Τεχνολογικά νέα, ανακοινώσεις από την... Blackmagic Design
Today we released Blackmagic Video Assist 3.7 update, which adds support for Blackmagic RAW recording from Fujifilm X-H2s cameras to Video Assist 5” and 7” 12G HDR models.
When recording Blackmagic RAW with Video Assist 12G HDR, you can also save the camera’s settings in metadata. This means the white balance and exposure are encoded into the file to be read by DaVinci Resolve, however you can also override these settings later in the RAW settings palette when color correcting.
This update also adds support for adjusting white balance on Panasonic GH5S and BGH1 cameras and improves white balance accuracy on Panasonic S1H, S1, S5, BS1H cameras when using Video Assist 12G HDR models.
Blackmagic Video Assist 3.7 update is available now as a free download from http://bmd.link/uCCisk
Today we announced Blackmagic Camera 7.9.1 update for Blackmagic Pocket Cinema Cameras which includes improved reliability when recording in all formats to external USB-C media disks. In addition, this update improves the record button response which means you’ll be able to start and stop recording faster. Plus, there’s improved reliability when updating the camera software and it fixes an issue where Blackmagic RAW clips with a LUT applied may not preview correctly in camera.
This update also fixes an issue on the Blackmagic Pocket Cinema Camera 4K that prevented users from setting frame rates above 60 fps when shooting in the 4K 2.4:1 resolution. Frame rates up to 75 fps can now be selected allowing you to record smoother slow motion footage. Also, this update improves the accuracy of the motion sensor metadata recorded from the gyro sensor in the Blackmagic Pocket Cinema Camera 4K, improving the effectiveness of the stabilization feature in DaVinci Resolve 18.
Blackmagic Camera 7.9.1 update is available now as a free download from http://bmd.link/k3K7pL
Μακάρι να το εξελίξουν.
Θα κατεβασω και θα δοκιμάσω πλάνα πριν και μετα ....
Βάζω και τα bullet points που συμπληρωνεις πάντα:
What's new in Blackmagic Camera 7.9.1​
The following models have new features.
Pocket Cinema Camera 4K, 6K, 6K G2 and 6K Pro
  • Improved reliability of recording to USB-C SSDs.
  • Improved reliability when updating the camera software.
  • Improved lag time when starting and stopping recording.
  • Fixed issue where Blackmagic RAW clips with LUT applied may not preview correctly in camera.
  • Improved motion sensor data accuracy.
  • Improved reliability in detection of physical OIS switches on MFT lenses.
  • Fixed issue preventing users setting frame rate above 60 fps when shooting 4K 2.4:1.
What’s new in Blackmagic RAW 2.6​
  • Adds support for Fujifilm XH2s Blackmagic RAW clips captured by Blackmagic Video Assist.
  • Adds adjustable white balance and accuracy for Panasonic GH5S, BGH1.
  • Improved white balance accuracy for Panasonic S1H, S1, S5, BS1H
Reactions: Kosh
εγω δεν προλαβαινω να το βαλω οταν επιστρεψω την ερχομενη εβδομαδα, παντως ακομα και στην προηογυμενη του εκδοση δεν ηταν κακο....
Today we announced Cloud Store 1.0.3 update which adds support for synchronization with Google Drive. This means in addition to existing Dropbox sync, you can now set up a local cache of your Google Drive files. This makes them instantly available to anyone on your network without the need to download them from the internet each time. It also allows you to sync multiple Blackmagic Cloud Stores so people in different geographic locations can collaborate without latency because everyone has a local copy of the files.
This update also lets you open Finder windows and Windows Explorer directly from the Blackmagic Cloud Store utility, making it faster and easier to connect to your network as well as access files.
With improved stability, you also get better performance when moving files with extremely long names. Plus, it’s now easier synchronizing large directories with these same files, making for a smoother workflow.
Cloud Store 1.0.3 update is available now as a free download from http://bmd.link/NWA3x3
What's new in Cloud Store 1.0.3​
  • Add support for synchronization with Google Drive.
  • Open Finder Windows and Windows Explorer from the utility.
  • Display amount of storage used in the utility.
  • Fix issue where files with very long names could not be moved.
  • Fix infrequent crash when syncing large directories with long filenames.
  • Improve validity of auto-generated network hostnames.
  • Fix issue where files could not be downloaded on Google Chrome to ExFat disks.
  • General performance and stability improvements for all models.
