Xiaomi Mi Pad 3 (9.7")
airb
25 May 2008
16,366
Λιβαδειά
Xiaomi's Mi Pad 2 is over one year old at this point, so you'd expect a successor to show up pretty soon, right? Right.
Meet the Mi Pad 3, which has been leaked today in all its glory in China thanks to some newly uncovered promotional
materials.​
The Mi Pad 3 will be bigger than both of its predecessors, opting to sport a 9.7-inch 2,048x1,536 touchscreen, matching
Apple's iPad Pro 9.7 in both size and resolution. Speaking of which, the Mi Pad 3 is barely thinner than Apple's tablet,
coming in at 6.08mm compared to 6.1mm. Xiaomi's device weighs only 380g, 57g less than the iPad, and it manages
to be shorter and narrower too, at 239.5x164.5mm.
The Mi Pad 3 is powered by Intel's 7th Gen Core m3-7Y30 processor, aided by 8GB of RAM and a choice between 128
or 256GB of storage. It runs Windows 10, and boasts an 8,290 mAh battery as well as a USB Type-C port for charging.
On the rear will be a 16 MP camera with dual-tone LED flash, while selfies will be taken care of by an 8 MP sensor.
The device is reportedly going to launch on December 30, priced at CNY 1,999 ($289 or 273) with 128GB of storage,
and CNY 2,299 ($332 or 314) with 256GB. The keyboard dock you can see below will be sold separately for CNY 99
($14 or 13). The Mi Pad 3 has a full metal build with dual speaker grilles on the bottom, flanking the USB Type-C port.
It's unclear if there will ever be an Android version of this tablet, since the leak doesn't mention such a possibility. That said,
last year's Mi Pad 2 did have two OS versions, so it's not entirely unreasonable to expect an Android-powered Mi Pad 3 to
show up at some point next year.
[via] . [via]
[h=2]Specification[/h][TABLE="class: jbEidtTable, width: 912"]
[TR]
[TD="width: 20%"]General[/TD]
[TD="width: 80%"]Brand: Xiaomi
Model: Mi Pad 3
Available Color: Silver, Gold
OS: Windows 10
CPU: Intel Kaby Lake Core m3-7Y30
Core: Dual Core, 1.0-2.6GHz
GPU: Intel HD Graphics 615[/TD]
[/TR]
[TR]
[TD]Storage[/TD]
[TD]RAM: 8GB, LPDDR3
ROM: 128GB/256GB, eMMC
External Memory: Not supported[/TD]
[/TR]
[TR]
[TD]Display[/TD]
[TD]Screen type: IPS LCD capacitive touch screen, 16M colors
Screen size: 9.7 inch
Screen resolution: 2048 x 1536 pixels
Pixel density: 264 ppi[/TD]
[/TR]
[TR]
[TD]Network[/TD]
[TD]Support network: 2.4G&5G WiFi
WiFi: 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
Bluetooth: Yes, V4.2, A2DP, LE[/TD]
[/TR]
[TR]
[TD]Camera[/TD]
[TD]Camera type: Dual cameras (one front one rear)
Front camera: 8MP
Rear camera: 16MP, autofocus, dual-LED (dual tone) flash[/TD]
[/TR]
[TR]
[TD]Connectivity[/TD]
[TD]USB-C slot: Yes
3.5mm headphone jack: Yes (Active noise cancellation with dedicated mic)
Docking interface: Support[/TD]
[/TR]
[TR]
[TD]Power[/TD]
[TD]Battery type: Non-removable Li-Po battery, 8290mAh
Power device Type: AC Adapter, 100-240V
Charging voltage: DC 5V 2A[/TD]
[/TR]
[TR]
[TD]Multimedia[/TD]
[TD]Video format: (1080p) AVI/MOV/MP4/RMVB/FLV/MKV
Audio format: MP3/WMA/WAV/APE/AAC/FLAC/OGG
Picture format: JPG/BMP/PNG/GIF
Ebook format: UMD/TXT/PDF/HTML/RTF/FB2[/TD]
[/TR]
[TR]
[TD]Other Features[/TD]
[TD]Sensor: Accelerometer, Gyro, Compass
Speaker / MIC: Built-in stereo speakers and microphone
Languages: Windows OS is pre-installed English, and other languages need to be downloaded by WiFi.
Softwares: Youtube, Skype, Email, Push Mail, IM, Browser, Gallery, Clock, Calculator, Calendar, etc.[/TD]
[/TR]
[TR]
[TD]Dimensions[/TD]
[TD]Product size: 239.5 x 164.5 x 6.08 mm
Product weight: 380 g
[/TD]
[/TR]
[TR]
[TD]Package Contents[/TD]
[TD]1 x Tablet PC
1 x USB-C Cable
1 x Charger (A right plug of adapter will be sent as your shipping country)
1 x User Manual[/TD]
[/TR]
[/TABLE]
