AZBOX Me & Mini Me
tsakman
Απάντηση: AZBOX Me & MINI ME
Και επίσης βρήκα αυτό.Δε νομίζω να ειναι το επίσημο
http://azbox.me/
nakata
11 June 2007
2,239
var/etc/home
Re: AZBOX Me & MINI ME
Δεν ξερω κατα ποσο ειναι αληθεια αλλα πληροφοριες απο Γιουγκοσλαβια μερια λενε οτι ο δεκτης θα ειναι triple boot δηλαδη μας θα ερθει με επίσημο λογισμικο και θα εχουμε την δυνατοτητα να φορτωσουμε neutrino και android
και να μπουταρουμε τον δεκτη επιλεγοντας το λογισμικο που θελουμε (αντε τωρα να ξεκολλήσεις απο την πολυθρονα και να πας βολτα με την κυρια πρωθυπουργο)
mv_best
11 September 2010
534
και οδηγιες για φορτωση μεσω web interface:
How to flash AzBox Me with Enigma 2 over Web interface
This tutorial, which consist from screenshots will explain You how to flash Your AzBox Me with Enigma 2 or Neutrino HD image.
As far as we noticed, new AzBox bootloader allow You to install three (3) different Neutrino HD or Enigma 2 Images, so at boot it ask You which image You want to boot. In my case I am running official Neutrino HD on Boot 0, Enigma 2 v1.0 on Boot 1 and Enigma 2 TEST release on Boot 2.
So each time when receiver boot i can press on RCU button 1 or 2, or if i dont press anything receiver will by default boot to Neutrino HD which is installed on Boot 0.
1. Turn ON receiver by switching ON on the back panel and by pressing power button on RCU or Front panel and press VOL+, untill it show You on VFD that You are in rescue mode, where You will see also IP address of Your receiver.
2. Enter IP address which is shown on VFD to Your Web browser, and press enter.
3. Now on Your screen You will have this:
4. After You have selected on which position You want to install Your Enigma2 or Neutrino HD image, than You will have this screen, on which You have to click on Browse button and to navigate where Your Enigma 2 flash file is located, and after you choose it click on Upload!:
5. After upload process is done (20-30 seconds), You will have this screen, on which You should press button Flash, and also if You want You can check checkbox Reboot, that Your receiver reboot after flashing process is done, or You can reboot it manually.
6. After flashing process is done (arround 40 seconds), You will get this final screen, so if You didnt check checkbox to Reboot after flashing is done, You can do it manually or You can simpy click on link to go back on main page from where You can do other operations.
tsakman
Το image της Spaze team στον Αzbox ME
και απ'ότι φαίνεται είναι το Availink : AVL2108 το tuner του όπως στους
et9000
qboxhd
coolstream hd1 ( neutrino hd )
nakata
11 June 2007
2,239
var/etc/home
το καλο ειναι οτι ο επεξεργαστης μπορει να υπερχρονιστει απο τα 499 MHz στα 667 MHz και αν μετα τον υπερχρονισμο δεν ανεβαινει η θερμοκρασια του θα ειναι οτι το καλυτερο
kyrliot
31 March 2008
3,913
Καλα ολα αυτα αλλα αν δεν εχει την καλυτερη εικονα σε δεκτη που κυκλοφορει (δηλαδη απο ipbox 9000 με dgs image και με το sigma 8655 χλωμο,γιαυτο ελεγα για 8642) εμενα μου ειναι αδιαφορος (ειδικα με ενα tuner που εχει).Αndroid,media player και αλλα μπιχλιμπιδια εμενα μου ειναι αδιαφορα μιας και τα εχω απο αλλα καταναλωτικα προιοντα.Μονο το feed ειναι ενδιαφερον αλλα και αυτο με την pc καρτα,το εχω.Μακαρι να δω κορυφαια εικονα....
nakata
11 June 2007
2,239
var/etc/home
off topic
παδια εχει ακουσει κανενας απο σας για νεο azbox με επεξεργαστη arm dual-core 1.2 GHz Cortex-A9 M3, 4tuners (2 x DVB-S2, 1 x C, 1 x T) και android?
Φίλιππος Φ.
12 February 2007
3,910
Re: Απάντηση: AZBOX Me & MINI ME
off topic
Εγώ πάντως δεν έχω ακούσει κάτι τέτοιο ...
ΑΝ είναι στα σκαριά μιλάμε για ΤΗ λύση όμως !!!!!!!
jami
21 May 2009
23
Νομίζω οτι οι ΑΖΒΟΧ πάσχουν απο υποστήριξη απο την Opensat και εκεί εντοπίζεται η αδυναμία τους.Τώρα αν περιμένουμε πάλι απο την RTI να βγάλει το φίδι απο την τρύπα όπως έγινε και με τους Elite-Premium,φασκελοκουκούλωστα!Απο hardware καλοί είναι.
Φίλιππος Φ.
12 February 2007
3,910
Μην το πάμε εκεί ...
Γιατι και το official firmware της Dream Multimedia GmbH είναι ΑΔΕΙΟ !
Τα "καλούδια" τα έβαλαν οι διάφορες ομάδες ανάπτυξης στα ανεπίσημα λειτουργικά...
jami
21 May 2009
23
Συμφωνώ, αλλα η RTI εμφανίστηκε μετά απο πολύ καιρό,χωρίς ιδιαίτερη βοήθεια (όπως λέγανε) απο την Opensat.Τώρα χωρίς να υπάρχει δέκτης στην αγορά, έβγαλαν ήδη λειτουργικό!Το ακριβώς ανάποδο απο οτι έγινε με τους πρώτους δέκτες!Μήπως γράφουμε ο ένας πίσω απο τον άλλο?ΧΕΧΕ:BXVZCBXZ6:
Φίλιππος Φ.
12 February 2007
3,910
Βάλε τον εαυτό σου στη θέση της Opensat (ή της οποιασδήποτε εταιρείας).
Θα πάς να υποστηρίξεις κάποιους που δεν τους ξέρεις, χωρίς να έχεις δηλαδή δεί κανένα δείγμα γραφής τους;
Ουτε η Dream το έκανε ...
Το πρώτο Gemini σε Enigma 1 ήταν ΑΠΟΚΛΕΙΣΤΙΚΑ προσπάθεια του team !
Αλλά τώρα πλέον όλοι ξέρουμε οτι η Dream (ανεπίσημα πάντα) "βοηθάει" κάποιες ομάδες, ακόμα και απλά δίνοντάς τους μηχανήματα.
Το ίδιο πιστεύω οτι κάνει και η Opensat με την RTI ...
Γι αυτό και έχουμε ΗΔΗ image για τους Me πρίν καν βγεί ο δέκτης στην κυκλοφορία !
jami
21 May 2009
23
Απο το στόμα σου και στου θεού το αυτί, γιατί τα δείγματα γραφής της Opensat δέν είναι και απο τα καλύτερα.Το γεγονός οτι το επίσημο λειτουργικό, μόνο λειτουργικό δεν ήταν και έπρεπε να βγεί το Enigma να μπαλώσει τις βλακείες της είναι μεγάλο μείον για εμένα.Πολύ αμφιβάλω αν όσοι έχουν αγοράσει ήδη δέκτη της ΑΖΒΟΧ, θα την ξαναεμπιστευτούν για την αγορά επόμενου δέκτη απο την ίδια εταιρία.
