- 20 December 2008
- 5,351
Απάντηση: Re: Zidoo X20/Χ20 PRO
Ενα περιμεναμε, δυο τελικα μας ερχονται τον Μαιο .. :antlers:
X20
Powerful Configuration:
430MM Standard cabinet Size, All aluminum alloy chassis
New upgrade version Realtek 1296 Quad-Core 64 bit A53 processorοΌHigh quality high-power SMPS.
2G DDR4 MemoryοΌ16GB eMMC Super Built-in StorageοΌgigabit wired, 802.11 AC 2T2R 867Mbps WIFIοΌBluetooth 4.2
Abundant Interface :
SATA 3.0*2, USB 2.0*2, USB 3.0*1, TYPEC *1, Coaxial Cable*1, Optical Fiber*1 , Left/Right Channels*1, AV Output*1, Infrared Input*1, RS232*1, HDMI OUT*2, HDMI IN 2.0*1
Full function with backlight Bluetooth-Infrared-Learning three-in-one remote control, remote control without dead Angle.
Super Lager front LED Display.
Independent Dual SATA 3.0 Ports, NSS Patented metal hard disk extractor can Build-in two High-Capacity Hard Disk.
Smart temperature control with dual Balls and High Static Pressure Fan.
Dual HDMI Output ports (Audio and Video Separation) dispense with origin power amplifier and enjoy 4K with HD Audio.
New quality optimization engine technology, Optimized HDR to SDR Algorithm. Play 4K HDR which Restoring primitive color even without HDR TV.
Detailed Frame switching and resolution switching. (23.976,59.94,25,30,50,60)
4K 60P Point to Point Output, Color Region: HDR/HDR10, 10Bit Color Depth, 10.7 hundred million kind of colors.
True 4K 60P decode, H.265/HEVC 10Bit Hard solution.
Support 4K UHD Blue-Ray Navigation
Powerful subtitle function, Support random change any fonts with different color effects; Support download subtitle online; Support SUP&ASS special effects subtitles
Unparalleled Wall-Poster Function, Full automatic scan, Automatic classification and sorting movies and dramas. Customer Layout.
Soundtrack support SACD, DFF, DSF, APE, FLAC, WAV and etc Free lossless audio formats; Support CUE track; Support cell phone control without having to open the display device to listen to music.
Support NFS,SMB,V2,SMB V1 multiple shared protocols.
Support HTTP, RS232(Control on-off), Control4 Multiple ways to control.
X20 Pro
New upgrade version Realtek 1296 Quad-Core 64 bit A53 processor, High quality high-power SMPS.
4G DDR4 MemoryοΌ32GB eMMC Super Built-in Storage
perator:, gigabit wired, 802.11 AC 2T2R 867Mbps WIFI, Bluetooth 4.2
X20: SATA 3.0*2, USB 2.0*2, USB 3.0*1, TYPEC *1, Coaxial Cable*1, Optical Fiber*1 , Left/Right Channels*1, AV Output*1, Infrared Input*1, RS232*1, HDMI OUT*2, HDMI IN 2.0*1
ESS 9038 Professional DAC Audio processing Chip :guitarist:
Προσεξτε την διπλασια μνημη (4/32) του PRO εναντι του 'απλου', τη παρουσια εξιδικευμενου chip ηχου (ESS 9038 Professional DAC Audio processing Chip) και οπως επισης οτι λιγοτερο απο εναν μηνα πριν την επισημη παρουσιαση, κουβεντα δεν γινεται για το λειτουργικο...:BDGBDGB53:
Περισσοτερα εν'καιρω..
Θα καθυστερήσει λιγο το λανσάρισμα του Zidoo X20.
Στην καλύτερη τέλη Δεκεμβρη αλλιώς με το νέο ετος.
Τελος, μάλλον θα ονομάζεται Zidoo X20 Pro.
X20
X20 Pro
..και για τιμη -αγνωστο ακομα- στο 'θεο'.. Υπερβολικα 'φιλοδοξες' οι προσδοκιες τους ειδικα οταν ακομα το λογισμικο σου εχει 'τρυπουλες'..
