Απάντηση: Re: Panasonic GH5
Aύριο παρουσιάζεται τα επιβεβαιωμένα χαρακτηριστικά απο το
digicameinfo ειναι :
LUMIX DC-GH 5
β Number of effective pixels 20.3 million pixels (total number of pixels: 21.77 million pixels)
β 3,680,000 dots organic EL EVF (0.76 times)
β 1.62 million dots free angle monitor (touch panel)
β Wi-Fi (802.11a / b / g / n / ac), Bluetooth (v4.2) installed
β USB type-C (USB 3.1 GEN 1)
β Dual SD card slot
β 138.5 x 98.1 x 87.4 mm
β 645 g (main body only), 725 g (SD card, battery included)
LEICA DG Vario-Elmarit 12 β 60 mm F 2.8 β 4 Power OIS
β Lens construction: 12 groups 14 pieces (4 aspheric lenses and 2 ED lenses)
β Shortest shooting distance: 20 cm (wide angle), 24 cm (telephoto)
β Maximum shooting magnification: 0.3 times (converted to 35 mm 0.6 times)
β Shake correction: POWER OIS
β Filter diameter: 62 mm
β Size (maximum diameter Γ length): 68.4 mm Γ 86 mm
β Weight: 320 g
και απο το 43rumors :
1. Slow motion up to 180 fps!
2. much larger number of focus point: 225 vs 49 in the GH4.
3. Same body weather sealing as the E M1 II β up to minus 10 degrees of cold.
4. 5 axis IBIS
5. The 20MP sensor is actually NEW
6. No more limit about the duration of recording. 29 minutes in Europe.
7.The audio XLR microphone hotshoe mounted I/O interface will be compatible with the DMC-GH4.
8.It has full size HDMi
9. Panasonic plans to start shipping out the GH5 in March/April!
10. Body only: Price will be between 1 800 and 2 000 in Europe for the DMC-GH5.
11. Price will be ± 2 900 for the DMC-GH5 + the new Panasonic Leica 12-60 Lens (not the older 12-60mm lens!)
