50%-50%) εργοστάσιο κατασκευής πάνελ LCD στην Κορέα με το όνομα S-LCD (Samsung/Sony). Και οι δυο εταιρίες, για τις τηλεοράσεις τους, προμηθεύονται από τις γραμμές S-LCD τα πάνελ τους. Έτσι οι τηλεοράσεις των Samsung και Sony έχουν τα ίδια πάνελ ενώ διαφοροποιούνται μόνο στα ηλεκτρονικά και στο design.
To νέο στην εταιρία S-LCD είναι ότι ξεκινά η δεύτερη γραμμή παραγωγής πάνελ LCD 8ης γενιάς. Η γραμμή αυτής ονομάζεται 8-2. Πρόκειται για το αποτέλεσμα μιας επένδυσης ύψους 1,8 δισεκατομμυρίων KRW(Νόμισμα Νότιας Κορέας). Η παραγωγική δυναμικότητα της νέας γραμμής παραγωγής ανέρχεται σε 70.000 πάνελ ανά μήνα (το μέγεθος υαλοπίνακα μάνας από τον οποίο «κόβονται» τα πάνελ ειναι: 2.200 x 2.500 mm). Σκοπός της γραμμής 8-2 είναι η παραγωγή μεγάλων σε ίντσες πάνελ για την χρήση σε μεγάλου μεγέθους τηλεοράσεις. Δηλαδή για τηλεοράσει; 32, 46 και 52 ιντσών.
Για να γιορταστεί το γεγονός, η εταιρεία S-LCD πραγματοποίησε μια τελετή που πραγματοποιήθηκε στο Tangjeong Crystal Valley, Asan-City της Κοράς. Η περιοχή εκεί ονομάζεται Crystal Valley από το Silicon Valley των H.Π.Α.
"Θα εστιάσουμε όλες μας τις προσπάθειες στο να καταστεί δυνατό οι Samsung και Sony να ξεπεράσουν την τρέχουσα οικονομική κρίση και να εδραιώσει την ηγετική τους θέση στην αγορά των τηλεοράσεων LCD," είπε Won-Kie Chang, Διευθύνων Σύμβουλος της S-LCD. Χέρι-χέρι με την S-LCD οι μεγάλες κυρίες Samsung και Sony.
Ιστορία της εταιρίας S-LCD
* Απρίλιος 2004: δημιουργία της S-LCD
* Απριλίου 2005: Έναρξη μαζικής παραγωγής στη γραμμή 7-1
* Ιούλιος 2006: Υπογραφή της συμφωνίας για τη γραμμή παραγωγής 8-1
* Αύγουστος 2007: έναρξη μαζικής παραγωγής στη γραμμή 8-1
* Απρίλιος 2008: υπογραφή συμφωνίας για τη γραμμή παραγωγής 8-1
• Ιούνιος 2009: Έναρξη μαζικής παραγωγής στη γραμμή 8-2
http://www.fullhd.gr/pro/2008-03-05-02-33-57/1581-s-lcd-samsung-a-sony.html
Η Samsung παρουσιασε μονιτορ που βασιζονται σε ενα νεο τυπο πανελ που λεγεται cPVA. Δεν υπαρχουν ακριβεις λεπτομερειες αλλα θεωρειται οτι ειναι μια οικονομικότερη version των γνωστων μας S-PVA...
http://www.tftcentral.co.uk/news_archive/17.htm
Απλοποιημενο διαγραμμα που δειχνει τα τμηματα απο τα οποια αποτελειται μια τηλεοραση LCD...(α) για συμβατικο φωτισμο CCFL/HCFL (β) για direct LED (γ) για side LED
Άσχετο, αλλά τελικά οι γενιές στις LCD είναι τελικά θέμα μεγέθους του υποστρώματος; Καμιά ιδέα για να βελτιώσουν την αντίθεση των πάνελ τους θα σκεφτούν;
Ακριβως αυτο που λες , οσο μεγαλυτερο το υποστρωμα τοσο πιο πολυ πεφτει το κοστος παραγωγης...-bye-
Για την αντιθεση ειναι δυσκολο να βελτιωθει λογω του ενδογενους προβληματος των S-IPS που εχουν πιο πολυ διαρροή φωτος απο αλλους τυπους...-bye-
