-LG TV Line-up 2020-
georget
31 March 2007
3,109
Λευκωσία
Πιο φωτεινή η νέα OLED από τις QLED. Μεγάλη βελτίωση στο Game mode σε σχέση με τις προηγούμενες. Ειδικά με την την δικη μου B7 που είναι απελπιστικά σκοτεινή στο game mode.
xavito
29 October 2008
8,991
65"...[avforums.com]...LG 65GX review,calibration...https://www.avforums.com/reviews/lg-gx-oled65gx-4k-oled-tv-review.17543
image.php
00:33:08 - Steve reviews the 65-inch LG GX OLED TV
https://www.youtube.com/watch?v=1p08LNprt8k
source:[avforums.com]
Verdict
Should I buy one?
That really depends on what you want. If your main interest is the aesthetics of the TV, then the LG GX is the perfect choice. The ultra-thin chassis is gorgeous, and the build quality is exceptional. There’s no denying this is a gorgeous piece of industrial design that will look stunning when wall mounted. But if you're more interested in the features, then the cheaper CX is identical in this regard.
And what a feature set it is, with support for 4K Ultra HD, HDR (including Dolby Vision IQ), and Dolby Atmos. The newly added Filmmaker Mode ensures you can enjoy movies as the content creators intended, and the overall accuracy is really impressive. There are also extensive calibration controls, and a great autocal feature that even has a pattern generator built into the TV.
The inclusion of HDMI 2.1 inputs remains a competitive advantage for LG, who are the only manufacturer to embrace this connection on its 4K TVs. It means this OLED TV not only supports eARC but also HFR, VRR and ALLM. That’s sure to please gamers, as will a low input lag, fast response time, HGiG profile and G-Sync compatibility.
Overall, it’s a superb TV that delivers the kind of gorgeous images you expect from an OLED. Of course it’s not perfect, and if you’re looking for criticisms the HDR could be brighter and will never fully compete with an LCD TV. There’s no HDR10+ support either, although that’s not really a great loss these days as Dolby Vision dominates. There’s also the slight possibility of screen burn, so anyone who games extensively should bear that in mind.
However, in all other respects the LG 65GX is a fantastic TV that looks stunning whether it’s on or off, and comes highly recommended. It’s best suited to wall mounting, so if you’re not planning on doing that or the design isn’t that important to you, then you might want to consider the CX instead.
Highly recommended
user2726
Inactive User
7 September 2008
641
Xavito,
μας έσκασες....πότε θα κυκλοφορήσουν τελικά με προσφορά στην Ελλάδα?
Αυτό να είναι το επόμενο post σου!
Καλό μήνα σε όλους τους Lgάδες
papasouzakias
13 May 2009
4,523
Η LG αφαίρεσε την υποστήριξη DTS από τα μοντέλα του 2020.
Από ότι φαίνεται η LG ακολούθησε την πολιτική της Samsung και δεν υποστηρίζει το DTS στις τηλεοράσεις του 2020.
Το διαπίστωσαν καταναλωτές στην Αμερική που αγόρασαν τις νέες OLED και διαπίστωσαν πως οι τηλεοράσεις δεν αναπαράγουν τον ήχο DTS ούτε τον κάνουν passthrough.
https://www.avsforum.com/forum/40-o...-lg-cx-gx-owners-thread-no-price-talk-81.html
Ακόμα και στα χαρακτηριστικά των νέων τηλεοράσεων δεν ανεφέρεται υποστήριξη DTS, μόνο Dolby Digital και Dolby Digital Plus.
Άλλοι μιλάνε ότι η κίνηση αυτή έγινε για να μην πληρώνει δικαιώματα χρήσης του DTS ενώ άλλοι μιλάνε πως θέλει έμμεσα να καταπολεμήσει τη πειρατεία αφού το DTS το έχουν ριπαρισμένα mkv που παίζουν από τον ενσωματωμένο usb player, ενώ το Dolby Digital υποστηρίζεται από τις streaming υπηρεσίες όπως το Netflix.
Μια δυσάρεστη εξέλιξη αφού πολλοί επέλεγαν LG λόγω της υποστήριξης DTS.
user2726
Inactive User
7 September 2008
641
Να γιατί θα αγοράσω TV OLED μόνο την BF του 2021.
