Ευχαριστώ για την απάντηση αλλα έχω ρωτήσει αν κανείς γνωρίζει αν μπορώ να βάλω το patch σε dual boot η αν το βάλω θα χάσω την dual boot δυνατότητα και θα πρέπει να το ξαναφτιαξω απο την αρχή.
Για σένα, E2 usb flashaki αφήνοντας το επίσιμο όπως έχει.
Install E2 to Azbox\USB stick in 10 easy steps.
10 easy steps to get E2 to run from USB stick on your Azbox.
Download your E2 image (will be a .E2 file once extracted)
1) format a USB stick as fat32 on your PC
2) download and extract Jazup2.3 (full not lite) to PC
3) extract the file called "patch.bin" from "Official to E2" (cant remember exact name) folder within the Jazup folder AND copy to theUSB stick
exact folder = C:\Jazup_2.3_by_Hectore_and_Pr2\J azup_2.3_by_Hectore_and_Pr2\Offic ial_To_E2 folder
(extract the zip file using winrar)
4) turn off azbox
5) insert USB stick into front of Azbox, and switch on.
6) on the TV screen, choose to run USB upgrade (usb - ripper kernel) once finished switch off Azbox.
7) take out usb stick and format the same stick again as FAT32 in your pc (im not sure if this is neccessary TBH).
8) insert USB stick into front of Azbox, and switch back on - it will come to rescue mode with an IP ADDRESS scrolling along the lcd display.
9) on your PC run JAZUP2.3.bat - select USB (not HDD or DOM) tick the box for "format extended" (but DO NOT tick box for ext4) - and type in the IP address of your azbox in the top
10) now choose upgrade to E2 - it should then ask you to browse for your E2 file, select it, and choose ok - now, watch and wait.
Notes: if i left format ext4 on, the process crashed mounting MPP (about 50%)
also, if you get a FTP timeout error - just repeat step 10.
ps. you have to install java to get work Jazup2.3
and in step 3 do it like this :
after you have downloaded Jazup - and extracted the files
you will find in the: C:\Jazup_2.3_by_Hectore_and_Pr2\Jazup_2.3_by_Hecto re_and_Pr2\Official_To_E2
there is a file called PATCH.BIN, copy that to the formatted (fat32) stick, and then boot up the azbox with the stick in it..
this changes the Kernel on the box, from official to E2
