Απάντηση: Re: Απάντηση: MPC Home Cinema : Βασικός Oδηγός Αναπαραγωγής, Ρυθμίσεις, Προ
Ctrl+Alt+Shift+Break | manual freeze report functionality |
Ctrl+Alt+Shift+T | switches between video (DXVA) and film (IVTC) content type |
Ctrl+Alt+Shift+D | turns deinterlacing on/off |
Ctrl+Alt+Shift+F | switches deinterlacing field order (auto, top, bottom first) |
Ctrl+Alt+Shift+B | displays and decreases the Gamma value |
Ctrl+Alt+Shift+G | displays and increases the Gamma value |
Ctrl+Alt+Shift+I | toggles input levels |
Ctrl+Alt+Shift+C | toggles gamma curve type |
Ctrl+Alt+Shift+M | toggles decoding matrix |
Ctrl+Alt+Shift+P | toggles source primaries |
Ctrl+Alt+Shift+C | displays & toggles color format (BT.709 -> BT.601 -> PAL) |
