Microsoft Surface Book 2 [2017]
alextrela
28 November 2011
3,129
Έσκασαν και τα πρώτα review και unboxing ενόψει χθεσινής πρώτης ημέρας κυκλοφορίας σε όλο το πλανήτη.
https://www.youtube.com/watch?v=TNvyHcI_eUc
https://www.youtube.com/watch?v=h2xa3ukUecs
https://www.engadget.com/2017/11/16/surface-book-2-review/
Surface Book 2 review: Microsoft gets closer to the 'ultimate laptop
Pros
Hinge is stronger than before
Better CPU and graphics
15-inch screen can fully compete with the MacBook Pro
Works well as a tablet
Cons
Expensive if you need more storage
Doesn’t come with Surface Pen
Summary
The Surface Book 2 is one of the most powerful and well-designed Windows laptops on the market. And thanks to its improved hinge, it doesn’t feel any different than a traditional notebook. It’s the best MacBook Pro competitor we’ve seen yet.
https://www.youtube.com/watch?v=DRi8j6R8t9Y
https://www.windowscentral.com/surface-book-2-13-review
A WORTHY SUCCESSOR
Surface Book 2 13-inch review: A good thing made great
PROS:
Serious computing power for professionals, students, and even some gaming.
Refined and improved hardware for 2017.
All-day battery life.
Excellent display and typing.
A PC that is nearly capable of everything.
CONS:
No Thunderbolt 3.
Still very expensive.
alextrela
28 November 2011
3,129
https://www.youtube.com/watch?v=-Hh0lZ7Jg4U
POWERFUL, STYLISH, AND PRODUCTIVE AF
Surface Book 2 15-inch review: The ultimate Windows laptop gets bigger and better
I have a lot of laptops at my disposal, but it is the Surface Book 2 15 that does everything. Gaming, inking, tablet, productivity, all the ports I need, excellent typing and that outstanding battery life. There is no other device on the planet right now that is as capable as the Surface Book 2 15 and that says a lot seeing all the great hardware HP, Dell, Lenovo and the rest are bringing to market.
The Surface Book 2 15 is not just the ultimate laptop it may very well be the ultimate PC.
See at Microsoft
PROS:
Excellent build quality and features.
A true gaming PC with outstanding performance.
It does everything a PC an do in 2017.
CONS:
Very expensive.
No Thunderbolt 3 or eGPU support.
Windows Mixed Reality seems like an afterthought.
waroo
20 April 2012
1,697
είναι εκπληκτικά μηχανάκια αλλά η έλλειψη thunderbolt 3 ή τουλάχιστον 2 θυρών usb-c είναι τρομερή παράλειψη, ειδικά σε αυτή την κατηγορία τιμής (στρατόσφαιρας).....
το δοκίμασε κάποιος φωτογράφος στο dpreview και γράφει ότι χαιρέτησε στεγνά το macbook pro του
waroo
20 April 2012
1,697
ε δε θα κανει 2,5 χιλιαρικάκια; εύκολα.....
και με 256αρη δισκο μονο.... άλλο ένα φάουλ
ειναι πολλά τα λεφτά....
23,811
Δυστυχώς τα προϊόντα δεν τιμολογουνται με το βιοτικό επίπεδο του ελλαδισταν και κάθε ελλαδισταν.
Σκασιλα τους αν δεν πουληθεί ουτε ενα εδώ.
Τα 2.5 χιλιάρικα είναι ενα μηνιατικο ενός καλού υπαλλήλου σε μια π.χ. πολϋεθνικη εταιρεια σε π.χ. Λονδινο-Νεα Υορκη κλπ. Δεν μιλάω ουτε για διευθυντή ουτε για μεγαλοστέλεχος.