Εκτός από τον παραπάνω λόγο που μας εξέθεσε ο συμφορουμίτης papasouzakias, υπάρχει και ένας άλλος, ο εξής : Η Τηλεόραση LG 4K 2020 θα είναι χωρίς HDMI 2.1 πλήρους φάσματος!
Μια συνέντευξη που κυκλοφόρησε στο Forbes αποκαλύπτει πώς η LG φέτος έχει ενσωματώσει 48 Gbit / s HDMI συνδέσεις μόνο στα μοντέλα OLED 8K και LCD NanoCell, ενώ η σειρά 4K θα έχει 40 Gbit / s εισόδους που επαρκεί για 4K / σήματα 120fps με βάθος χρώματος 10-bit ανά συστατικό και δειγματοληψία 4: 4: 4
Σύμφωνα με όσα δημοσίευσε το Forbes, η σειρά LG 4K OLED και Nanocell 2020 θα ενσωματώνει εισόδους HDMI 2.1 με μέγιστο εύρος φάσματος τα 40 Gbit / s.
Έτσι η κατάσταση διαμορφώνεται ως εξής: οι OLED WX, GX και CX θα έχουν τέσσερις εισόδους HDMI των 40 Gbit / s, ενώ μόνο οι νέες τηλεοράσεις 8K OLED ZX και LCD Nano 99/97/95 θα έχουν δύο εισόδους HDMI 2.1 πλήρους φάσματος (48 Gbit / s) και δύο των 40 Gbit / s.
Απαιτούνται 48 Gbit / s για 4K, 120fps, 12 bit ανά στοιχείο και δειγματοληψία 4: 4: 4. Ωστόσο, το βάθος χρώματος των 12 bit υποστηρίζεται μόνο από το Dolby Vision και τα πάνελ στην αγορά τα οποία φτάνουν επί του παρόντος στα 10 bit.
Το τερματικό HDMI 40 Gbit / s εξακολουθεί να επαρκεί για τη διαχείριση 4K / 120fps στα 10 bit ανά στοιχείο και τη δειγματοληψία 4: 4: 4. Ο περιορισμός είναι συνεπώς σχεδόν βέβαιος, αλλά δεν θα ισχύει το ίδιο για τα OLED BX και LCD Nano 91, Nano 90 και Nano 86, τα οποία έχουν μόνο δύο εισόδους HDMI 40 Gbit / s, ενώ το άλλο ζεύγος είναι 2.0b ( 18 Gbit / s). Θα αποτελεί έκπληξη το γεγονός εάν η LG ενσωματώσει εισόδους HDMI 2.1 πλήρους φάσματος σε όλες τις σειρές OLED 8K / 4K (Z9 / W9 / E9 / C9 / B9) και LCD 8K LCD της περσινής σειράς.
Η κορεατική εταιρεία δικαιολόγησε την επιλογή αυτή, με τη μη διαθεσιμότητα στην αγορά περιεχομένου που να χρησιμοποιούν 48 Gbit / s, προτιμώντας επομένως να διαθέσει τα αποθεματικά chipset για την ενίσχυση της τεχνητής νοημοσύνης.
Διότι το εύρος χρησιμοποιεί το 2020 περισσότερους πόρους CPU και GPU για τη βελτίωση της ποιότητας των εικόνων και του ήχου μέσω αλγορίθμων AI.
Λαμβάνοντας υπόψη όλα αυτά, ορισμένοι μπορεί να προτιμήσουν να επικεντρωθούν στα μοντέλα του περασμένου έτους, οι διαφορές των οποίων φαίνονται να είναι οριακές.
Από την άλλη πλευρά, το OLED 2020 προσφέρει νέες λειτουργίες όπως η λειτουργία Filmmaker, το Dolby Vision IQ και η λειτουργία HGiG για παιχνίδια HDR.
Μ' αυτά και με άλλα, προσανατολίζομαι στο να περιμένω την ολοκληρωμένη σειρά 11 του 2021, όταν θα φέρουν και DisplayPort Alt Mode 2.0, 16K σε USB4 με WiFi 6.
