Changes since*120815_2150:- NOTE: This is a minor update to 120815_2151. - Dune HD TV models: Bugfix: Vidimax application could report "error 7" in some cases during playback. - Bugfix: fixed problem with the playback of certain MMS URLs (the problem appeared in the firmware version 120608_1420_beta). - Bugfix: playback of MPEG-TS streams w/o audio and with temporary audio dropouts could cause problems. (This includes playback of multicast, HLS, DVB MPEG-TS streams.) - Bugfix: playback of media content via HTTP protocol could cause hangup in some cases (e.g. when the server did not respond). - HLS playback improvements: - By default, the initial quality is now chosen based on the previous statistics (remembered till reboot). - Various performance and stability improvements. - Bugfix: too long HLS URLs were refused to play. - media_url: 'hls_initial_bandwidth' parameter extended with new possible values: 'auto' and 'auto_high'. - More details:
http://dune-hd.com/support/misc/media_url.txt - Improvements in API for PHP plugins: - Default PHP plugin operation timeout increased to 60 seconds. - Bugfix: PHP plugin operation was handled in wrong way in some cases. - Bugfix: EPG OSD column had wrong title in some cases. - Dune HD TV models: Improvements in API for HTML+JS applications: - Bugfix: when playing HLS stream, read error events could be wrongly generated even in the absence of any errors.
