Νέοι Denon A/V FY '23
broncogr
9 December 2011
58
AV AMPLIFIER FIRMWARE UPDATE INCLUDING SUPPORT FOR DIRAC LIVE ROOM SOUND OPTIMIZATION SOLUTION, GREATER FLEXIBILITY IN SPEAKER LAYOUT, AND IMPROVED INTERFACE​
3 15, 2023​
Denon is pleased to announce that it has released the latest firmware for its AV amplifiers on March 2023, 3. Online firmware updates include support for the Dirac Live room sound optimization solution, greater flexibility in speaker layout when playing Dolby Atmos and Auro-15D, and improved speaker manual setup interfaces.
* The contents of the update vary depending on the product.
* Internet connection is required to perform firmware update.
* To use the functions of Dirac Live, you need to purchase a paid license and a corresponding measurement microphone.
See below for details of individual product updates.
1. Support for Dirac Live
Products Covered
  • AV surround amplifier: AVC-A1H
  • AV Surround Receiver: AVR-X4800H, AVR-X3800H
The high-end AV amplifier has been updated to support the room sound optimization solution "Dirac Live". You can use Dirac Live features by updating the firmware of the affected product and purchasing a paid license from the Dirac website. Dirac Live Room Correction Limited Bandwidth is available for measurement and correction from 20 Hz to 500 Hz and Dirac Live Room Correction Full Bandwidth for 20 Hz to 20 kHz. Dirac Live measurements use a networked Windows PC/Mac and a Dirac-recommended USB measurement microphone, so there is no need to connect the measurement microphone to the AV amplifier, and measurements can be performed even when the AV amplifier is away from the viewing position, such as the equipment room. If the PC is in a separate room, you can also connect a USB measurement microphone to the AV amplifier to take measurements.
Dirac Live Room Correction Limited Bandwidth: $259 Dirac Live Room Correction Full Bandwidth: $
349
*Prices as of March 2023, 3. Please visit the Dirac website for the latest prices. For more information, see here
* For more information on purchasing Dirac Live licenses, please visit the Dirac website. For more information, see here
※ How to use Dirac Live here Please refer to the instruction manual of
* Dirac Live and Audyssey MultEQ corrections cannot be used at the same time, but each setting can be registered in "Speaker Presets" and switched between them.
About Dirac Live
A large part of the quality of a sound system is determined by the quality of its components, including the quality of its speakers and amplifiers. On the other hand, the fact that the room where the sound system is installed also plays an important role in sound quality is often overlooked.
Dirac Live Room Collection software uses a unique approach to analyzing the acoustic characteristics of your room and correcting the sound of your system to deliver the best possible results. The Dirac Live Room Collection uses state-of-the-art, patented algorithms to analyze the impact of room characteristics on sound. Digital processing reduces its impact and brings out the original performance of the speaker. Doing so achieves an enlarged sweet spot when listening, precise staging, clarity, vocal clarity, and deep, toned bass that would not be possible otherwise.
2. Supports playback of Auro-3D format using top speakers
Target Models
  • AV surround amplifiers: AVC-A1H, AVC-A110, AVC-X8500HA, AVC-X8500H, AVC-X6700H
In the conventional target product, when playing the Auro-3D format, it was necessary to have a front height installed on the top of the wall, a surround height, and a top surround speaker installed directly above the listening position, but with this firmware update, the top front, top middle, Auro-3D playback using top rear speakers is now possible. So you can stay with Dolby Atmos' recommended speaker layout and enjoy Auro-3D content without adding speakers.
* Top front and top rear speakers play the sound of front height and surround height speakers.
* If a center-height speaker is not installed, the sound of the center-height speaker will be output from the top front speaker.
* The top middle speaker plays the sound of the top surround speaker.
Supports Auro-3D playback with top front, top middle, and top rear speakers
3. Supports playback of Dolby Atmos format using surround height speakers
Target Models
In the past, surround height speakers installed on the upper part of the left and right walls of the viewing position could not be used when playing the Dolby Atmos format, but with this firmware update, it is now possible to play Dolby Atmos using surround height speakers. So you can stay with the Auro-3D recommended speaker layout and enjoy Dolby Atmos content without adding additional speakers.