Που και παλι και αυτοι το θεωρουν xtreme να δώσουν ενα μηνιατικο για ενα laptop όταν υπαρχουν τόσες επιλογές με τον μισο μισθό τους. Απλα θα τα δώσουν οι πορωμενοι και θα πάρουν μια γαλοπούλα λιγότερη τα Χριστούγεννα :)
waroo
20 April 2012
1,697
και εδώ που τα λέμε η τιμολόγηση του κορυφαίου windows hybrid laptop με τόσα καλούδια είναι εφάμιλλη αυτή του άμεσου ανταγωνιστή του από το άλλο στρατόπεδο (macbook pro)
αν το κρίνεις έτσι, μη πω ότι είναι και (πιο) φθηνό...
πάντως αν μπορεί να αγοραστεί από το εξωτερικό, σε κάποια περίοδο προσφοράς και με τιμολόγιο (για το κέρδος του ΦΠΑ), κάπως θα παλεύεται
alextrela
28 November 2011
3,129
Microsoft Surface Book 2 (13.5", i7, GTX 1050) Convertible Review
https://www.notebookcheck.net/Micro...-i7-GTX-1050-Convertible-Review.263954.0.html
Pro
high-quality housing
very good screen without PWM
high performance, despite passive cooling
very long battery life
comfortable input devices
decent cameras
often silent in everyday life
Contra
very loud GPU fan (depending on power setting)
Power supply is not always sufficient
no Thunderbolt 3
Surface Pen is no longer included
significant power reduction (especially CPU) in battery mode
Hinge teeters on touch inputs
no LTE
virtually no upgrade options
long loading time (especially tablet)
expensive, especially the surcharges for more storage
Verdict
In review: Microsoft Surface Book 2. Test model courtesy of Notebooksbilliger.
Microsoft promises a lot for the new Surface Book 2. The 13.5-inch convertible is a really good device in some respects, but we are sometimes wondering why the manufacturer ignores known issues or waives modern standards, respectively.
Let's begin with the good things. Microsoft says the new device is twice as powerful as before. This is true as long as you focus on the CPU performance. The new ULV quad-core from Intel is much faster compared to the previous dual-core models. We can only praise Microsoft for the performance utilization, which is very decent, despite the passive cooling. Some laptops with actively cooled CPUs perform worse. However, not much changed for the graphics card. Yes, the GTX 1050 performs well, but it is not much faster than the previous GTX 965M. The new Surface Book 2 also lasts longer on battery, still uses an excellent display, and has a nice chassis with comfortable input devices.
The Surface Book 2 13.5" is once again almost unrivaled thanks to the good performance. However, there are some compromises (no Thunderbolt 3!), which are hard to swallow for the high price.
The biggest problem is revealed when you stress the dedicated GeForce GPU, because the fan is really loud. We showed how you can easily bypass this issue with the new performance settings of Windows without sacrificing much performance.
A bigger issue, which seems to be acceptable for Microsoft, is the power delivery. The power adapter is not always sufficient during gaming, so the batteries are slightly discharged and charged again. This cannot be good for the battery health. It might be related to a limitation of the Surface Connector since the power adapter of our test model should be sufficient. This brings us to the next problem, the ports. Microsoft probably sticks to the Surface Connector to ensure compatibility with the old Surface Dock. This is unfortunately a big limitation. A modern Thunderbolt 3 port would be more practical and future-proof. An additional USB Type-C port at the tablet would have been nice as well.
The battery situation is not perfect, either. There is a connector for the power adapter at the tablet, but it still takes almost 2.5 hours to charge the small battery. This can probably be fixed via software update. An "empty" tablet can unfortunately not be charged by the battery in the keyboard unit, either.
You can easily avoid the loud fan in this case and the power delivery should not be a big deal in practice as long as you avoid the Best Performance setting. The missing Thunderbolt 3 support is a bigger issue for more than 2200 Euros ($1999) though. The Surface Pen is not included anymore, either, and has to be purchased separately. The 13.5-inch convertible is still almost unrivaled on the market thanks to the high performance and leaves a positive overall impression.
alextrela
28 November 2011
3,129
Full αναλυτικό review για το 15αρι από AnandTech.
The Microsoft Surface Book 2 (15-Inch) Review: Second Time's The Charm
https://www.anandtech.com/show/12167/the-microsoft-surface-book-2-15-inch-review
Κάπουα βασικά συμπεράσματα.
