Title: Baraka
Original title: Baraka
Released: 1992
Genre: Documentary
Director: Ron Fricke
Issued: USA
Length: 1:37:48
Format : Matroska
File size : 24.6 GiB
Duration : 1h 37mn
Overall bit rate : 36.0 Mbps
Writing application : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Video
Format : VC-1
Format profile : AP@L3
Codec ID : WVC1
Codec ID/Hint : Microsoft
Duration : 1h 37mn
Bit rate : 33.7 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.678
Stream size : 23.0 GiB (94%)
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Codec ID : A_DTS
Duration : 1h 37mn
Bit rate mode : Variable
Bit rate : 1 585 Kbps / 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 96.0 KHz / 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
James Bond CasinoRoyale
General
Format : Matroska
File size : 23.4 GiB
Duration : 2h 24mn
Overall bit rate : 23.2 Mbps
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container
[email protected]
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 24mn
Nominal bit rate : 20.5 Mbps
Height : 798 pixels
Display aspect ratio : 2.40:1
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.558
Writing library : x264 core 104 r1677 19df41a
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=54 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=1 / weightp=2 / keyint=24 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=20513 / ratetol=1.0 / qcomp=0.70 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=38000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=none
Language : English
Audio #1
Format : DTS
Format profile : MA
Codec ID : A_DTS
Duration : 2h 24mn
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 16 bits
Language : English
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Format profile : Dolby Digital
Codec ID : A_AC3
Duration : 2h 24mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : L R
Stream size : 199 MiB (1%)
Language : English
Audio #3
Format : AC-3
Codec ID : A_AC3
Duration : 2h 24mn
Bit rate : 192 Kbps
Language : English
Subtitles : English, Dutch
James.Bond Quantum of Solace
Movieinfo: :
http://www.imdb.com/title/tt0830515/
General
Format : Matroska
File size : 18.6 GiB
Duration : 1h 46mn
Overall bit rate : 25.1 Mbps
Video
Format : AVC
Format profile :
[email protected]
[email protected]
Duration : 1h 46mn
Nominal bit rate : 21.2 Mbps
Height : 798 pixels
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.578
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=54 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=1 / weightp=2 / keyint=24 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=21225 / ratetol=1.0 / qcomp=0.70 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=38000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=none
Language : English
Audio
Format : DTS
Format profile : MA
Codec ID : A_DTS
Duration : 1h 46mn
Resolution : 24 bits
Language : English
Complete name : Hellboy.2004
Format : Matroska
File size : 17.7 GiB
Duration : 2h 12mn
Overall bit rate : 19.1 Mbps
Encoded date : UTC 2011-04-24 05:21:38
Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format profile :
[email protected]
Format settings, ReFrames : 4 frames
Duration : 2h 12mn
Bit rate : 16.5 Mbps
Height : 1 040 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.346
Stream size : 15.7 GiB (89%)
Title : x264 2pass @ 16550 kb/s
Writing library : x264 core 114 r1924 08d04a4
Encoding settings : cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.05:0.20 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=16550 / ratetol=1.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio #1
Format : DTS
Codec ID : A_DTS
Duration : 2h 12mn
Bit rate : 1 561 Kbps / 1 510 Kbps
Bit depth : 16 bits
Title : English DTSHD-MA 5.1 - PBR @ 3246 kb/s
Language : English
Audio #2
Format : AC-3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 2h 12mn
Bit rate : 192 Kbps
Channel positions : Front: L R
Bit depth : 16 bits
Stream size : 182 MiB (1%)
Title : Director's Commentary
Language : English
General
Complete name : Memento.2000
Format : Matroska
File size : 16.8 GiB
Duration : 1h 53mn
Overall bit rate : 21.2 Mbps
Encoded date : UTC 2011-05-05 07:45:11
Video
Format : AVC
Format profile :
[email protected]
Duration : 1h 53mn
Bit rate : 19.2 Mbps
Nominal bit rate : 17.2 Mbps
Height : 816 pixels
Display aspect ratio : 2.35:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.512
Stream size : 15.2 GiB (91%)
Title : x264 2pass @ 17190 kb/s
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.05:0.25 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=17190 / ratetol=1.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : DTS
Codec ID : A_DTS
Duration : 1h 53mn
Bit depth : 24 bits
Language : English
