leonkoum
- 20 December 2008
- 5,217
ΑΝ και ειναι πια για μενα 'old news' η παλια αγαπη δεν ξεχνιετε...
Model: ZIDOO_X9S
Version number: v2.1.42
Link: http://apidl.zidoo.tv/X9S/v2.1.43/ZIDOO_X9S-v2.1.42-202009192015-ota.zip
MD5: C4928AFE27DBD8905C02A8B7505B5EAB
System
1. Increase screen saver function
2. Add support for aiff music files
3. Optimize DLNA projection function
Player
1. Add press the information button to display poster information
2. Fix the problem of pressing the function key to continue playing during pause
3. Optimize subtitle download
4. Fix the problem that the shortcut keys cannot switch chapters
5. Optimize the display of player poster information
6. Added file name display for local player information key
7. Add external subtitles and press the delete button to delete subtitles
Picture Manager
1. New revision of functions
2. Add custom folder function
3. Add the function of setting folders as screensaver pictures
4. Optimize the slideshow function
5. Fix the problem that the vertical screen picture is stretched in the slide show
6. Add the function of exclude folder
7. Add the function of exclusion by folder name
Poster wall:
1. Upgrade version 4.0
2. Optimize the sorting function of the navigation interface
3. Fix the problem that Douban cannot match
4. Solve the problem that the child lock will be ignored when playing directly
5. Fix the problem of incorrect data after sorting widgets
6. Optimize the ratio of local trailers
7. Optimize the sorting function
8. Optimize the details interface
9. Fix the problem of incorrect TV viewing records
10. Modify the problem that the detailed title is too long
11. When optimizing the list display, the letter navigation and the left side bar prompt the picture at the same time
12. Optimize TV series matching
13. Fix the problem that Douban cannot match
14. Add the launch time setting of the trailer in the detail interface
Quick settings
1. Increase screen saver settings
4. Add input method selection settings
File manager
1. Optimize the display of playback records
2. Increase the playback record display switch
3. Fix the problem that the wallpaper of the file manager is not synced occasionally
Blu-ray navigation
1. Increase the function of the information button to display movie information
2. Fix the problem of not being able to navigate after entering the screensaver
Control center
1. Optimize connection stability
App installer
1. Optimize webpage installation function
Main interface
1. Optimize the boot display speed
2. Shortcuts increase sorting function (press the menu key or long press the OK key)
3. Optimize animation fluency
Οπως παντα υπ'ευθυνη σας και παντα να τσεκαρετε το MD5 οτι κατεβασετε σωστα το αρχειο και ειναι το σωστο για το μηχανημα σας. :antlers:
Model: ZIDOO_X9S
System
Player
Picture Manager
Poster wall:
Quick settings
File manager
Blu-ray navigation
Control center
App installer
Main interface