(Τ' ακούς Αλέκο=LG, τ' ακούω να λες)!
source:[forbes]
lak100
26 December 2008
855
απ οτι ειπε ο vincent η σειρα 9 υποστηριζει κανονικα 48GBPS
xavito
29 October 2008
8,991
This week, LG revealed that the HDMI 2.1 bandwidth on the company's 2020 4K TVs including the CX and GX OLED is "only" 40Gbps instead of the 48Gbps implemented on last year's C9. Vincent and Adam discussed the real-world implications of this revelation, and also touched on DSC (Display Stream Compression) which is allowed for within the HDMI 2.1 specifications.
https://www.youtube.com/watch?v=GFJmjKJGx5o
source:[hdtvtest.co.uk]
hristoslav2
8 January 2016
359
Varna, Bulgaria
https://www.avsforum.com/forum/40-o...ner-s-thread-faq-posts-1-6-no-price-talk.html
ModellHDMI 2.1
(48 Gbit/s)
HDMI 2.1
(40Gbit/s)
HDMI 2.0b
(18 Gbit/s)
2020 ZX 8K OLED2x2x
2020 Nano99 8K LCD2x2x
2020 Nano97 8K LCD2x2x
2020 Nano95 8K LCD2x2x
2020 WX 4K OLED4x
2020 CX 4K OLED4x
2020 GX 4K OLED4x
2020 BX 4K OLED2x2x
2020 NANO91 4K LCD2x2x
2020 NANO90 4K LCD2x2x
2020 NANO86 4K LCD2x2x
2019 Z9 8K OLED4x
2019 SM99 8K LCD4x
2019 W9 4K OLED4x
2019 C9 4K OLED4x
2019 E9 4K OLED4x
2019 B9 4K OLED4x
enigmatiko40
23 May 2010
443
Αθηνα
Εχω παρατηρησει, και διορθωστε με αν κανω λαθος, πως σε καποια μοντελα τηλεορασεων του 2020 που θα ερθουν, η LG εχει προσθεσει Twin tuner και οχι σε ολα. Μαλιστα το εχει ονομασει και ως Dual tuner. Καποια μοντελα που εχω ξεχωρισει οτι εχουν αυτο το προσθετο χαρακτηριστικο ειναι η Nano867, Nano917, η σειρα UN7400, UN7300 και ολες οι OLED τηλεορασεις. Μπορει να ειναι καποια ακομη μοντελα που να τα εχω ξεχασει. Η πηγη που τα εχω δει ειναι:https://www.displayspecifications.com/en/brand/a1025
Ειναι κατα πολλους, κι εγω συμφωνω με αυτο, πολυ χρησιμη εφαρμογη, αν μπορω να το πω ετσι. Ευκολια και διαχειρηση στο τι εχει σε καποιο αλλο καναλι την ωρα που παρακολουθεις καποιο αλλο. Η Samsung και η Panasonic το εχουν στανταρ στις εκδοσεις τους στα πιο πολλα μοντελα.
Παντα, εννοειται να παιζει PAP, PIP, PAT, χωρις εξωτερικη συσκευη, οπως γινοταν πιο παλια και μονο με PIP σε καποιες Samsung 10ετιας, οπου για να δεις PIP επρεπε να συνδεσεις εξωτερικη πηγη μεσω hdmi. Οπως ηταν η παλια μου samsung le40c750! Τι εργαλειο ετσι? Sorry για το off topic σε αυτο το σημειο.
Στην Ελλαδα γνωριζουμε ποτε θα ερθουν? Ευχαριστω.
xavito
29 October 2008
8,991
65"...[homecinemamagazine.nl]...LG 65CX review...https://www.homecinemamagazine.nl/2020/05/review-lg-oled65cx6la-cx-serie-oled-tv/
65CX:W-OLED+CF
General:
Picture Mode: Cinema
Aspect Ratio Setting: Original / Scanning: On
Power Saving: Off
OLED Light: 80
Brightness: 50
Contrast: 85
Sharpness: 10
Color: 50
Tint: 0
Advanced controls:
Dynamic Contrast: Off
Dynamic Tone Mapping: Off / On
Super Resolution: Low
Color Range: Auto
Gamma: 2.2 / BT.1886
White Balance: Warm2
Maximum Brightness: Off
Image Options:
Noise Reduction: Low
MPEG Noise Reduction: Low
Smooth Gradation: Low
Black Level: Auto
Real Cinema: On
Motion Eye Care: Off
TruMotion: Cinema Clear or Custom with OLED Motion Pro: Low
xavito
29 October 2008
8,991
55"...[rtings.com]...LG 55CXPUA review...https://www.rtings.com/tv/reviews/lg/cx-oled
...Unfortunately, LG has dropped DTS decoding from their 2020 TVs...