Aυξησεις τιμων και απο την ΒΜ λογω πληθωρισμου
Ενδεικτικα στις καμερες που μας αφορουν περισσοτερο
Blackmagic Pocket Cinema Camera 6K Pro change from $2,495 to $2,535 for a $40 increase.
Blackmagic Pocket Camera Battery Grip change from $245 to $255 for a $10 increase.
Blackmagic Pocket Camera Battery Pro Grip change from $145 to $149 for a $4 increase.
Blackmagic URSA Mini Pro 12K change from $5,995 to $6,385 for a $390 increase.
Blackmagic URSA Viewfinder change from $1,495 to $1,525 for a $30 increase.
Blackmagic URSA Studio Viewfinder G2 change from $1,495 to $1,515 for a $20 increase.
Blackmagic Camera Fiber Converter change from $2,995 to $3,245 for a $250 increase.
Blackmagic Studio Fiber Converter change from $2,995 to $3,325 for a $330 increase.
Blackmagic URSA Mini Recorder change from $395 to $425 for a $30 increase.
Blackmagic 3G-SDI Shield for Arduino change from $95 to $109 for a $14 increase.
Today we announced Blackmagic Camera 7.9.2 update for Blackmagic URSA Broadcast G2 which improves compatibility with live streaming platforms and improved iPhone 12 tethering when streaming via RTMP.
In addition, this update adds support for the recording of camera motion sensor data to Blackmagic RAW clips. This means you can record data from the gyro sensor into the metadata of a Blackmagic RAW file to stabilize your handheld footage in DaVinci Resolve, just like a built in steady cam.
This update also optimizes the behavior of the camera’s ISO, shutter and white balance switches, preventing accidental large changes of these settings when adjusting up or down, as well as improved connectivity between Blackmagic Camera Fiber Converter and Blackmagic Studio Fiber Converter.
Blackmagic Camera 7.9.2 update is available now as a free download from http://bmd.link/geR73m.
What's new in Blackmagic Camera 7.9.2​
  • Improved streaming compatibility.
  • Improved compatibility with some iPhone 12 models.
  • Improved gain, shutter and white balance switch behavior.
  • Improved codec response with LED walls.
  • Adds support for writing motion sensor data to Blackmagic RAW recordings.
  • Adds support for retaining presets and LUTs for future updates.
  • General performance improvements.
  • Compatibility improvements.
  • Improved white balance accuracy for Panasonic S1H, S1, S5, BS1H.
Και εγω αυριο γυρισμα με την G2 :)
Α οχι με την broadcast λεει εχουμε μπλεξει πλεον με τοσα μοντελα G2 που εχουν καπως πρεπει να τα διαχωρισουν.
Reactions: evanfotis
Δεν ξερω ρε γμτ ανακοινωσαν και την καινουργια 6κ G2 προσφατα .
Η λογικη λεει οτιο αν ερθει κατι στις καμερες αυτη θα ειναι μια νεα mini ursa G3.
Xτες που την δουλεψα ξανα και ειδα αρχεια ειναι τοσο ωραια ρε συ.....καταπληκτικο DR. Η απολυτη vfm camera η οποια βαζει κατω καμερες πολλαπλασιου κοστους.
Δεν ξερω τι αλλο θα ηθελα ισως το ιδιο DR σε 8k ισως και φυσικα FPS μπολικα......
Την θελω χτες μια τετοια καμερα σε αυτο το κοστος .
Δεν νομιζω να πανε σε τοσο μικρο κελυφος.
Θελει επενδυσεις αυτη η στροφη.
Οι τυποι ναι μεν στα "σπλαχνα" κανουν παπαδες αλλα στα κελυφη ειναι γερμανοι (αν και αυστραλοι)
Ποσα χρονια τωρα εχουν τις mini ursa και απλα αλλαζουν την καμερα εσωτερικα ?
Το ιδιο εκαναν τωρα και με την 6k G2. Πηραν το κελυφος της 6k pro αφαιρεσαν τα εσωτερικα builded nd, εβαλαν μια φθηνοτερη οθονη και ιδου.
Ένας λόγος παραπάνω...
Ας κρατήσουν σώμα p6 pro και ας βάλουν 8k / 12k / ff μέσα ..
Δεν νομιζω οτι θα αλλαξει συντομα η 6kpro.
Aν δεις τον ανταγωνισμο δηλαδη δεν υπαρχει λογος απλα.
Και τωρα να την εβγαζαν παλι μπαμ θα εκανε.....
