Davinci Resolve Updates
evanfotis
26 March 2008
5,475
"if it aint broke don't fix it" κατάσταση. Εκανα εγκατάσταση και ενα δοκιμαστικό project που πριν επαιζε κανονικα, τωρα βγάζει συνεχώς GPU memory full... Και δεν ανταποκρίνεται.
Kosh
7 September 2006
91,153
Εκεί ψηλά.....
Other than that, the new Resolve 17.3.2 also brings improvements and bug fixes. Here is the full list:
  • Addressed instability issues when using the color warper.
  • Addressed incorrect HDR highlight when using DaVinci Wide Gamut.
  • Addressed a naming issue for recorded clips in the Fairlight timeline.
  • Addressed incorrect reloading of cached audio effects on linked tracks.
  • Addressed missing EQ and other automation issues in Fairlight.
  • Addressed incorrect Fairlight Spaceview display for specific AMD drivers.
  • Addressed potential freezes after using Fusion tracker modifiers.
  • Addressed a Fusion planar transform issue on small images.
  • Addressed an issue with uploads for renders on Apple Silicon systems.
  • Addressed an issue with the classic stabilizer on Apple Silicon systems.
  • Addressed an issue with LUT generation on Apple Silicon systems.
  • Addressed out of order frames when decoding certain XAVC clips.
  • Addressed an issue with importing malformed CLF LUTs.
  • General performance and stability improvements.
evanfotis
26 March 2008
5,475
Blackmagic Design Announces DaVinci Resolve 17.4​
DaVinci Resolve 17.4 Features​
Key Features
  • Hardware accelerated Apple ProRes on Apple M1 Pro and M1 Max.
  • 120Hz support on Apple M1 Pro and M1 Max for smoother UI and playback.
  • Faster DaVinci Neural Engine performance on Mac OS 12.
  • Native HDR viewers on supported Mac hardware.
  • Comments and annotations sync between Dropbox Replay and DaVinci Resolve Studio.
  • Markers and comments sync between Dropbox and DaVinci Resolve Studio.
  • Export timeline markers titles as YouTube video or Quicktime chapters.
  • Steinberg VST3 support giving access to even more audio effects.
  • Simplified color management, SDR and HDR selection and new automatic project settings.
  • New Resolve FX including film halation.
  • Improved 3D keyer and matte finesse controls.
  • Text+ support for combining glyphs, vertical layouts and right to left for Arabic, Hebrew etc.
  • Significantly faster ProRes decode, encode and AI performance for M1.
  • Subtitle backgrounds auto resize and nested timelines decompose to parent.
Support for Apple M1 Pro and M1 Max
  • Native full screen mode on Mac.
Dropbox Comment Integration
  • Dropbox login within DaVinci Resolve preferences.
  • Render directly to Dropbox or Dropbox Replay.
  • Automatic background uploads when render completes.
Edit
  • Subtitle and caption backgrounds now auto-resize to fit text content.
  • Subtitle tracks in nested timelines now decompose to the main timeline.
  • Adding a new subtitle caption now auto-focuses on the text area.
  • Simple titles and subtitles are faster on Apple Silicon systems.
  • Improved ease in and out functionality for position curves in the timeline.
  • Options to include effects and grades for render in place operations.
  • Switch multicam angles in the edit page with the speed editor.
  • Ability to mark selection for timeline gaps.
  • Edit asymmetric audio transitions created in the Fairlight page.
  • Trim video and audio transitions asymmetrically using cmd/ctrl.
  • Fine audio clip gain adjustments using shift + mouse drag.
  • Support for pasting retime attributes on audio clips.
  • Option to limit audio sync to the first timecode match.
  • Preview composite modes by hovering over each mode in the inspector.
  • Ability to set per-clip deinterlace quality in the inspector.
  • New square iris transition.
  • Support for custom aspect ratio controls for shape transitions.
  • Improved overlays for Fusion tools in the viewer.
  • Improved undo support for Fusion effects and Text+ in the inspector.
  • Support for folder based organization of effect templates.
  • New customizable key actions to go to previous/next timeline tabs.
  • Ability to close timeline tabs with middle click.
  • Preview generators and titles from the effects panel in the cut viewer.
Color
  • Support for an automatic mode for color managed projects.
  • Support for ACES 1.3, gamut compression and new CSC transforms.
  • New 3D Keyer with new modes, better selection/stroke logic, live feedback.
  • Improved HSL and Luma keyers with updated matte finesse controls.
  • Track forward and back with a single action in trackers and magic masks.