* Surround height speakers reproduce the sound of rear-height speakers.
Supports Dolby Atmos playback using surround height speakers
4. Improved manual speaker setup interface
Target Models
  • AV Surround Receiver: AVR-X4800H, AVR-X3800H, AVR-X2800H
The interface and setting items of "Manual Setup" for manually changing speaker settings and automatic settings have been improved.
- The setting items of "Amplifier assignment", "Speaker configuration", and "Speaker connection" are consolidated on one screen, and settings can now be made without going back and forth between multiple screens.
- Merged "Speaker Configuration" and "Crossover Frequency" settings. The "large" and "small" settings of the speakers have been abolished and changed to only set the crossover frequency with the subwoofer.
- Infrequently used items such as "LFE settings", "XLR output terminal assignment", "front speaker A/B switching", and "1-channel playback settings" have been consolidated into "Advanced settings".
* Available setting items vary depending on the product.
Consolidate "Amplifier Assignment", "Speaker Configuration", and "Speaker Connection" setting items on one screen
Reactions: Pleo
Pleo
14 March 2008
19,710
Να πω εδώ κάτι που παρατήρησα και αφορά και παλαιότερα μοντέλα.
Γενικώς ό,τι feature συμπίπτει αναβαθμίσημο και υποστηρίζεται από τα παλαιότερα μοντέλα, το παίρνουν και αυτά.
Ας δουνε οι χρήστες παλαιότερης γενιάς Denon το πως μπορούν να έχουν και αυτοί ανεξάρτητο πλέον το ARC από το HDMI control. Το είδα μετά το update και στον 1700Η που δεν είναι σειρά ***800.
Ψάξτε το.
Reactions: broncogr
Wspr
13 July 2020
80
Η τιμή του είναι 350+150 το mic γύρω στο 500αρικο…Αξίζουν τα χρήματα που ζητάει;
Pleo
14 March 2008
19,710
231 το limited και 325 το full έχει.
Αν θέλεις το Dirac. Αλλιώς έχει και Audyssey από μόνος του.
Wspr
13 July 2020
80
Τ αξίζει τα χρήματα που ζητάει;θα δει κάποιος διαφορά στον ήχο του ;;;
billpeppas
23 October 2013
6,819
Athens
Βοηθάει.
Αν αξίζει τα 231 που ζητάει; Μάλλον ναι.
ΑΝ μπορεί κανείς να "μεταφράσει" σε χρήματα την διαφορά που κάνει.
Φυσικά όπως και όλα τα room correction systems, αυτό είναι το "κερασάκι στην τούρτα"... η "τούρτα" είναι η ακουστική φροντίδα του χώρου και η σωστή χωροταξία (τοποθέτηση ηχείων, subwoofer/s, θέσης ακρόασης, ακουστικά πάνελς, διαστάσεις χώρου).
Wspr
13 July 2020
80
Είναι κ το μικρόφωνο που χρειάζεται μιας και αυτό που δίνει δεν κάνει…όποτε ανεβάζει και αυτό το κόστος…προφανώς και ο χώρος/ηχεία/ενισχυτής δεν αλλάζουν και πολύ το θέμα είναι οτι 350 στα 1700 που κάνει ο Denon 3800 δεν είναι κ αμελητέο ποσο
Pleo
14 March 2008
19,710
Δεν είμαι σίγουρος αν κατάλαβα τον συσχετισμό σε σχέση με την τιμή του ενισχυτή.
Θα προτιμούσες το κόστος να είναι ενσωματωμένο στην τιμή του ενισχυτή και αυτός να κοστίζει περισσότερο χωρίς να έχεις τη δυνατότητα να διαλέξεις αν το θέλεις ή όχι;
Εναλλακτικά μπορείς να δεις το MultEQ-X που μπορεί να χρησιμοποιήσει το υπάρχον μικρόφωνο.
