Ελπίζω να είναι χρήσιμα τα παρακάτω και να βοηθήσουν το θέμα. Προσωπικά δεν έχω τεχνικές γνώσεις.There is a debate about the relative merits of Single-Ended amplifiers vs. Push-Pull. Single-Ended amplifiers owe their 'magical' properties to the way the output transformer is used and to the use of zero feedback (we won't cover the zero feedback issue here). There is only a single power tube in a Single-Ended amp, which is connected to the output transformer. As it draws DC power through the transformer, it sets up a magnetic field in the transformer. This current (and field) is at one half of the total current possible when the amp is at rest. At no time does the magnetic field in the output transformer have to reverse polarity- it merely changes in strength.
It takes a small amount of energy to reverse the polarity of a magnetic field in an output transformer; this energy loss is known as 'hysteresis loss'. The energy to reverse the field comes from the signal. If you never reverse the field, this problem goes away. Thus in Single-Ended amplifiers it is relatively easy to make small changes in the current through the transformer. This accounts for the fine inner detail that Single Ended amplifiers are known for.
Push-pull amps by contrast have more bandwidth and power, as the dual power tubes produce opposing magnetic fields in the transformer (while the amp is idling), resulting in no magnetic field. This increases the amount of power and bandwidth the transformer is capable of, but at a price: low level detail. The major issues for small signals occur at the zero crossings: when the signal goes from negative to positive and back again. It takes energy to reverse the field (however small) in the transformer, and this energy requirement results in increased distortion. Thus push pull amplifiers lack the low level detail that Single-Ended amps have in spades.
Eliminating the transformer eliminates this issue and any arguments for single ended operation.
Removal of the transformer from the signal path also reduces other degradations of the signal. There is distributed capacitance in the windings (loading the tubes), series inductance (which can contribute to distortion), hysterysis loss (meaning that anywhere up to 20-25% of the amplifier power is used to create heat) and resistive loss in the windings as well.
These issues cause the transformer to inhibit bass, dynamics, and bandwidth. Detail is lost and tone colors are obscured. In larger output transformers it is almost impossible to get both the bass and the treble right at the same time due to these issues.
OTL technology allows this to be corrected. The lack of a transformer means that the amplifier can deliver the signal with the same speed as a transistor amplifier, but with the sonic benefit typical of tube amplifiers.
OTLs have suffered their own issues over the years, primarily due to the earlier efforts of Julius Futterman and the later failings of New York Audio Labs (Harvey Rosenburg). The Futterman circuit was for many years the most publicly visible OTL, and was prone to stability issues (caused by positive feedback nested within a global negative feedback loop). When in oscillation, (which could be caused by overload, component failure or even layout problems), the amp had a tendency to destroy itself. For many years the public has associated the weaknesses of the Futterman circuit with OTLs in general. Fortunately modern OTLs have solved the earlier problems of the Futterman by (for the most part) using entirely different circuitry.
In fact, every manufacturer who has ever attempted to produce a Futterman amplifier has failed. The public is very demanding of reliability. The 'Futterman legacy' is the largest marketing issue any OTL manufacturer has had to face.
At this point no accurate history of OTLs can ignore Atma-Sphere Music Systems. Founded in August of 1977, Atma-Sphere was created around its radical new approach to OTL technology and the [now attainable] principle of striving only for State of the Art in audio amplification.
Atma-Sphere's biggest claim to fame is that we developed and introduced the world's first reliable and practical OTL. This was accomplished by using a fully symmetrical output circuit (known as the Circlotron; first devised in 1954 by Cecil Hall), which resulted in low distortion. The low distortion meant that little or no feedback was required, resulting in a very stable amplifier. Atma-Sphere is also the first to offer an OTL amplifier in a fully balanced (differential) configuration, allowing for balanced and single-ended inputs. A further innovation was the first use of a fully symmetrical drive circuit for the output section.
The design has been quite successful; Atma-Sphere is now the largest and oldest manufacturer of OTLs worldwide.
There have been only three patents issued to OTL manufacturers since the 1950s; two of them belong to Atma-Sphere.
Our new OTL designs can drive a wider range of speakers than had been previously possible. Eight-ohm speakers can be easily used (and in the case of our larger amplifiers, 4 ohm speakers too), with far greater performance hen other technologies. OTLs are now a very practical choice for discerning audiophiles.
Home | Papers
"Dragging high end audio (kicking and screaming) into the future for over 3 decades..."