  • Node tooltips now indicate LUT and effect type present.
  • Dragging new links to layer and key mixers auto-creates node inputs.
  • Dragging color nodes over key links creates key-to-RGB connections.
  • Added individual primary and secondary tool icons for faster switching.
  • Clip filters for timeline clips with Dolby Vision analysis or trim.
  • Disabled clips are now shown as gray in the timeline.
  • Support for applying camera LUTs and CDLs to ARRI MXF ProRes clips.
  • The printer light state is now persisted across application restart.
  • Navigating to markers in the timeline now auto scrolls to center marker.
Resolve FX
  • Film halation emulates film stock reflections and scatter with Studio.
  • Custom mixer to combine effects and grades with finer control.
  • Improved 3D, HSL and Luma keyers in edit and Fusion.
  • Better noise handling and key refinement for existing keyers.
  • Improved patch replacer with ability to align source and target.
  • Film grain with interactive previews and grain freeze options.
Fairlight
  • Support for Steinberg VST3 audio plugins on Mac OS and Windows.
  • Ability to reorder, move and duplicate effects in the mixer.
  • Support for copying clip ranges with partial fades.
  • Single sided audio transitions are now displayed as fades.
  • Support for multi channel audio outputs on Linux.
  • Better waveform displays at smaller track heights and lower zoom levels.
  • Ability to shift-click and cmd-click on keyframe selections in the timeline.
  • Navigating to previous or next timeline marker now selects the marker.
  • Improved default processing order in Fairlight mixers.
  • Automation curves display current values when no automation is present.
  • Point selections now flash in edit selection mode.
  • Improved column order and search behavior in the clip index.
  • Improved jog, scroll and shuttle with the editing keyboard and speed editor.
  • Fairlight FX meters have resizable displays and improved channel labels.
  • Improved audio performance when using Blackmagic monitoring devices.
Fusion
  • Text+ support for combined glyphs and right to left language layouts.
  • Improved vertical Text+ layout, vertical glyphs, rotation and line direction.
  • Improved Text+ character grouping, spacing, underlining and borders.
  • Text+ supports per-character stylistic sets for supported fonts.
  • Support for OpenType features, including old-style numbers in Text+.
  • Multiple Text+ improvements for character styling and animation.
  • Hover to show tool descriptions in the effects panel and add tool window.
  • Improved default tracker search and pattern size for grid warps.
  • New search area scale slider in tracker options.
Codecs and File I/O
  • Improved encode settings for YouTube render preset.
  • Option to export a timeline marker color as YouTube video chapters.
  • Option to export a timeline marker color as QuickTime chapter markers.
  • Support for decoding opus audio in QuickTime and MP4 clips.
  • Hardware accelerated Panasonic 8K AVC decodes on Apple Silicon.
  • Improved decode speeds for ARRI ARX clips.
  • Hardware accelerated H.265 encodes on free version on Windows.
  • H.264 encode profile options on supported Nvidia systems with Studio.
  • H.264/H.265 encode bit rate controls on supported Windows Intel systems.
  • Faster encodes and decodes for Windows Intel systems with Studio.
  • Support for encoding to ZIP1 EXR format.
  • Ability to add custom languages in DCP/IMF composition naming options.
  • Ability to use approved operator / rating / region lists for DCP naming.
  • Marker support in the IO encode plugin SDK
  • Ability to bypass re-encodes for Sony XAVC Intra clips.
  • Improved retention of comments metadata for third party XML workflows.
  • Improved display of render job names with tooltips.
General
  • Right click audio icon to adjust volume on media, color and deliver pages.
  • Auto-identifying media storage sequential image formats as stills or clips.
  • Prompt to overwrite existing projects when invoking save as.
  • Locked project indicator for PostgreSQL databases with usage info tooltip.
  • Ability to clone a PostgreSQL database from the project manager.
  • Ability to export PostgreSQL access keys from the project manager.
  • Option to import into current timeline when importing an AAF.
  • Scripting API support to access inspector properties for video clips.
  • Scripting API support to set playhead position on the timeline.
  • Scripting API support to get color version for video clips.
  • Scripting API support for reflecting upload status in render job APIs.
  • Scripting API support for setting network optimization in render jobs.
  • Scripting API support for H.264 multi-pass encode option in Mac OS.
  • Improved scripting property set when querying MediaIn nodes.
evanfotis
26 March 2008
5,475
What's new in DaVinci Resolve 17.4.1
• Improved frame based imports from Finder.