...The CX doesn't support full bandwidth HDMI 2.1. It only has 40Gbps ports capable of 4k @ 120Hz @ 4:4:4 10-bit instead of 48Gbps ports which would be able to reach 12-bit, but we don't expect this to make any noticeable difference...
xavito
29 October 2008
8,991
55"...[rtings.com]...LG 55NANO85UNA review...https://www.rtings.com/tv/reviews/lg/nano85
PLS (Plane-to-Line-Switching) panel . It's technically different than an IPS panel, but still very similar.
...Local Dimming : Yes
Backlight : Edge (bottom)
Bad local dimming. It isn't very effective and makes dark scenes look worse. When there's a bright object that moves across the screen, the dimming zones around the object light up and it's noticeable even during real scenes. Setting the local dimming to 'Medium' helps with this issue, but overall, it gets very distracting...
...Unfortunately, LG has dropped DTS decoding from their 2020 TVs....
xavito
29 October 2008
8,991
We review the LG CX (pronounced as C10), a 2020 4K OLED TV from the South Korean brand which succeeds last year's C9. Topics covered in this video are near-black handling, colour accuracy, motion including 120Hz BFI, video processing, HDR including Dolby Vision IQ, as well as gaming including VRR.
Our review sample is the 55-inch LG OLED55CX, model number OLED55CX6LA which is exclusive to Currys in the UK. The LG CX is also available in 48-inch (OLED48CX), 65-inch (OLED65CX) and 77-inch (OLED77CX) sizes.
https://www.youtube.com/watch?v=NrRUTqfB_Ts
papasouzakias
13 May 2009
4,523
Η LG ξεκινά τις πωλήσεις της 48" OLED τον Ιούνιο.
Η LG θα ξεκινήσει τις πωλήσεις της LG OLED 48CX στην Ευρώπη και την Ασία τον Ιούνιο ενώ οι πωλήσεις στην Αμερική θα ακολουθήσουν λίγο αργότερα σύμφωνα με επίσημη ανακοίνωση της εταιρείας.
http://www.lgnewsroom.com/2020/05/p...-lgs-48-inch-oled-tv-rolls-out-in-key-markets
xavito
29 October 2008
8,991
We compare the picture quality of the LG CX vs last year's LG C9 OLED TV to help you decide if you should go for the 2020 or 2019 model. Topics covered include HDMI 2.1 bandwidth, DTS support, near-black handling, motion including 120Hz BFI, and standard-definition broadcast presentation.
Both OLEDs used in this comparison are 55 inches in screen size, model number OLED55CX and OLED55C9 respectively.
https://www.youtube.com/watch?v=FT5VK5YPTkc
xavito
29 October 2008
8,991
We compare the picture quality of the LG CX (pronounced as C10) and the Panasonic HZ1000 4K OLED TVs for 2020. Topics covered include near-black handling, colour accuracy, motion performance including 120Hz BFI, video processing, HDR, as well as input lag for gaming.
Our review samples are the 55-inch LG OLED55CX and 65-inch Panasonic TX-65HZ1000B.
https://www.youtube.com/watch?v=yw0Dygpz1pI
xavito
29 October 2008
8,991
65"...[lesnumeriques.com]...LG 65CX test...https://www.lesnumeriques.com/tv-televiseur/lg-65cx-p57919/test.html
μετάφραση google fr to en
...The sub-pixel structure has further evolved compared to that of 2019...
The white and blue sub-pixels are slightly smaller than last year, but the operation remains identical: each pixel is made up of four sub-pixels (a green, a red, a blue and a white). The white and red sub-pixels are larger in order to improve the maximum brightness of the screen, while maintaining a color temperature close to 6,500 K.