Reactions: broncogr
Pleo
14 March 2008
19,710
Ελπίζω να μην είναι πολύ βασικό, γιατί λέει how to get started και αν κρίνω από τη διάρκεια (την οποία συνήθως ξεπερνούν βέβαια) μάλλον θα δεν θα είναι κάποιο deep dive στη χρήση.
Εκτός αυτού θα είναι και Μ. Πέμπτη, μέρα πιο κατάλληλη για τσίπουρα. :p
Εάν έχει κάποια πληροφορία σχετικά με το Dirac που δεν είναι γνωστή στους περισσότερους, θα βάλω τα αντίστοιχα screenshots.
Για παράδειγμα έχει αναφερθεί πολλές φορές ότι εκτός από το laptop, θα μπορεί κάποιος να συνδέει το μικρόφωνο και στη USB της πρόσοψης. Αυτό χρήζει διευκρίνησης.
Dirac Live Webinar
In this the webinar, you will have the opportunity to learn from our expert panelists, including Oliver Kriete, Product Manager Europe, as they discuss the latest updates, functionalities, and requirments related to Dirac Live. You will also have the chance to ask questions and participate in a live Q&A session.
Whether you are a distributor, a salesperson, or simply interested in learning more about Dirac Live, this webinar is a valuable opportunity for you to gain insights.
The webinar is scheduled to take place on Thursday, 20th April at 10:30 AM CET and will last approximately 45 minutes.
Agenda
  • Introduction
  • What is Dirac live ?
  • What is required to get started?
  • How does it work?
  • Q&A session
Duration : 45 minutes
(30 minute presentation, plus 15 minutes reserved for Q/A)
Reactions: broncogr
broncogr
9 December 2011
58
New firmware with Dirac delay limit raised to 50ms is released today
Firmware from 24.05.2023 (U30.1)
HEOS iOS App (2.98.330)
HEOS Android App / Kindle Fire App (2.98.330)
HEOS Firmware: HS2 devices (2.98.332)
Households with only HS1 devices will remain on version 1.583.147 (U25.10)
Households with both HS1 and HS2 devices, HS1 devices will remain on 2.71.510 (U29.3)
  • Fixed: Audible skips chapters when using Alexa voice control.
  • Fixed: The HDMI card does not refresh the "HDR MaxCLL/MaxFALL" info changes in the stream.
  • Fixed: When selecting "Top front + Top surround" as height speakers, "Auro 3D" is (correctly) not displayed as available Sound format. But when you play any content (ex: Internet radio) with settings, you are now able to select "Auro 3D" as Surround Format.
  • Fixed: Sound is interrupted while playing FLAC 88.2kHz music on USB-A or music server.
  • Fixed: Noise or Audio drop occurs during the last 5-10 seconds while playing certain m4a files.
  • Fixed: The value for "Auro 3D" Preset is NOT stored on "Quick Selects".
  • Fixed: Stored DAB stations on AVR show correct on TV GUI, but on "AVR Remote App", some stations are missing.
  • Fixed: Display is not showing DSD tracks from DLNA server correctly.
  • Fixed: AVR Remote App (and also on the AV display) instead of "DTS-HD MSTR" it now says "DTS-HD Hi Res" for DTS-HD Master Audio content.
  • New feature: Added support for "Station Skip" restriction in HEOS App for Amazon Prime users. Skip operations are limited to a maximum of 6 tracks for one hour.
  • New feature FY23 AVR: Dirac Live measurement distance increased from 20ms to 50ms
Other bugfixes and performance improvements
Reactions: Pleo
Pleo
14 March 2008
19,710
Denon announces 125 W at 8 Ω and two driven channels (at a much lower than standard distortion level - 0.05%). So we start by setting the impedance selector to the "8 Ω" position and gradually load more and more channels with the "regulatory" 8 Ω impedance. With two channels (in stereo) we have 2 x 152 W - so more than promised by the manufacturer (but with the general distortion of 1%). With five channels we note 5 x 79 W, with nine 9 x 48 W.