• Addressed an issue with HDR on viewers on Mac.
• Addressed an issue with banding on video clean feed on Mac.
• Addressed incorrect fades when trimming in the edit timeline.
• Addressed an issue displaying certain unicode characters in Text+.
• Addressed an issue where Text+ expressions would not work.
• Addressed slow playback for Text+ with character styling.
• Addressed retention of smart filters between projects.
• Addressed nested macros not rendering or showing previews in Fusion.
• Addressed incorrect Fusion viewer behavior with tablet input devices.
• Addressed trim interpolation for imported XML Dolby Vision metadata.
• Addressed incorrect PAR values on some Blackmagic RAW clips.
• Addressed issue with lost customized subtitle backgrounds.
• Addressed an issue with unintended markers on Sony MXF clips.
• Addressed a decoding issue with Panasonic XAVC clips on Mac.
Χρειαζόταν γιατί η 17,4 είχε αρκετά bugs, δεν εφαρμοζόντουσαν εφφε, δεν έκανε update η timeline και αλλα.
evanfotis
26 March 2008
5,475
Today we announced DaVinci Resolve 17.4.2 update which improves playback performance for Fusion titles and effects. This means you can get a better sense of how the scenes are flowing with titles and effects applied.
This update also improves system stability when rotating power windows using the DaVinci Resolve Advanced Panel, or changing location preferences such as when selecting the Chinese keyboard, as well as or when working on Windows Intel graphics systems with old drivers. These improvements will enable you to work more consistently with fewer interruptions.
For Fairlight, there’s better handling of VST3 plugins which will result in fewer crashes and faster scanning of the plugins at startup. Improvements to dynamic delay compensation of VST3 plugins will now result in a more accurate positioning of the effect on the timeline, giving you confidence that you are monitoring audio effects correctly.
In addition, this update addresses an issue where parts of H.264 clips may have shown up offline on Windows. Now, they will correctly reflect the clip’s online or offline status making it easier to review your timeline during the editing process. Plus, when you’re using ProTools render presets to export your project, DaVinci Resolve will now accurately apply handles settings, making it easier for you to collaborate with others on audio post production.
DaVinci Resolve 17.4.2 update is available now as a free download from http://bmd.link/kV9q7t
evanfotis
26 March 2008
5,475
Kαλό φυσικά που συνεχώς βελτιώνουν, αλλά κάθε φορά χαλάνε και κάτι.... Τώρα δεν εμφανίζεται το thumbnail image στο Color page στα Nodes.... Σκέτο γκρι...
evanfotis
26 March 2008
5,475
Today we announced DaVinci Resolve 17.4.3 update which improves system stability when working on Windows computers with Intel GPUs. This update also supports more reliable character styling behaviour with Fusion text that makes it easier and faster to create titles and more accurately displays the blanking region as black when working with various aspect ratios.
For Fairlight, this software update adds the ability to instantly rename bounced clips in the media pool, which speeds up your audio workflow. Additionally, it not only supports more consistent crossfade behaviour when editing clips but also supports a more accurate Fairlight Accelerator monitoring experience on fixed bus projects, making it easier to mix down your projects.
There have also been further improvements to decode performance when working with ProRes files on Apple Mac models with M1 Max processors enabling you to play back, edit and grade your ProRes projects even faster.
DaVinci Resolve 17.4.3 update is available now as a free download from http://bmd.link/4arjRt.
Reactions: Kosh
evanfotis
26 March 2008
5,475
Ξέρεις γιατί η bmpcc4k δεν εφαρμόζει το LUT όταν γράφει σε Prores 422 ενώ το έχω στις ρυθμίσεις embed in file;
ούτε το στέλνει εξω στην HDMI ενω πάλι ειναι ρυθμισμένη να το εφαρμόζει...
Με το Braw δεν εδινα σημασια, το εβαζα μετα αλλα οταν χρειάζεται ετοιμη εικόνα να φύγει, βγαίνουν ξέπλυμα ολα..
Kosh
7 September 2006
91,153
Εκεί ψηλά.....
Λοιπον εμαθα.
Όταν λέει embeded δεν είναι στο video file τελικα.
Θα πρέπει να ήταν εντελώς ηλίθια μια εταιρία για να κάνει κάτι τέτοιο. Το embed είναι στα metadata μονον.
Στην ουσια αυτο ειναι μια δικλειδα ασφαλειας αν το LUT που έχεις βάλει δεν είναι σωστο ή χαμηλης ακριβείας.
  • Wow
Reactions: evanfotis