1.CPU Conclusion
As we saw with the ASUS ZenBook 3, the move to quad-core in the U series of Core chips has been very welcome. The performance increase is impressive over the older dual-core models, and although the eight threads run into the thermal limit quicker than the do on the higher-wattage HQ series chips, such as seen in the Dell XPS 15, the Core i7-8650U is still a very strong performer.
2.The GTX 1060 is a massive improvement over the original GT 940MX based Surface Book, and moves it out of being somewhat better than integrated, into a laptop with some serious gaming potential. The performance difference on the most GPU demanding test, Fire Strike, over the GTX 1050 is also a huge leap
GPU Conclusion
The jump from the original GT 940MX found in the Surface Book, to the GTX 1060 in the Surface Book 2, is a massive increase in performance. The Surface Book 2 isn’t what most people would consider a gaming laptop, but the 15-inch model offers plenty of compute if you ever do want to game. For office productivity, apps that take advantage of CUDA, such as Adobe’s suite, should see some much-improved performance over almost any other productivity laptop. Really, to match the GPU performance in this laptop, you’d have to jump into the gaming notebook arena with something like a Razer Blade 14.
3.Display Conclusion
Microsoft continues to be the only major PC maker to color calibrate all of their devices, and the Surface Book 2 sets new levels for accuracy in a notebook. The display also has amazing contrast. It’s not difficult to add these together and say that the Surface Book 2 has the best display on any laptop
4.Speakers
Much like the new Surface Pro, the speakers on the new Surface Book 2 have improved in sound quality, offering stronger mid-range and bass levels than before. They sound remarkably good, for a notebook. The speakers are located in the display and are front firing, which likely helps with the sound as well. They don’t get overly loud, at around 74-75 dB(A) on our test track, but with the better sound quality that’s a good trade-off.
5.Final Words
https://www.anandtech.com/show/12167/the-microsoft-surface-book-2-15-inch-review/8
waroo
20 April 2012
1,697
:drool1:
αφού το anand τους κράζει μόνο για το thunderbolt 3 (το οποίο βέβαια είναι epic fail ή πιο σωστά τιτανο-τεράστιο) και λέει ότι έχει την καλύτερη οθόνη εκεί έξω, μπροστά και από όλα τα macbooks κλπ....
.....καταλαβαίνουμε ότι μιλάμε για ΤΟ εργαλείο
ειλικρινά, δε θυμάμαι το συγκεκριμένο site να γράφει με τόσο ενθουσιασμό για άλλο προϊόν αυτής της κατηγορίας εκτός των macbooks.
sokos
19 January 2007
2,316
το λέω εγώ απο το καλοκαίρι για την οθόνη πόσο απιστευτη ειναι (στο Surface Laptop ίδιες οθονες ειναι νομίζω)
Το έβαλα το S.Laptop διπλα διπλα σε ΜΒ Pro και ήταν σαν ξεθωριασμένο το MB σε σχέση με το MS.
alextrela
28 November 2011
3,129
Διαθέσιμο και στην Ευρώπη από σήμερα μεταξύ άλλων γεωγραφικών περιοχών του πλανήτη το 15αρι Surface Book 2
Surface Book 2 coming to all Surface markets
https://blogs.windows.com/devices/2...g-to-all-surface-markets/#OWAXQHyEWTdtTRpG.97
Today, we’re excited to bring the power of versatility of Surface Book 2 to more people around the world. Pre-orders for Surface Book 2 15” will begin today in Australia, Austria, Belgium, Canada, Denmark, Finland, France, Germany, Ireland, Luxembourg, the Netherlands, New Zealand, Norway, Poland, Sweden, Switzerland, and the United Kingdom.
Later, beginning in February and continuing through March and April, Surface Book 2 13” and 15” will roll out to Bahrain, China, Hong Kong, India, Italy, Korea, Kuwait, Malaysia, Oman, Portugal, Qatar, Saudi Arabia, Singapore, Spain, Taiwan, Thailand and the United Arab Emirates.