Pleo
14 March 2008
19,710
Όταν είχαν κυκλοφορήσει τα προσχέδια για τον AVR-X1800H, το μάτι μου είχε πέσει επάνω σε μια λεπτομέρεια, η οποία εν τέλει δεν φαίνεται να υλοποιείται (pre-out για τα δύο εμπρός κανάλια) βλέποντας τις πρώτες φωτογραφίες.
Από Σεπτέμβρη λοιπόν, ίσως ανακοινωθούν μέσα στον τον Αύγουστο, θα έχουμε ανανέωση στο κάτω μέρος της γκάμας.
AVC-S670H
AVR-S670H
AVR-S770H
AVR-X1800H
AVR-Χ1800Η DAB
Οι διαφορές σε σxέση με τα τρέχοντα μοντέλα θα αφορούν τη νέα σχεδίαση του μενού (αλα 2800Η) πράγμα που σημαίνει ότι και σε αυτούς θα δούμε να καταργείται το designation small/large στα ηχεία και να υπάρχει κατ' ευθείαν ορισμός συχνότητας ή full range.
Δεν αλλάζει σε αυτούς ο αριθμός τριών θυρών HDMI 2.1 και τριών 2.0, στην πράξη τώρα τα μοντέλα αυτά φτάνουν αντιστοίχως για τη σειρά S εκείνα που έφερε 970Η σε σχέση με τον προκάτοχό του 960Η και για τη σειρά Χ εκείνα που έφερε ο 2800Η σε σχέση με τον 2700Η.
Και στον δικάναλο AV μαζί με τη Marantz θα υπάρχει αλλαγή αλλά αυτό δεν αφορά τα πολυκάναλα νήματα.
Reactions: broncogr
Pleo
14 March 2008
19,710
Λίγο πιο μετά από τους παραπάνω, συν τον δικαναλο DRA-900H, θα έρθει και ο AVC-X6800H, ΑVR-X6800H για τις άλλες αγορές, με την Ευρώπη να έχει τουλάχιστον με τα μέχρι τώρα δεδομένα την αποκλειστικότητα στο ασημένιο χρώμα.
Ένα σκαλοπάτι πιο κάτω από τον Α1Η, θα είναι με έντεκα κανάλια ισχύος και δεκατρία επεξεργασίας.
Τυπικά 4 ανεξάρτητες εξόδους subwoofer, DIRAC, Audyssey Pro, made in Shirakawa Japan κλπ.
Pleo
14 March 2008
19,710
Οι νέες προσθήκες στη σειρά S.
Reactions: vadergr
Pleo
14 March 2008
19,710
OK, αφού πλέον υπάρχει στο internet ως πληροφορία κάπου στην Αυστραλία, ας δούμε τον DRA-900H.
Πρόσθεσαν έξοδο προενίσχυσης σε σχέση με τον DRA-800H, προφανώς θα έχει και το νέο HD menu. Φυσικά απέκτησε και HDMI 2.1 στις τρεις από τις έξι συνολικά εισόδους του και στην έξοδο καθώς φαίνεται στη φωτο.
Νομίζω ότι έλειπε η έξοδος προενίσχυσης, κάτι που είχε ο NR1200 που είναι ο αντίστοιχος δικάναλος της Marantz και που φυσικά θα έχει και ο αντικαταστάτης του.
Για τις 22 του μήνα, σε λίγες μέρες δηλαδή, έχει προγραμματιστεί και το launch για τον 1800Η και 1800H DAB. Δεν έχει νόημα να βάλω φωτογραφίες αφού είναι πανομοιότυπος με τον 1700H & 1700H DAB με τις ίδιες 3+3 εισόδους και τη μία έξοδο. Η μόνη διαφορά θα είναι το νέο μενού και τις όποιες λειτουργικές διαφοροποιήσεις αυτό θα έχει (π.χ. κατάργηση του small/large στα ηχεία).
Την ίδια μέρα θα παρουσιαστεί επίσημα και ο DRA-900H.
Pleo
14 March 2008
19,710
22 του μήνα σήμερα. ;)
Reactions: chocbhed
