Απάντηση: Re: Panasonic G9, Φωτογραφική μηχανή high end
Από σήμερα είναι διαθέσιμες οι βελτιώσεις :
Expanded compatibility with Profoto wireless transmitters
- Profoto wireless transmitters "Air Remote TTL-O/P" and "Profoto Connect-O/P" can be used.
* All functions may not be available depending on the situation.
Improved AF performance
- [Animal Detect.] has been added to AF mode.
- It is possible to switch the subject to focus on by pressing the joystick in [Face/Eye/Body/Animal Detect.] mode.
- [AF-ON: Near Shift] and [AF-ON: Far Shift] functions have been added. [AF-ON: Near Shift] preferably focuses on a subject nearby while [AF-ON: Far Shift] preferably focuses on a subject far away.
- Focus Peaking function is available in any AF mode.
- It is possible to set continuous AF on the live view screen in Creative Video mode or in other video recording mode when the video recording area is displayed.
Enhanced video functions
- 4K 30p/25p 4:2:2 10-bit internal recording is supported.
- 4K 60p/50p 4:2:2 10-bit HDMI output is supported.
- Luminance level for 10-bit video is supported.
- VFR (Variable Frame Rate) shooting is supported.
- HDR video recording is supported.
- V-Log L recording and Waveform Monitor (WFM) are available with the Upgrade Software Key DMW-SFU1(sold separately).
Other added functions
- [MODE2] has been added to High Resolution mode, which reduced subject's motion blur.
- [AWBw] has been added to WB mode.
- [Highlight Weighted] has been added to metering mode.
- [Exposure Offset Adjust.] has been added to Custom menu, which enables adjustment of the standard exposure value for all metering modes.
- [0.5SEC] has been added for an option of [Duration Time (photo)] in [Auto Review].
Other improvements
- AE can be locked with the [AF/AE LOCK] button when ISO Auto is set in M mode.
- [MODE1] has been added to the Live View Boost function, which increases the frame rate for smooth image display to enable easier manual focusing.
Improved operational stability
- There were cases where Backup Recording using the Double Card Slot Function stopped during writing. This bug has been fixed.
- AF operation following the pressing of [AF-ON] in MF mode was unstable when the LVF Frame Rate was at 120 fps and the camera was under dim lighting. This bug has been fixed.
- There were cases where the images shot vertically did not rotate on playback. This bug has been fixed.
- Operational stability of image stabilizer has been improved. (When [Image Stabilizer] > [E-Stabilization(Video)] and [Boost I.S.(Video)] is ON. ).
https://av.jpn.support.panasonic.com/support/global/cs/dsc/download/fts/dl/g9.html
